Arduino and X-Sim
Discussion in 'SimTools compatible interfaces' started by HammerHead, Oct 30, 2010.
  1. shomi87
    shomi87 New Member
    Serbia
    58Coins
    Hi everyone. I am also trying do it with arduino.
    I had a little time and play with PID library. I write code that simulate controlling one motor. I change PID library from Arduino site. I think this is good code. What are you think about it?
    Code:
    #include <PID_v1milos.h>
     * PID Basic Example
     * Reading analog input 0 to control analog PWM output 3
    //Define Variables we'll be connecting to
    double Setpoint, Input, Output;
    int i;
    int Gforce = 0;
    int Gforce1 = 0;
    int Gforce10 = 0;
    int Gforce100 = 0;
    PID myPID(&Input, &Output, &Setpoint,2,0.05,0.25, DIRECT);
    void setup()
      //initialize the variables we're linked to
      Input =90;
      Setpoint = 90;
      //turn the PID on
      myPID.SetMode(AUTOMATIC);
      Serial.begin(9600);
    void loop()
      if(Serial.available() > 0)
         char tip;
         tip=Serial.read();
        delay(2);
        int Gforce100 = Serial.read()- '0';
        delay(2);
        int Gforce10 = Serial.read()- '0';
        delay(2);
        int Gforce1 = Serial.read()- '0';
        if (Gforce1 < 0) { Gforce = Gforce10 + 10*Gforce100; }
        if (Gforce1 < 0 && Gforce10 < 0) { Gforce = Gforce100; }
        if (Gforce100 < 0) { Gforce = 127; }
        if (Gforce1 >=0 && Gforce10 >= 0 && Gforce100 >= 0) { Gforce = 100 * Gforce100 + 10 * Gforce10 + Gforce1; }
        if(tip == 'p') //simulate reading potentiometer value with manual inputting potentiometer value in console in format pxxx
            //i=0;
            Serial.println(InputX:  );
            Serial.println(Gforce);
            Input=double(Gforce);
        if(tip == 's') //simulate setting new setpint value from PC with manual inputting  value in console in format sxxx
            Setpoint=double(Gforce);
            Serial.println(Setpoint:  );
            Serial.println(Setpoint);
      //if(i<10)
      myPID.Compute();
      while((Input<Setpoint-1 || Input>Setpoint+1) && Output!=0.0)
        Serial.println(Input:  );
        Serial.println(Input);
          myPID.Compute();
            Serial.println(output: );
            Serial.println(Output);
          if(myPID.smer==1) // myPID.smer tell us in what direction motor should turn
            Input+=Output/10; //simulate motor turning and potentiometer new value
            else
             Input-=Output/10;
            Serial.println(Direction);
            Serial.println(myPID.smer);
            Serial.println(----------------);
    when you read potentiometer value you should MAP it from 0 to 180.
    same thing you should do with values that PC sends to Arduino.
    Here is my modded library :D
    How i could send data from arduino via x-sim to game???
  2. hraanan
    hraanan New Member
    1Coins
    I have problems with how to define the arduino in x sim. I can't see the com of the arduino in the list!!
    if anyone can help I will be very happy.
    tnx
    hraanan
