AMC1280USB Motion Simulator Controller
Discussion in 'SimTools compatible interfaces' started by Thanos, Jul 6, 2017.
  1. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    Hi thanos the controller is out of stock any idea when will it be restocked??
  2. Thanos
    Electronics Engineer
    United States
    2,917Coins
    I'm expecting more parts to be delivered today. It should be back in stock later today. Joint the waitlist to get notified so you won't miss it again...
    Thanos
  3. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    Hi thanos I did not know that the controller comes with PT actuator can I cancel the order? Order number 156370
  4. Thanos
    United States
    2,917Coins
    No problem, Shao has a small stock of these to save on separate shipping fees. Just make sure he will include a controller in the order.
    Thanos
  5. DoctorD
    DoctorD New Member Gold Contributor
    Engineer
    Brisbane, Australia
    - 2Coins
    AC motor, 6DOF
    Hi guys,
    I had a very similar problem with my worm gear/AC motor setup until recently. Jerky as hell in small movements, especially when unloaded/downwards.
    Achieved a HUGE improvement by going into the VFD settings and upping the minimum voltage values (from 0.7V to 8V) and decreasing the minimum frequency outputs to as low as possible (0.5hz from 2Hz).
    There is still a tiny bit of mechanical backlash (almost un-noticeable, even for my 250mm gear output arms) but for the most part it has been the difference between 'notchy' movements and smooth "clear-weather" flying in air sims and the feel of car tires/suspension in driving sims.
    I really hope this helps
  6. Thanos
    United States
    2,917Coins
    The AMC-AASD15A controller is back in stock again:
    https://www.tindie.com/products/tronicgr/amc-aasd15a-servo-motion-controller/
    New firmware under beta will be released in stable as soon its fully tested. For the brave one you can give it a try here: https://github.com/tronicgr/AMC-AASD15A-Firmware/tree/master/Beta_Firmware
    ======= enc_6dof_AMC_AASD15A_v2_06 BETA =======
    release date: 09/23/2019:
    -Added support for 2525 leadscrew (25mm/rev).
    -Added support for different reduction belt ratios (1:1, 1:1.5, 1:2)
    -Added support for Platform check. Will Park active actuators if any of them fail.
    Selectable by Menu Entry ON or OFF.
    -Fixed a bug saving stroke and direction of Servo7.
    -Attached the speed of blinking of the Standby LED on the ButtonSpeed setting.
    Thanos
  7. Thanos
    United States
    2,917Coins
