Arduino code for steppers?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by jackon680, Apr 23, 2014.
  1. Ivan Zaharov
    Ivan Zaharov Member Gold Contributor
    Industrial repair CNC
    Latvija
    219Coins
    2DOF, AC motor, Arduino, Motion platform, 6DOF
    Hello. I do not know what to write in Sim Tools Engine. Startup output..?, Shutdown output..? BitRange ?
  2. Harry King
    Harry King Member
    224Coins
    3DOF, Arduino
    I was looking for some help with the code and the wiring schematic. I am using a UNO with motor driver DQ860MA motor Drivers for 4 stepper motors.
    I am not a coder and I am at the beginning of my project.
  3. EleaSkipper
    EleaSkipper New Member
    - 45Coins
    hello everybody , I'm trying to setup my 2 Steppers to the Simtools Engine using the Arduino. the Code up there it work with one Stepper using AccelStepper.h , but I cant figure out how to make it work with 2 Steppers , can someone help me with this pls ?
  4. AndreFilipe
    AndreFilipe Andrefly
    businessperson
    Brasil
    - 55Coins
    3DOF, DC motor, SCN6, SimAxe, Arduino, SimforceGT, Motion platform, 6DOF
    Hi, can you help me with something? I want to use stepper motor for testing, I found this code ai for arduino but I don't know how to define the output there in simtools (R<Axis1a>R<Axis1a>L<Axis2a>L<Axis2a>F<Axis3a>F<Axis3a> V<Axis4a>V<Axis4a>~*) like the one I was using on the model aircraft servos what should I put there for simtools to send to the engines?
    Thanks!
  5. Billel
    Billel Member
    195Coins
    hello guys,
    a newbie here, i've been diging aroung this forum for the past two weeks, and the amount of informations i gathered are enormous, but i still can't my head around this stepper motors this, i mean linear actuators based on dc motors are easy to set up and control (thanx to SMC3), but how do you set your limits for the actuator if you are using stepper motors (SMC3 works with those as well ?)
    154,580Coins
    +11,190 / 57 / -2
    Steppers are not impossible but are uncommon when you have so many cost effective tried and tested AC and DC alternate options, including DIY actuators: https://www.xsimulator.net/community/faq/diy-linear-actuators.248/
    Steppers can have a lot of vibration, noise, and can lose torque on higher speeds, so actuator speed is limited.
    But if you are interested in the Stepper path check out @Lebois thread: https://www.xsimulator.net/community/threads/srt100-stepper-motor-actuators.16261/
  7. Joe Cortexian
    Joe Cortexian Active Member Gold Contributor
    1,616Coins
    If it were up to me I would extract the serial protocol code from smc3. This requires some work but is certainly doable. There are 3 or 4 subroutines you need and of course you need to understand what they do. Aka this input sets the position value.
    smc3 is a fantastic piece of work but not really set up to be flexible.
