Andreas Ewe
Aerofly FS 2 Plugin 2.1.1.0
SimTools plugin for Aerofly FS 2
  1. SeatTime
    Also, don't forget to select 'Anti RollOver' in simtools for Roll and Pitch.
  2. Arianus One
    Arianus One Tony Rom
    empleado
    Capilla del Monte,Cordoba, Argentina
    16Coins
    :thumbs
  3. fafafoot
    fafafoot New Member
    bruz
    - 165Coins
    hello, is this normal when i put the stick on the left, the simulator rises on the left too? He should lean to the left, right? Thanks for your help
    154,669Coins
    +11,207 / 57 / -2
    This is how SimTools expects a rig to be configured: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    When you roll left the rig should lean to the left.
    The Dir box in Axis Assignments being checked orange or not determines which way an axis moves.
  5. fafafoot
    fafafoot New Member
    bruz
    - 165Coins
    I did exactly as it was noted in the patch and it seems to be the opposite, right?
  6. fafafoot
    fafafoot New Member
    bruz
    - 165Coins
    154,669Coins
    +11,207 / 57 / -2
  8. zgseat
    zgseat New Member
    Engineer
    Shanghai, China
    135Coins
    I installed aerofly fs 2 flight simulator and downloaded the plugin, but cannot find how to set up and get the motion data, please tell me how to set up? Thank you very much.
  9. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    More details about your problem with SimTools setup??? :confused:
  10. zgseat
    zgseat New Member
    Engineer
    Shanghai, China
    135Coins
    the problem is fixed , thanks.
  11. kparkin
    kparkin Member
    United Kingdom
    236Coins
    4DOF
    Anyone know if there are any plans to activate Extra 2 & 3 to get continuous roll and pitch?
  12. kparkin
    kparkin Member
    United Kingdom
    236Coins
    4DOF
    OK, I see that the Extras no longer work.
  13. Avee
    Avee Virtual Pilot
    1,167Coins
    @Andreas Ewe Do you know what the update frequency of ground speed and rate of turn from FS2 would be? I am thinking I might want to take a stab at interpolating acceleration forces by estimating them myself between updates from FS2. Sway can be caculated by ground speed, rate fo turn and bank (turning without banking causes sway like in a car, banking without turning causes sway like in a ship). surge can be calculated by speed differential and pitch differential (am I accelerating or am I changing my orientation towards gravity). I think that would be close enough to fill in the gaps.
  14. Guyotine
    Guyotine New Member
    - 1Coins
    3DOF, SCN6
    Hello to you. I have a problem. everything works correctly for 15min, then the dynamic system stops. I have to exit the game and restart it. and 15 minutes later it stops again. Any ideas?
  15. DZSchneider
    DZSchneider New Member
    Toronto
    64Coins
    Anyone know if it's possible to get Surge out of the sim? The current plugin doesn't appear to have it.
  16. alfsin
    alfsin New Member Gold Contributor
    España
    - 1,019Coins
    Hello, I have checked, that the surge gets the data from the yaw.
    You could check if it can be corrected, thanks and a greeting.
  17. alfsin
    España
    - 1,019Coins
    @Andreas Ewe Hello, I have checked, that the surge gets the data from the yaw.
  18. izhangt
    izhangt Member Gold Contributor
    - 91Coins
    2DOF, Motion platform
    what exactly i have to do to make that plugin work? what dll are missing? where i have to put them? simtools installation folder, no motion here, the game recognice, tuning center doesn´t capture, i have to do something with ip settings inside the game????
  19. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
    Game attached but no movement
  20. noorbeast
    154,669Coins
    +11,207 / 57 / -2
    Please post pictures of ALL settings, including the Tuning Center while Aerofly FS 2 is running.
