Question After the DR 2.0 update and support for VR, the motion simulator plugin seems to be invalid.
Discussion in 'Dirt Series' started by wp8051, Aug 8, 2019.
  1. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    Oculus home version:
    <?xml version="1.0" encoding="UTF-8" ?>
    <hardware_settings_config version="25" deviceId="0x17C8">
    <cpu>
    <threadStrategy workerMapFile="system/workerMap4Core.xml" forceFeedbackProcessor="3" dvdStorageProcessor="3" dataSetMonitorProcessor="1" renderProcessor="0" updateProcessor="2" fileStreamProcessor="3" />
    </cpu>
    <audio_card>
    <dynamic_range value="low" />
    <eq value="flat" />
    <voice_chat enabled="true" />
    <push_to_talk enabled="true" />
    <music level="99" />
    <replay_music level="100" />
    <effects level="100" />
    <engines level="100" />
    <speech level="100" />
    <surfaces level="100" />
    <voip level="100" />
    </audio_card>
    <motion_platform>
    <dbox enabled="false" />
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="4123" delay="1" />
    <custom_udp enabled="false" filename="packet_data.xml" ip="127.0.0.1" port="20777" delay="1" />
    <fanatec enabled="false" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
    </motion_platform>
    <physics environmentalDamage="true" vehicleDamage="true" />
    <input device_type="auto" />
    <controls neutralTimeToShift="0.25" />
    <graphics_card rating="1">
    <eyefinity force="" osd="" />
    <stereo enabled="false" separation="0.015" convergence="0.5" />
    <resolution width="1366" height="768" aspect="auto" fullscreen="0" vsync="0" refreshRate="143" multisampling="4xmsaa" supersampling="1" taa="1" />
    <gamma level="0.600000" />
    <hdr level="1.0" />
    </graphics_card>
    <shaders low_quality="false" />
    <textures quality="2" />
    <anisotropic target="4" />
    <shadows enabled="true" size="2048" maskQuality="1" particles="true" grass="false" />
    <particles enabled="true" wind="true" dynamicRes="false" lowResScalar="4" nearFadeBias="0" emissionRate="1.0" />
    <weather quality="1" />
    <crowd enabled="true" detail="3" />
    <cloth enabled="true" tessellation="true" />
    <ground_cover clutter="true" enabled="true" lodScaling="1.0" />
    <objects lod="1.01" maxlod="0" stones="true" />
    <trees lod="1.0" maxlod="0" meshes="true" />
    <vehicles characterQuality="3" lodQuality="2" textureQuality="3" />
    <track lod="1.4" />
    <reflections>
    <envmap size="512" quality="1" scaleminsize="1.0" mindistance="100.0" facesPerFrame="3" />
    <ibl probeSize="256" diffuseSize="16" diffuseSamples="128" specularSize="256" specularSamples="128" />
    </reflections>
    <mirrors enabled="true" width="768" height="256" car_maxlod="1" car_culldist="300.0" />
    <skidmarks enabled="true" />
    <dynamic_ambient_occ enabled="true" quality="3" />
    <dynamic_ambient_occ_soft enabled="false" />
    <night_lighting volumes="true" shadows="true" onlyHeadlights="false" shadowSize="1024" renderTrees="true" renderVehicles="true" renderOrganisms="true" />
    <aoit enabled="false" />
    <avsm enabled="true" />
    <postprocess>
    <motion_blur enabled="true" replayonly="false" />
    <god_rays enabled="true" replayonly="false" />
    <chromatic_aberration enabled="true" replayonly="false" />
    <bloom enabled="true" replayonly="false" />
    <lens_flares enabled="true" replayonly="false" />
    <light_streaks enabled="true" replayonly="false" />
    <lens_dust enabled="true" />
    </postprocess>
    <screenspace_reflections enabled="true" replayonly="true" />
    <vr enabled="true" eyeDistanceMultiplier="1.000000" lockedOrientation="false">
    <motion_blur enabled="true" />
    <vignetteless enabled="true" />
    </vr>
    </hardware_settings_config>
  2. yobuddy
    51,529Coins
    There is a new plugin posted...
  3. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    Hi Yobuddy. Can you tell me where? I find only 2.1 in update:) TY!
  4. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    2.1 gives me the problem that as soon as I return to the menu the gamengine goes into blink and no motion
  5. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    Since mine is the oculus home version of the game, not the steam one, the xml file named
    "hardware_settings_config_vr"
    but
    "hardware_settings_config" probably patch dont work for me?
    I tried to edit manually
    <udp enabled="true" extradata="3" ip="192.168.x.x" port="4123" delay="1" />
    x my port
    nothing, after enter menu stopped
    I have post my oculus version .xml above
    C:\Users\SacroWorld\Documents\My Games\DiRT Rally 2.0 Oculus\hardware_settings_config
  6. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    motion for me work one time, if i esc on the menu stop working ...Any Solution?? I am stuck
  7. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    the location for save game is changed. its under "C:\Program Files (x86)\Steam\userdata\135213117\690790\remote" and not on savegame.
    i try to patch on 3 diferent DR2. codex, steam and windows store. no success.
    windows store ( xbox game pass ) its a bad version. no ones patch this version, because winapp folder have locked files by MS. steam version added simvibe normally, so, telemetry its work. but, the patch for simtools, dont work because savegame folder dont have anything. i try to copy files from remote and paste, but the same message appears. I hope this problem have a solution
  8. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    For all of you guys having troubles with no motion after pause the game, please try to turn off startup / resume and shutdown / centering speed at simtools tools AND remove HEAVE from your axis assignments..
    To me it seems like heave is causing all the troubles (it gets "NaN" value in tuning center at pause) and is trying to recenter rig even after it is turn off in simtools. Then it fails to resume normal play..
    This works out for me! I don´t have heave but can use most important surge / sway at least! Give it a try and let me know if it helps:)
  9. sulfail
    sulfail Member
    Mason
    vigo(pontevedra) SPAIN
    205Coins
    If sir Martin, that's where the shots go, removing heave no longer disconnects, the probelma is the heave, if the deactive no problems but if I turn it back on no longer works, IT IS THAT, hehe now it is only necessary for someone who understands to code this , by the way in tools you do not need to disable the startup and summarizes, nor the shutdaw and centering, I test it with this activated and it works the same if you turn off heave, so the problem has to do with heave, to see if it is solved because without the heave it is not the same , but thank you at least you can already use it without disconnecting +++1000 :thumbs:thumbs:thumbs:thumbs.
    forgive me for my English use translator.
  10. sulfail
    sulfail Member
    Mason
    205Coins
    you have to deactivate heave
    in the axis assignment, and no longer disconnects the movement, at the moment it is the only solution, you can enjoy the others without problems arises, sway,pitch,roll etc, but heave is not the one that causes the problem, friend thanks to Martin realized , let's see if they fix it soon, but for now deactivating that works well.
  11. sulfail
    sulfail Member
    Mason
    205Coins
    I have to say that update the dirt rally 2 plugin to the latest version 2.03 and now it is perfect, it does not stop and you can enter and exit the menu to the desktop without problems, this simulator with simtools is fantastic, many thanks to youbudy and All the members who helped update it, excellent work, it works great, thanks.hug:hug:hug:hug:with mixed reality lenovo explorer.
    It works well with all effects, and the all-perfect centering of 10.
  12. Juuso Pulkkinen
    Juuso Pulkkinen New Member
    74Coins
    Hello!
    I'm a newbie here nyt I have a question to ask and there is so many instructions that im very confused.
    So my rig is working fine with DR 2.0 but soon as I want to play it trought VR, I start Steam VR and use the game from there, Game manager reagonizes Dirt Rally 2.0 and its turning blue sayin game running but nothing happens during the game.
    When I close VR it Works fine again.
    I have 2dof Prosimu rig and Oculus Rift S.
    Thank You
    Juuso
  13. noorbeast
    153,788Coins
    +11,150 / 57 / -2
    Install the latest plugin update, with VR patch: https://www.xsimulator.net/community/marketplace/dirt-rally-2-plugin.224/
