Tutorial Arduino RevBurner driving a tachometer.
Discussion in 'DIY peripherals' started by jamesdio, Oct 11, 2014.
  1. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
    2DOF, 3DOF, DC motor, AC motor, SCN5, SimforceGT, Motion platform, 4DOF
    There is very little current for the signal.
    I think you can use ULN2003.
  2. MAYA One
    MAYA One Member
    china
    468Coins
    2DOF, SCN5
    Thank you so much !!
  3. Masilicondrio
    Masilicondrio New Member
    Programmer
    Uruguay
    186Coins
    Im using arduino nano and only 1x 2.2K resistance and 1 diode...
    Its alive!!!! only with 5v signal :O
    Working with Project Cars but have problems with Dirt Rally Plugin :(
  4. MAYA One
    MAYA One Member
    china
    468Coins
    2DOF, SCN5
    Hi @jamesdio. This tachometer code can be used in X-SIM?I can't write code:grin
  5. Meawto
    Meawto Sorry for bad English ;'(
    Thailand
    - 336Coins
    hi can you help me to driving a speedometer with gamedash
    i'm very poor in coding. now i use your code with my tachometer. its work very well !!
    can you help me for this speedometer
    thanks
  6. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
    sorry for the late reply.
    Yes, you can use any transistor for this application.
  7. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
    Does your speedometer work like tachometer which works with PWM signal?
    I would like to know the specification of your speedometer.
  8. Meawto
    Thailand
    - 336Coins
    i got it from my friend. have nothing except wire (has 1 wire for signal) i think its works with PWN signal like tachometer
  9. Meawto
    Thailand
    - 336Coins
    I have tried coding by use your code and the gauge are works fine on 1 gauge standalone
    but i still have some problem when i run 2 gauges (tacho&speedo).
    the gauge can run only one (in my video speedometer run,when tachometer was crash)
    can you help me :)
    Code:
    Arduino code for simple rev. burner
    //    This code is emulating the signal of ignition coil.
    //     ex) 4 cylinder, 4-cycle engine. (2 combustion cycle/rev.)
    //     1 rpm = 0.5 combustion cycle/min.cylinder = 1/120 combustion cycle/sec.cylinder.
    //     => 1/120 Hz/cylinder (Combustion cycle = signal for ignition So, 1 combustion cycle/sec. = 1Hz)
    //     => 1 rpm with 4 cylinder = 1/120 Hz/cyclinder * 4 cylinder = 1/30 Hz
    //     => 1 RPM = 1/120 hz/cylinder
    //    Following the formula above, Hz vaue per 1 rpm would be..
    //    * 2 cylinder = 1/60 Hz
    //    * 4 cylinder = 1/30 Hz
    //    * 8 cylinder = 1/15 hz/rpm
    // Serial parser for Interface - Output : M<Dash2>
    // Serial parser for Shutdown - Output : Z00
    // M : rpm              (16bit - hexadecimal output)
    // Z : clear            (to clear display and max rpm value)
    // for dashboard
    // Pin D3 : STB0 - strobe
    // Pin D4 : CLK - clock
    // Pin D5 : DIO - data
    int i;
    double cylinder = 4;           // cyliner count for Tachometer.
    double divideUnit = 120;         // 1/120 hz/(rpm * cylinder)
    double hzPerRpm = cylinder / divideUnit;
    int rpmtone;
    int pinTacho = 5;
    unsigned int rpm;           // holds the rpm data (0-65535 size)
    unsigned int rpmmax = 5000; // retrieves from rpm live with minimum setting on initialization and Shutdown - Output
    byte rpmdata = 0;           // marker that new data are available
    /////////////////////////speedo///////////////////////////////
    double speedhz1 = 98;
    double speedhz2 = 180;
    double hzPercarspeed = speedhz1 / speedhz2;
    int carspeedtone;
    int pinSpeedo = 6;
    unsigned int carspeed;           // holds the carspeed data (0-65535 size)
    unsigned int carspeedmax = 5000; // retrieves from carspeed live with minimum setting on initialization and Shutdown - Output
    byte carspeeddata = 0;           // marker that new data are available
    // INITIALIZATION
    void setup()
      // serial initialization
      Serial.begin(9600);
    ///////////////////////////////// Main Loop ////////////////////////////////////
    void loop()
      // read input data
      readSerialData();
      // generate signal and send to tacho
      tacho();
      // generate signal and send to Speedo
      Speedo();
    // Procedure: wait for complete trame
    void readSerialData()
      byte Data[5]={
        '0','0','0','0','0'  };
      // parse the buffer
      if (Serial.available()>4){
        Data[0]=Serial.read();                   // read command
        if (Data[0]=='Q'){                       // if carspeed data
          Data[1]=Serial.read();                 // store high byte
          Data[2]=Serial.read();                 //
          Data[3]=Serial.read();                 //
          Data[4]=Serial.read();                 // store low byte
          carspeed = NormalizeData(Data);
          carspeeddata=1;                             // we got new data!
            Data[0]=Serial.read();               // re-read command
        if (Data[0]=='M'){                       // if rpm data
          rpm = NormalizeData(Data);
          rpmdata=1;                             // we got new data!
        if (Data[0] == 'Z' ){                          // if Shutdown - Output
          Serial.flush();
      if (Serial.available()>40) Serial.flush();
    void tacho()
      if (rpmdata == 1) {
        // auto set max rpm
        // with filter of negative value
        // reported from 65535 to down in some games
        if (rpm>rpmmax && rpm<50000) {
          rpmmax=rpm;
        // rpm gauge gets messy movements below 100 rev.
        if(rpm>50000){
          rpm = 0;
        // Tacho range : from 0 to 10000, we will use 0 to 320 hz.
        //rpmtone = map(rpm,0,10000,0,320);
        rpmtone = (int)(rpm * hzPerRpm);
        // if hz. value goes over 320, then,,
        if(rpmtone > 320) {
          rpmtone = 333;
        //It is not possible to generate tones lower than 31Hz. For technical details,
        // see Brett Hagman's notes. (https://code.google.com/p/rogue-code/wiki/ToneLibraryDocumentation#Ugly_Details)
        if(rpmtone < 31) {
          rpmtone = 31;
        // For debugging.
        if(rpm>500){
          tone(pinTacho, rpmtone);
        else{
          noTone(pinTacho);
        rpmdata=0;
    void Speedo()
      if (carspeeddata == 1) {
        // auto set max carspeed
        if (carspeed>carspeedmax && carspeed<50000) {
          carspeedmax=carspeed;
        // carspeed gauge gets messy movements below 100 rev.
        if(carspeed>50000){
          carspeed = 0;
        // Speedo range : from 0 to 10000, we will use 0 to 320 hz.
        //carspeedtone = map(carspeed,0,10000,0,320);
        carspeedtone = (int)(carspeed * hzPercarspeed);
        if(carspeedtone > 320) {
          carspeedtone = 333;
        if(carspeedtone < 31) {
          carspeedtone = 31;
        // For debugging.
        if(carspeed>10){
          tone(pinSpeedo, carspeedtone);
        else{
          noTone(pinSpeedo);
        carspeeddata=0;
    // Function: convert Hex to Dec
    unsigned int NormalizeData(byte x[5])
      unsigned int result;
      for (int i=1; i<5; i++)
        if (x[i]>47 && x[i]<58 ){   //for xA to xF
          x[i]=x[i]-48;
        if (  x[i]>64 && x[i]<71 ){ //for x0 to x9
          x[i]=x[i]-55;
      result = (x[1]*16*16*16+x[2]*16*16+x[3]*16+x[4]);
      return result;
  10. it_pixy
    it_pixy New Member
    macau
    251Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, SimforceGT, Motion platform, 4DOF, 6DOF
    my gamedash show this sentence "the interface connected to con3 is not detected" What should I do?
  11. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
    I think you'd better check COM Port number on Dashboard output setting if the port number is correct or not.
  12. choclo
    choclo Member
    Vienna
    388Coins
    Could you please stop putting this things on here!!!
    My Shopping cart is getting bigger and bigger ;-)
    nice Job!
  13. it_pixy
    it_pixy New Member
    macau
    251Coins
    I was ardunio board, the output is COM3, I imported the procedures? To the ardunio COM3 normal work,
    But when I open gamedash, set the output is COM3, open the LFS, and then enter the gamedash settings, the phrase "the interface connected to con3 is not detected", then said to the ardunio COM3 BUSY,
    What should I do?
  14. Meawto
    Thailand
    - 336Coins
    any idea to make 2 gauges work together ? :(
  15. djgroove
    djgroove New Member
    Turkey
    236Coins
    Hi, I have a problem with GameDash 2.0. When I open the program I do the port settings and save but I can not setup the game name. I can not set any game to the program. And also interface output. What should I do ?
  16. alejandroads
    alejandroads New Member
    Unated States
    106Coins
    DC motor, Arduino
    Hi Guys!, there is possible to make PWM in output? I want to drive a fan whit the RPM, like wind effect whit speed , but using RPM for get PWM in output of Arduino.
    Cheers !
  17. noorbeast
    154,750Coins
    +11,196 / 57 / -2
  18. alejandroads
    Unated States
    106Coins
    DC motor, Arduino
    Hello noorbeast, I read that wind section, but I couldn't find any information or code using RPM for PWM output ,in that section show how to have wind effect but works whit speed data. Or maybe if somebody can help me whit a code for have PWM instead frequency signal (tone) in Arduino output.
  19. cazsan
    cazsan Member
    Programmer
    444Coins
    Hello there!
    I tried to replicate this and I'm facing weird issue I can't solve.
    If someone have any idea I'd really pleased.
    Here are the links to the parts I use:
    The tacho itself boots. I'm able to play with it using external buttons and such. That a good first step.
    I figured out that my power source voltage is correct (12V) but the others are wrong (7.4 instead of 2.5 to 3.0V)...
    I wired the Boost gauge too (based on youtube video from amstudio) and I'm getting also a weird buzzer sound, which makes it barely untestable.
    I uploaded a video on youtube showing what's happening for my rig : here.
    I also ordered a standard diode but It's slow shipping so I'm still testing with current zener diodes I have.
    If you might have some time to look at the following video. Thanks in advance.
  20. abs
    consultant
    Montreal
    765Coins
    3DOF, SCN5
    Hello, there is 2 type of tip120 Darlington (NPN and PNP). I am not sure what is the difference and you used . could you help?
    thanks
