Arduino UNO/Duemilanove 2dof firmware
Discussion in 'SimTools compatible interfaces' started by prilad, May 29, 2013.
  1. Nur
    Nur New Member
    36Coins
    2DOF, 3DOF, Arduino, JRK, 4DOF
    Что не так подключил подскажите
  2. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    Hi @prilad ... where can I find the original thread in the Russian forum ... as I can't log in under Google translation
  3. prilad
    Dubna, Russia
    9,663Coins
    3DOF, DC motor, Arduino, 4DOF
    Hi, Speedy!!! I'l try to check this
  4. prilad
    Dubna, Russia
    9,663Coins
    Speedy, whats wrong? You can login and than translate site via google translate.
  5. speedy
    Alexandria , Egypt
    7,943Coins
    No Google logs me out when translating the forum after log into the forum ... could it be a wrong settings in my Firefox ?
    edit : just give me the link to the thread and I'll translate it ... I just need to read some information about the F/W
  6. speedy
    Alexandria , Egypt
    7,943Coins
    I'm sorry if this is off topic ... it's the same here too ... when translating into Arabic ... Google loges me out
    @RaceRay ... Is this normal ? help please :sos
  7. insanegr
    insanegr !N$@n€
    Athens
    16,724Coins
    I'm sorry for topic too
    @speedy i had the same problem once and the only way i found to have a translation was to use Google chrome browser on those forums
  8. speedy
    Alexandria , Egypt
    7,943Coins
    Thanks for that ... sure I'll try that tip right now ...
    thanks again .:thumbs
  9. fluna
    fluna New Member
    350Coins
    2DOF, DC motor, SimforceGT
    Hi, this firmware will work with my Pololu 18v25 hbridge? only have two wires for direction. (PWM & DIR).
  10. fluna
    fluna New Member
    350Coins
    Another question about Prilad´s galvanic isolator.
    The output of Arduino are: DIR and PWM but:
    on Prilad´s galvanic isolator, there are 3 Outs!:
    M1_PWM
    M1|_INA
    M1_INB
    thanks
  11. fluna
    fluna New Member
    350Coins
    OK, IT WORKS perfect with my Pololu 18v25! and my diy hall sensor
  12. fluna
    fluna New Member
    350Coins
    I have only the Prilad´s galvanic isolator question...
    M1_PWM
    M1|_INA
    M1_INB
    thanks
  13. fluna
    fluna New Member
    350Coins
    anybody can help with opto isolator?
  14. helisfreak
    helisfreak Member
    Phoenix, AZ
    579Coins
    Can anyone tell me what's the difference with the files in the zip? 9600, 19200, 28880 ect...?
  15. Pit
    30,497Coins
  16. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    Can a pololu simple motor controller control position if used with an arduino, datrefs from the sim software, and potentiometer?
  17. trust928
    trust928 Member
    brazil
    435Coins
    hey my babies after much work i can say its done, but as nothing is perfect im having a problem as i always use prilads firmware heres the place, every thing works, from xctrl to the game, the problem is that my wipers internal coil are being burned after some time, some time the left wipe some time the right,, if every thing is correct, what else can cause the coils to burn?
  18. Historiker
    Michigan USA
    9,208Coins
  19. trust928
    trust928 Member
    brazil
    435Coins
  20. trust928
    trust928 Member
    brazil
    435Coins
    Hey guys prilads firmware is high frequence or low frequence? I havent see any mention about it, and my hbridge i think iys not made for high frequence
