Amicos 3DOF from 3DPrinter Parts
Discussion in 'DIY Motion Simulator Projects' started by Jon Amico, Jan 26, 2026.
  1. Jon Amico
    Jon Amico Active Member Gold Contributor
    573Coins
    Help! Lol Anyone have the .STL file for this Hall sensor Mount that fits the 24v 250 watt Wheel Chair Motors?
    I Broke one of mine and lost the file in my laptop hard drive crash and I cant seem to find it anywhere on thingiverse or the 3D Printers section here..
    I could have sworn I found it here..
  2. Jon Amico
    573Coins
    Found it.. (Attached). I made it 4mm Thick and I will print 100% infill! I did have a more recent back up of my hard drive.. It was just hard to locate in my mess of a place.. lol
  3. Jon Amico
    573Coins
    Monitors arrived in 1 day... lol Thanks Amazon! I hate that I give them so much money but damn they are fast..
    But more money spent.. i was running monitor out to hdmi on the old Monitors but these have Monitor cable ins.. One is too short. Had to overnight a longer one for the 3rd monitor..
    Looks way better and will perform better no doubt..
  4. Jon Amico
    573Coins
    Plugged in every thing and hit the power to the motors and I got vigorous back and forths on motor 2 again.. i tried messing with all the parameters but couldn't get it to stop.. Sooo I switched the positive and negative back to how they were originally, and now that motor just spins again..
    I got Motor 3 working and hooked it to the seat.. It shakes pretty good during transition.. is this normal for SMC3 and gets better in Simtools or do I need to keep screwing with the parameters in the SMC3Utilis v1.01?
    154,849Coins
    +11,228 / 57 / -2
    You need to sort SMC3 before messing with SimTools.
    I am not sure how you got the SMC3 values in the video.
    I would suggest trying Fpwm at 25 and expect Kp to be in the range of 250-500. These are the SMC3 setup steps:
    Follow the steps below to reduce the risk of damaging anything: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    1. Disconnect the motor power supply
    2. Make sure Simtools is not running – we’re not ready for that yet!
    3. Wire up the Arduino (with SMC3 installed) to your H-Bridges and connect to your computer via USB
    4. Run the Windows SMC3 Utility software and make sure it communicates with the Arduino (There is no need to set baud rates, they are not configurable)
    5. Set the Kp, Ki, Kd, PWMmin, PWMmax, PWMrev to 0 for ALL motors (This will make sure the motors don’t move)
    6. Set Clip to 255 (you need to do this first) and Limit to 255 (This will give you plenty of margin if something goes wrong while setting up)
    7. Turn on the power to your motors – nothing should move at this stage!
    8. Set Kp to about 400
    9. Now slowly, increase PWMmax… at some point the motor should start to move. When it does check the “Green” feedback line is moving toward the “Blue” target position.
      • If it is then that motor and feedback is wired correctly - proceed to test other motors.
      • If it is moving away turn off motor power immediately (or quickly reduce PWMmax again). In this case you need to either reverse the wires to the motor being tested –OR– reverse the +5V and GND wires to your feedback pot for the motor being tested (do not do both). Restart the test from the beginning.
    10. Do the above for each motor
  6. Jon Amico
    573Coins
    Lol Yeah those settings were me just messing around trying to get the jittering out.. Zero All.. Lots of it was slop in my belt or Pot mount.. They were weak and I printed new solid 4mm. It helped a little but was desperately messing with settings..
    After some chats with Gpt I ended up with this.
    The A and C motors are working ok. But B still just spins till Max and cuts off.. I tried Switching B with its Pot to The C spot and worked OK and the C Moter does the same in B spot.. Im leaving them in those spots now.. I then tried switching the Motor controllers to see if there was a problem there... Same issues.. Im still in Mode 1 as nothing worked in mode 2..
    That damn B Spot!
  7. Jon Amico
    573Coins
    Oh and the B motor just moves no mater if its in Monitor or any other of the Movement Out Modes. Moves fast to Max limit after giving it power or moving the green line to center and clicking ON..
    154,849Coins
    +11,228 / 57 / -2
    I can't really read the settings in that image, but the graph at least looks closer.
    With B are you sure the pot is properly centered when the rig is level and at rest? You can disconnect power to the motor and check by observing the graph.
  9. Jon Amico
    573Coins
    When there is no power 24v I can spin the motor shaft / pot and I can get the green line centered. The arms are not connected to the cockpit at the moment. When I turn on the 24v is spins way faster than the other two till it hits max and stops.
    It shouldn't be getting any power. I have it on Monitor.. But the same one Sine, Movement or whatever..
    154,849Coins
    +11,228 / 57 / -2
    Check the pot is not 180 degrees out.
    If not I suspect a hardware fault so swap parts out to narrow down where.
  11. Jon Amico
    573Coins
    That would have been awesome if the Pot was only off 180.. I tried the green line centerd and then again 180 centered again.. Same deal.
    I swapped the motor controllers and same deal.. So its not the controller unless both of them dont like controlling 2 motors?!
    I unhooked the argentina wires to that motor.. the motor won't spin.. if I hook the A1 digital wire back I can see the green line again, Hook up pin 4 Nothing, 4 and 5 Spin..
    I tried reversing the motor in the SMC3 code.. maybe the motor spin the other way, but still moves till Max..
    Maybe I need one more controller??
  12. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    Does the pot on that motor run correctly if swapped to a different control board? Or alternatively does a different pot behave the same way with that controller?
  13. Jon Amico
    573Coins
    I did try the Pot and same motor on the other board so its seems to work but havent tried the Pot on a different motor..
    I will take the Pot off motor A and try it on B.. i am a feeling that if I used a third controller, it would be fine... But damn i dont wanna order another one from Ali Express.. i might try to put that one on an IBT2 if its not the POT.. But then mode one might not work with these controllers?!
    Well at least I have 2 more things to try...
  14. Jon Amico
    573Coins
    Im lost, but all 3 motors are working now.. After putting the wires back from the controller swap and testing the 180 Spin I came home ready to test Motor B on the 2nd motor contoller in Spot A because all 3 Pots were functioning correctly. I decided to try switching the positive Negative on motor out to Motor B on the number 1 Controller... Low and behold the thing didnt move when powered up!! It worked!! moves good on the out modes... WTF?! Ive swapped these multiple times but I guess never when everything was right or on?! I have no clue why Motor B works again but it does...
    Soooo
    Mode 1, Motor B has positive/Negative Reversed on the number 1s Controllers B out.. All 3 motors working in SMC3 Monitor Utility Program. Time for SimTools!!!
    After Work tomorrow....
  15. Jon Amico
    573Coins
    Well the thing moves... It Jumped off the Front pivot so had to set those set screws... Lucky I didnt break anything. Not even sure how it did it..
    I Moved to the 70mm CTC hole on my Motor Arm. I Also had to make woodruff key slots and keys for the 2 front motors. The Lock washer was not Enough to hold those guys.. Traction loss holds for now So Ill do that later if needed.
    Nothing a drill, Dremel and Files cant tackle..
    And now Im a little concerned about the thickness of the arms... I might have to make new ones...
  16. Jon Amico
    573Coins
    SimTools is up and I think I'm about ready to try an in game to see how bad the settings are... Here are the SMC3 Settings Im using..
    Motor 1 and 2 (A&B), FPID / 1 , Kp = 400, Ki = 0, Kd = 0, Ks = 1 , Fpwm = 25kHz, Power Min = 30, PWMax = 210, PWRev = 150 , Max Limits 50, Clip Input 160, Dead Zone 0
    Motor 3 (C), FPID / 1 , Kp = 400, Ki = 0, Kd = 0, Ks = 1 , Fpwm = 4kHz, Power Min = 5, PWMax = 200, PWRev = 205 , Max Limits 50, Clip Input 160, Dead Zone 0
    All working strong with woodruff keys installed on all 3..
    Time to finish off simtools settings, Think I finally figures out traction loss having to be on Extra1 and Testing Extra1 is in the "More" Tab that pops up after you turn on Testing... Took a min to figure that out... lol
  17. Jon Amico
    573Coins
    More Problems.. The A motor became loose and I couldnt get rid of the jitter.. I guess the 3D Printer Sized K Channel is not strong enough for the motors with only 2 mount Bolts... Kind of was expecting it but gave them a shot...
    It was moving all over the place after 2 test runs.. Im not sure I even got my Pitches and motor directions correct.. But I do have movement...
    Before Bracket.
  18. Jon Amico
    573Coins
    The bracket now makes use of all 4 Motor Mount Holes ol the motor.. Now has 4 Anchor Nuts.. Much More Solid..
  19. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    Just something for consideration, on my rig I used an adjustable alloy bar between the motors to help make them part of the rigs structural rigidity:
  20. Jon Amico
    573Coins
    That was my first thought but when im low in the front I have no room.. The pedals and Bass Shaker make that impossible.. I'm cutting it close..
    Thanks for Tip!! Appreciate you checking in!!
