AMC1280USB Motion Simulator Controller
Discussion in 'SimTools compatible interfaces' started by Thanos, Jul 6, 2017.
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,832Coins
    DC motor, 6DOF
    @Gabor Pittner ,
    I don’t have any experience with sabertooth config.
    Is there any other way in your setup to deal with the motor acceleration than the controller PiD ?
    Asking because that’s the case with ac setups and servo setups where you have to find a sweet spot for a proper acceleration
  2. Thanos
    Electronics Engineer
    United States
    2,907Coins
    Do you have the Sabetooth setup as Linear or Exponential? I strongly suggest setting it to Exponential so there will be not much drive near the target position. ( on Sabertooth 32A this is setup via dip switch 5 ).
    Thanos
  3. BlazinH
    16,687Coins
    Or you can take it a step further by setting up a custom throttle curve using Describe software giving you total control of the process.
  4. Gabor Pittner
    Gabor Pittner Active Member
    Szekesfehervar Hungary
    1,396Coins
    It has analog HAL sensors
  5. Gabor Pittner
    1,396Coins
    If I remember well I set it to exponential, but I have to check it. Thank you.
  6. Gabor Pittner
    1,396Coins
    No I can set motors acceleration in AMC board PID settings only.
    In analog control to sabertooth.
    By the way the I integral and D derivative values don't affect anything of analog mode with sabertooth. I tried to change 0-300 both values. Maybe with D changing I get some noise while motors keep position but no else happen.
  7. Gabor Pittner
    1,396Coins
    Hi @Thanos , I noticed when P proportional value is relatively low under 15, the first and second motors start moving some tenths of a seconds lately than the other four. You can see in my video on heave, motors are out of synchron.
    Watch from 0:15 seconds when I slowly move heave slider. Is that normal?
  8. hexpod
    berlin
    7,832Coins
    DC motor, 6DOF
    I would advise the digital upgrade
  9. Gabor Pittner
    1,396Coins
    I use this type of sensors: Link
  10. hexpod
    berlin
    7,832Coins
    DC motor, 6DOF
  11. hexpod
    berlin
    7,832Coins
    DC motor, 6DOF
    Double check that your PID is same for all motors.
    Reselect the values and re-apply for all 3, p I and d
    It’s easy to make a mistake there with the rotary selector and apply the changes only for one motor
  12. Gabor Pittner
    1,396Coins
    Yes I know that, I've made mistakes several time because of that. You couldn't even think how many times I checked :roll
    Morover I tried the 1st and 2nd motors P values to higher than tho others. But it was bad idea :)
    When I set P values up to 50-60 or more, the motors move the same time together. But its too agressive and more jerky.
  13. BlazinH
    16,687Coins
    The hall pots he's using are 12 bit also and I believe the AMC has a 12 bit ADC? If so I don't see a huge advantage in switching to 12 bit encoders when not using more than one revolution. As a matter of fact the halls he's using are 180 degree so the resolution he has now is double what the encoder would be not considering hysteresis.
  14. BlazinH
    16,687Coins
    Increasing the PID's "I" setting should help alleviate motors that are lagging behind if its working properly.
    "I" is pretty simple to implement in code so I don't think such an important omission should happen.
  15. Gabor Pittner
    1,396Coins
    Unfortunately PID I setting doesn't change anything in my case. It doesn't matter if its zero or even 300... nothing changes.
  16. BlazinH
    16,687Coins
    Did you try increasing "I" with no "D" when using a low "P" value? You should notice the motor reaching the set point sooner than with no "I".
  17. Gabor Pittner
    1,396Coins
    I will make a try, but If I remember well I've tried several different configuration, and only PID P value modified the behavior of motors motion I and D did nothing...
    I will try to make a video of that.
  18. hexpod
    berlin
    7,832Coins
    DC motor, 6DOF
    Do the heave loop test with HeXpod software. (Loaded)
    Low speed big oscillations. Post it here
  19. Gabor Pittner
    1,396Coins
    Such a good idea, I will do that. :thumbs
  20. hexpod
    berlin
    7,832Coins
    DC motor, 6DOF
    I can only say from experience, having tried them both, I’ve experienced more stability with SSI.
    Also, kinematicwise, depending on geometry, sometimes there is an advantage of using 360’s as the curse greater than 180deg can be needed
