value1
American Truck Simulator 2.0.2.1
SimTools game plugin for American Truck Simulator
  1. Mpmo
    Mpmo Member
    United Arab Emirates
    1,289Coins
    ahh will try it, how do you capture?
  2. dhrto
    dhrto New Member Gold Contributor
    Netherlands
    - 45Coins
    3DOF, SCN6, Motion platform
    Make sure the game is running, with the game engine and game manager running as well. It needs to be active in the game manager (blue). Then go to the game engine > select tools (bottom button on the left) > press 'tuning center' button.
    Tuning center will popup in a new window. Press 'Capture Max Min' in button. Now go drive around and in the mean time the top row (green) should show changing numbers if the plugin is getting telemetry from the game.
    Also refer to page 73 of the simtools user manual v1.2 for a more in depth explanation.
    154,711Coins
    +11,212 / 57 / -2
  4. Mpmo
    Mpmo Member
    1,289Coins
    oh sorry it was my bad. I installed the game somewhere else lol, patched it in the right directory and fixed. Thanks @dhrto
  5. Toren454
    Toren454 New Member
    139Coins
    Hello I have been playing ETS2 and ATS with motion for 2 years now but from last monday I have no motion in my rig for those games I tried my rig with asseto corsa and all was fine.I am on 1.36 in Ets2 and 1.37 in Ats and no motion at all.Do anybody know what might be the problem?
  6. dhrto
    Netherlands
    - 45Coins
    When did you have motion last? A couple of things come to mind:
    - did you press ok when the game says something about advanced sdk? (right after the intro movie, before you load your profile). I noticed when you press escape instead of clicking ok, there's no movement
    - did you maybe change your language/region setting in Windows? It could be that the decimal symbol got changed from . to , or the other way around, resulting in the values in the tuning center need to be 1000x smaller
  7. dhrto
    Netherlands
    - 45Coins
    Could not edit my last message (only 1 minute window?)
    I have played both ATS and ETS2 this week (same versions as you) and have motion just fine.
  8. Toren454
    Toren454 New Member
    139Coins
    Thank you for the tips .
    I had motion a week ago.I press ok after intro I have the . in Region settings the Game manager show game running but I have no motion in Ats or Ets2. It looks like all values in tuning center are 0
  9. dhrto
    Netherlands
    - 45Coins
    Hmm that's really strange. Have you tried unpatching and repatching? Any other updates / changes in between? (like windows updates / moving game to another install location)
  10. Toren454
    Toren454 New Member
    139Coins
    Yes I tried to repatch both games but no motion.I have not had any updates of window 10.I do not understand what have happend all other games work just fine
    154,711Coins
    +11,212 / 57 / -2
    Any difference if you temporarily disable your firewall and anti-virus?
  12. dhrto
    Netherlands
    - 45Coins
    @Toren454: Just following up. Have you had any success in getting it to work again?
  13. Toren454
    Toren454 New Member
    139Coins
    I been buzzy latly but I tried it again today and I turnd off my Firewall as noorbeast said and YES I got motion back :).I have very limited knoelege of Computers but I wonder if it is posible to make the game work with motion and also have some firewall protection Sorry I am lost in all this settings. BUT I HAVE MOTION AGAIN
  14. noorbeast
    154,711Coins
    +11,212 / 57 / -2
    Glad you pinned it down, you likely need to add an exception to your firewall, there are plenty of howtos, just do a search: https://duckduckgo.com/?q=Firewall+add+exception&t=ffcm&atb=v171-1&ia=web
  15. De Baas
    De Baas New Member
    Alkmaar
    302Coins
    3DOF, Motion platform
    I have a question about american truck simulator and euro truck simulator 2.
    Both games i had it working perfectly with motion (i did make a motion profile and used the max-min setttings to fine tune for both games). I played both games a couple of times and suddenly it's stop working fine, my simulator goes wild with every movement and shakes. This happend all without any updates from the games or windows or any changes i made. I try with both games to unpatch and repatch the plugin but the motion is sick from now on. Any idees?
  16. noorbeast
    154,711Coins
    +11,212 / 57 / -2
    Obviously something has changed. Do all other games still work OK?
  17. dhrto
    Netherlands
    - 45Coins
    I had this a while ago. I don't know the exact cause, but it seemed in my case it had something to do with the decimal symbol in Windows. I had to change the min/max values in the tuning center from 1,000 to 1.000 (or the other way around).
    What do you see in the values in tuning center when doing a new capture?
  18. noorbeast
    154,711Coins
    +11,212 / 57 / -2
  19. De Baas
    De Baas New Member
    Alkmaar
    302Coins
    Oke, thanks for the answers. the thing DHRTO said changing the max-min values helpt. I only not understand why suddenly the values are changed that much, without any changes from my side or any updates.
    But i make the numbers a lot higher and now it's oke again.:thumbs
  20. De Baas
    De Baas New Member
    Alkmaar
    302Coins
    Yes, i think you are right. Today i tried ETS2 again and totally no motion since yesterday after i get it to work again with max-min settings. I tried the language settings with the emulator and now i have perfect motion again. I restarted the game multiple times and keeps working, so this is the solution for me. Thanks!
