Bug After Windows 10 update to 2004 (from 1909) Intensity Slider problems.
Discussion in 'SimTools DIY Version' started by p00ky, Jun 1, 2020.
  1. Damien
    Damien Member
    watchmaker
    Royan
    724Coins
    2DOF, SCN6
    Always the same, so I went back to the 1909 version.
  2. Michael Jeffries
    Michael Jeffries Member Gold Contributor
    485Coins
    Motion platform, 4DOF
    Today I raced again in iRacing with win10 2004 version - 100% gain and no changes to my profile
    All worked well. I was on canadian mosport track which i havent run in a while and it felt like it was maybe slightly rougher than previous races, but that could've been due to the track's configuration itself.
    No issues found still good on Win10 2004.
  3. yobuddy
    51,529Coins
    thanks for all the reporting guy's, im sure we will track down the issue.
    Take care,
  4. p00ky
    p00ky Active Member
    Self Employed Laser Cutter
    Wales
    392Coins
    Im not sure as I simply opted to turn everything up to 100 and havent looked back :)
    It would seem that some people have an issue but not others and no one has been able to come up with a reason why this odd behaviour happens. If your at all worried, rolling back the update is very quick (the install not so much) so if you find you have trouble you can get back to 1909 in the time it takes to make a coffee.
    • Dislike Dislike x 1
  5. Michael Jeffries
    485Coins
    Ye i use the gain at 100% as well and havent noticed any issues. Ive raced at least 10hrs worth since the update and probably more, but its not as others are saying it is. I did notice some strange bugs that popped up, but nothing that a reset button didnt fix. So far so good here as well.
  6. CoolSpy
    CoolSpy New Member
    - 4Coins
    Same problem for me with a Prosimu 2DOF and windows 2004! I race at 99%, it's acceptable but anything lower is pretty much like no motion and at 100% it's way too brutal... the gap between 99 and 100% is unreal, it's like the curve is exponential :(
  7. Zed
    USA
    5,845Coins
    Glad to see this thread. My computer held off on the update and told me Windows wasn’t ready yet for my hardware. It finally updated about two weeks ago and I noticed this in DCS too. If I sit quiet I can feel tiny movements but not near the same as I felt before the update. I hadn’t had a chance to look into it yet but this sure sounds like the same thing.
  8. Damien
    Damien Member
    watchmaker
    Royan
    724Coins
    2DOF, SCN6
    Hey, guys.
    For those of you with that problem, has anyone tried again since?
  9. CoolSpy
    CoolSpy New Member
    - 4Coins
    Yes same problem as today... I just gave up on SimTools and bought a Sim Racing Studio software license.... I don't think I'll ever look back!
  10. Damien
    Damien Member
    watchmaker
    Royan
    724Coins
    2DOF, SCN6
    Hey, guys.
    I tried again with Windows 2004 and simtools 2.4.1, still the same problem.
    So I stay in 2004 but I drastically lowered my values to get a correct rendering. 70->35, 60->30, even 70->20.
    On ACC, it looks pretty good.
  11. yobuddy
    51,529Coins
    I have reports that you need to reboot after the upgrade (even thou it reboots during the upgrade).
    Also a clean install seems to work fine also.
    Take care,
  12. Damien
    Damien Member
    watchmaker
    Royan
    724Coins
    2DOF, SCN6
    Hi Yobuddy.
    I just tried to completely uninstall simtools then reinstall it but the problem is still the same.
    Below 100%, the jacks(cylinders) are soft and slow.
    I only have ACC, I could not test on other games.
    It's strange.
  13. kscorp
    kscorp New Member
    france
    95Coins
    3DOF, SCN6, Motion platform, 6DOF
    I have exactly the same problem with Windows 10 2004. Big problem under 100% intensity level...very very slow. Very big latency. 100% it''s too big. With 1909 version, no problem. I reinstall fresh version of windows 10 2004 with iso and boot key... No way, I have always the same problem. It's crazy...
    Do you have an idea @yobuddy for this problem...Since a moment already....
    Thank you
  14. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    Hello drivers, i think same problem me to, when i use the smc3, al work perfect. But when i test in simtools ( output testing ) the slider under 0% not doIng anything after the -90% and react to hard for the position and for get back need to move the slider by at least the 1% Positive position,
    0 to 100% positive work “fine”
    Win 10 64bit pro (2004)
    Simtools 241
    Mobo: x570 msi 3600amd rz 3gen
    I’m in the same page? I mean this is the error all we have?
    Better if i intall the 240 version simTools?
    Or need to made a new thread?
    Thanks guys!
  15. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    Hmm The idea is always going forward, i have a original win and all licenses original to. I hope this be fixed soon.:thumbs
  16. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    Well so far so good,
    I uninstall simtools 2.4.1
    i see windows 10 have another new update on frameworks (2004) so i installed.
    just reinstall the later version of simtools 2.4.0
    All works great.
    Hope this helps someone.
    Maybe it's the last version of simtools on win10(2004)
    Just for the record that’s was my steps.
    Good race guys!
  17. elnino
    elnino Active Member
    Computer Geek
    Adelaide, Australia
    1,557Coins
    Wow! I have exactly the same problem! I just rebuilt my sim PC with fresh windows and Simtools (so 2004 and 2.4.1. Weird other issues too - DOF Axes will only go positive, not negative - Or they do but don't hit the % needed to move and then 'jerk' like you describe.
    So you rolled back to 2.4.0 and it fixed it?
  18. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    Amaizng , i see we are on a clearly on a bug.
    Yeah man. That’s what happened .
    I update again windows ( Whith the hope on this update fixed the problem , but not) so i decided uninstall simtools and every file on my newpc and go back to the 2.4.0. And with no mistery , works . o_O
    Yesterday i run a complete a race with not problems. ( but i think it’s react differently or now it’s just me ) like the lowers inputs are soft and the harder to harder. Or i’m getting picky :eek:
    Tell us how it’s work for you.
    Good luck !
  19. Damien
    Damien Member
    watchmaker
    Royan
    724Coins
    2DOF, SCN6
    Me, it's quite the opposite.
    With simtools 2.4.0, it worked very well on Windows 1909.
    When I switched to Windows 2004, it was not working well.
    So I installed 2.4.1, but no changes.
    That's strange.
  20. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    mine was a 2004 fresh build so i cant go back to 1909 but i have not had a chance to try 2.4.0 yet either
