Amicos 3DOF from 3DPrinter Parts
Discussion in 'DIY Motion Simulator Projects' started by Jon Amico, Jan 26, 2026.
  1. noorbeast
    154,849Coins
    +11,227 / 57 / -2
  2. Jon Amico
    Jon Amico Active Member Gold Contributor
    573Coins
    I have a 15 amp fuse in the main AC input. Before the terminal block to power supplies and other stuff. That fuse never blew.. Or Maybe it is a 20 amp? I need to double check that and do the blow test you linked… Should I have additional fuses inline on the 24V DC between the motors and controllers or between the power supply and controllers? Or should my main fuse should have blown?
    154,849Coins
    +11,227 / 57 / -2
  4. Jon Amico
    573Coins
    That link shows a diagram with 8GA + wire and 10GA Negative wire… Overkill? The controllers can’t even receive 10GA and barely a 12 GA wire.. I’m going With 12 GA to the motors because it’s a similar (Not Smaller) than the Gauge to the motors from factory. But larger than the 14GA I was using… I did upgrade to 10GA with inline fuses from the 24v power supplies to the Controllers. (I had to trim some copper wire threads off the 10GA to fit the controllers)
    The Image also shows a 30 amp fuse?! I Can’t blow the Main AC with a 5 Amp fuse… Holds strong in game with 2 motors, fans, bass shakers and pedal shakers.. Traction loss is still out as I’m waiting on a new controller..
    I have 7.5 amp fuses inline on the positive DC line before both controllers… Im only able to test the one with both front motors on as of now. But need to get smaller fuses if I want to test a blow out I guess… Seems impossible to blow out a fuse when I want it to blow…
    But still after long races the motors are barely warm to the touch.. Nor is that controller for the 2 motors… All I really learned is turn the simulator off after a power outage…. And don’t mess around! add fuses…
  5. Jon Amico
    573Coins
    I added the seatbelt Tensioner that @Misanthrop mentioned in his awesome build thread Here: https://www.xsimulator.net/communit...ous-racing-sim-project-3dof-surge-2xtl.18516/
    Took a few days to print the beast with my CR10 Printer.. I did 50% infill. The servos are a little louder than I would hope but erased with headphones.. My sim is a little squeaky anyway so headphones are best...
    Overall a really nice addition for not a huge cost. If you have a 3D Printer anyway...
    All the goods and and info here at Marvins Awesome iRacing App https://mairapp.com/
    Big thanks to Marvin. All he asks for is a donation.. Buy the guy a coffee already!
  6. Misanthrop
    Misanthrop Active Member
    1,024Coins
    Suits your rig really good, hope it will not break where it is attached to the rig, there is an designflaw. He changed the complete design in his v2 version because of this.
  7. Jon Amico
    573Coins
    I added vertical supports to where the lower mount holes lined up with the top mount holes.. It has a good amount of surface to sit on and feel it should be OK at the levels its at.. if it breaks, I'll print the new one.. ;) How new? just downloaded these files the other day?!
    But all good, either way, i'm stoked! Working for now...
  8. Misanthrop
    1,024Coins
    He didnt puplish the v2 version till now, first he wants to test it more. The design is similar to mine. Less Supports needed and far better print orientation to improve the stiffness.
