AMC-AASD15A servo controller
Discussion in 'SimTools compatible interfaces' started by Thanos, Nov 6, 2019.
  1. Dirty
    All the way up front.
    7,980Coins
    Here in Germany B-type breakers (240V/16A) are most common and I got those as well.
    I think you're right, it seems that the slower C-type would be much better suited to tolerate those few 1/10ths of a second of overcurrent.
    :thumbs
  2. Mat_Menzies
    Mat_Menzies New Member
    94Coins
    Hi Thanos, why do we set the pulse ratio (electronic gear ratio) Pn098 to 20?
  3. Dschadu
    Dschadu Active Member
    1,938Coins
    This means one revolution is split up to 500 pulses on the dir input. So 500 pulses = 1 rotation.
    You end up with 0.72° resolution, which translates to 0.01 mm minimum distance on a 5 mm spindle, or 0.02mm on a 10 mm spindle and so on...
    Formula is:
    PN102 PN98 = Steps you want / CPR * 4
    CPR is for the China servos 2500:
    500 / 2500 * 4 = 0,05 = 1 / 20 (as fraction)
    PN102 = 1
    PN98 = 20
  4. Thanos
    Electronics Engineer
    United States
    2,925Coins
    I kept this setting from SFX100, as I wanted to have plug and play with existing systems. But this also helps to allow more pulses for longer stroke actuators, and with proper gearing it can do up to 2450mm stroke actuators or 160:1 ratio on rotary actuators...
  5. Mat_Menzies
    94Coins
    HI Thanos, thanks for the info on the electronic gear ratio.
    I'm not sure if you have already done a full manual Thanos, but I cant find one. I have read all pages in this thread on Xsim and watched many of your videos, but I would much prefer / like an organised and informative written reference to use if its available.
  6. Mat_Menzies
    94Coins
    Thanks Dschadu for your very informative answer. I appreciate the detail.
  7. Thanos
    United States
    2,925Coins
    There is manual on the Github page:
    https://github.com/tronicgr/AMC-AAS...5A_4DOF+TL+Surge-SRS-Simtools_manual_v2_6.pdf
  8. Mat_Menzies
    94Coins
    Yes, thanks.
    Its colourful, but not what I would call 'complete' or 'reference' though :)
  9. Thanos
    United States
    2,925Coins
    It's a user's manual, doesn't need detailed description of what's going on under the hood.
    Its like a car manual, they don't show the fuel injection timing charts, or how the CPU talks to the peripherals and radio...
    Anyway if you need more info, like for custom motion software programming, there is material available if you ask for it.
  10. Thanos
    United States
    2,925Coins
    154,723Coins
    +11,213 / 57 / -2
  12. Thanos
    United States
    2,925Coins
    Oh, thank you!! hug:
  13. Thanos
    United States
    2,925Coins
    Anyone needs larger indication leds for the AMC-AASD15A? Check out this easy mod:
  14. noorbeast
    154,723Coins
    +11,213 / 57 / -2
    Vert cute @Thanos!
    Are size variations possible?
  15. Thanos
    United States
    2,925Coins
    Well, I found the one I used on the video on Amazon
    It was the most inexpensive I could find that has individual control circuit per color.
    Another one I found, is this one, but decided against it as it seems its only battery operated and the LEDs are not so bright...
    There are some other ones, bigger, but perhaps too expensive and don't know if they are same easy to hack. Like this industrial quality one :)
    Thanos
  16. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    113Coins
    Hello Thanos is it possible to use Simtools with thanus4u. What are the limitations? I would like to use some games that are not supported by SRS.
    thanks for your reply!
  17. Thanos
    United States
    2,925Coins
    Its working with Simtools now... I had to fix a bug.
    The latest firmware fixed it.
    It just doesn't have full integration to configure the Thanos4U from Simtools, like SRS does. I'm trying to get a remote configuration utility done for the Thanos4U so people can configure it without have to use SRS...
    Thanos
  18. bob williams
    IT
    Ermelo, Netherlands
    113Coins
  19. Thanos
    United States
    2,925Coins
    If you wonder how to make a safe power box for your motion simulator...
  20. sallerding
    sallerding Member
    Perth, Western Australia
    344Coins
    Thx @Thanos. Just what I have been looking for.
