Tutorial Arduino RevBurner driving a tachometer.
Discussion in 'DIY peripherals' started by jamesdio, Oct 11, 2014.
  1. Tonantsa
    Tonantsa New Member
    Finland
    81Coins
    SCN5
    For example Dirt Rally.
    The problem is to get HEX value ten times greater and because they are not decimals, formula math * 10 doesn't work.
  2. value1
    14,237Coins
  3. Subash
    Subash New Member
    - 8Coins
    Hey Dude I am So suprised with your work
    I Have a Arduino Uno Can you tell the me steps to set a tachometer and some leds for my Dash project
    What is the game your using for this tachometer................and is there are any plugins to be added
    Thank You
  4. Subash
    Subash New Member
    - 8Coins
    Hey what is that Game dash Software Can you send me the link
  5. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    出色的工作,谢谢。大拇指
  6. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    :thumbsExcellent work, thank you.
  7. RacingMat
    21,082Coins
  8. Aris
    Aris New Member
    Athens - Greece
    124Coins
  9. kieranjones39
    kieranjones39 New Member
    202Coins
    Hi, just tried building this up but I keep getting "the interface connected to com3 is not detected" I have confirmed my arduino is on com3 and have adjusted the baud rate to 19200, any ideas? Thanks
  10. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
    2DOF, 3DOF, DC motor, AC motor, SCN5, SimforceGT, Motion platform, 4DOF
    Please describe your situation in detail with screenshots or videos.
  11. kieranjones39
    202Coins
    Thanks for the reply, I will try and sort some screenshots out shortly.
  12. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
    Here are new videos.
    The needle fluctuation still exists.
    I'm going to add smooth filter code to remove needle jitters.
  13. Tonantsa
    Tonantsa New Member
    Finland
    81Coins
    SCN5
    Tachometer doesn't work anymore and I have no idea how to fix that :(
    Arduino connects Game Engine and Game Dash normally but tachometer doesn't do anything.
    Jamesdio, could you measure some voltages: the one that comes from Arduino and actual tachometer signal. I could compare them to my values and find out something :think
    Both Arduino and tachometer are cheap China stuff so the problem could be anywhere.
  14. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
    Hi Tanatsa,
    Had your tachometer worked then suddenly stopped working?
    The voltage levels are variable associated with RPM value.
    The one will be between 0V and 5V on Arduino signal. (pin9 on the diagram)
    Another will be between 0V and 12V on Tachometer signal. (green/white line on the diagram)
    These values will be changing as rpm is going high and low.
    Hope this helps.
  15. Tonantsa
    Tonantsa New Member
    Finland
    81Coins
    SCN5
    Now I feel ashamed :roll
    I had wrong settings in Gamedash. Managed to get it work again. Nothing wrong in schematics.
  16. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
    Good to hear that It's working. :)
  17. Tonantsa
    Tonantsa New Member
    Finland
    81Coins
    SCN5
    I have huge delay in my tachometer (cheap ebay stuff). Is there any ways to remove lag and get it working like Autometer :cool:.
    Is the problem Arduino sketch related or is it tachos fault?
    Any ways to "tune" the needle :roll ?
  18. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
    Does your tachometer work like this video below?
    If yes, It's the problem because of the slow servo motor of the tachometer.
    I don't think it can be fixed by modifying arduino source code.
  19. Cvetan Cvetanov
    Cvetan Cvetanov Member
    Teteven Bulgaria
    1,462Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF
  20. Masilicondrio
    Masilicondrio New Member
    Programmer
    Uruguay
    186Coins
    How much current draw the tachometer?
    Its possible drive them with ULN2003APG (Max 500ma) transistor?
    Have a 7 segment led connected and 1 pin left in ULN2003 :)
