amc1.5 connection problem
Discussion in 'Miscellaneous' started by Jeroen, Mar 1, 2009.
  1. Jeroen
    Jeroen DoctorXeno
    Holland
    - 70Coins
    Hi Thanos,
    I have orderd a Digitus like yours. I thought that the profilic was simular.
    Hope that this does the trick. Thanks for the help.
    I also had a digilink converter, but that one also did not work.
    gr. Jeroen
  2. 914tom
    914tom Member
    - 30Coins
    hallo
    i face the same problem.
    programming worked fine with my USB2SERIEL adapter, but in hyperterminal no connection can be established.
    22Mhz board clock.
    is your problem solved ?
    how?
    TOM
  3. Deleted member 4120
    Deleted member 4120
    hi tronic thx for help...
    I ordered a blue LCD ..
    and I read that it may be that one only has to adjust the contrast.
    and which one your a greater resistance is needed ... (Because it is very hot otherwise.)
    what a potimeter .. should I take the best?
    is there good? http://www.reichelt.de/?;ACTION=3;LA=5; ... 88bf3315eb
    thank you
  4. Deleted member 4120
    Deleted member 4120
  5. tronicgr
    tronicgr
    Just take any 10k Ohm potetiometer you can find. The only difference is that if you use a multi turn one you will have more accurate correction and it will stay put.
  6. Deleted member 4120
    Deleted member 4120
    okay i buy a 10k ohm potimeter :)
    (is it only for the contrast.)
    thank you tronic :thbup:
  7. egoexpress
    422Coins
    But a linear one. Not logarithmic ;D
  8. Deleted member 4120
    Deleted member 4120
  9. Frakk
    Frakk Active Member
    328Coins
    First of all, what is overheating? Is your potentiometer overheating for adjusting the contrast pin?
    Don't waste your money on high quality single or multi-turn potentiometers. Just get a cheap trimmer pot, set it and forget about it.
    If you have extra resistors, you can play with some combinations between the range of 1K-10K.
    My guess is that you forgot to mention something very important... Maybe your LCD has a backlight, and the whole screen is heating up???
    If I guessed right, just put a 100-200 ohm resistor in series with the light: (+) -- RES -- A)Light(K -- (-)
  10. kopex
    kopex New Member
    I think he is talking about overheating of the LCD screen, because of the background light.
    it cannot be soooo hot, so i think that 100-200 ohm really should be enough.
    For the contrast just try a very cheap trimmer with 10k. this worked for me!
  11. Deleted member 4120
    Deleted member 4120
    I'm talking about the
    I just want to make sure .. have a mind to order no 100 times.
  12. Deleted member 4120
    Deleted member 4120
    he says it may be that if it has the lcd display with a backlight makes it heat up then.
    and I want to prevent it ... with a 20ohms-50ohm resistance as he describes it.
    if I need a meter for optimizing the contrast set I do not know yet.
    it may be that I need one, but it may also be that I do not need.
    is always different.
  13. kopex
    kopex New Member
    korrekt! :)
  14. Deleted member 4120
    Deleted member 4120
    people what can be?
    If I stick purely to the first USB adapter in the flash and then the input power supply is nothing and nothing is lit.
    I make out the USB adapter and back in, then light up the LEDs and the LCD.
    and if I then put pure USB adapter into the gaming input hears the small LED light on at me!
    ... please help
