Arduino uno wiring diagram
Discussion in 'SimTools compatible interfaces' started by hooshang, Nov 9, 2013.
  1. hooshang
    hooshang Active Member
    275Coins
    this system is the one with the same configuration, work
    with x-sim properly...?!?
    thank you freind
    hooshang
  2. hooshang
    275Coins
    not solved yet!?!?!
  3. Historiker
    Michigan USA
    9,212Coins
    Sorry, I have not had time to wire everything up. This is the end of the Semester and I am hopping in order to get all my student's papers graded. It is amazing how students will ignore assignments until the last couple of weeks ;)
    I have installed the hex file to the arduino (UNO), I need to connected a potentiometer and then I should be able to see results from SimTools in xSimCTRL correct?
    Perhaps I can get a few minutes tonight to play around with it.
    I do not want to replace the Uno on my current platform as it is working perfectly with RacingMat's Arduino sketch. If I get Priliad's hex file to work I will try to use it on my next build if I can adapt it to six axis (or even three if I use two Arduinos)
  4. prilad
    Dubna, Russia
    9,672Coins
    3DOF, DC motor, Arduino, 4DOF
    Hi guys. I realy don't know how to help you... I'm sorry. On my system all works fine.
    Hooshang, are you sure that you downloaded the LAST firmware version (sorry for this question)
  5. hooshang
    275Coins
    hi prilad
    yes,download Simtoolscompatible one
    realy appreciate brother for all you have done:thumbs
    thank you
    Hooshang
  6. hooshang
    275Coins
  7. prilad
    Dubna, Russia
    9,672Coins
    Hi, hooshang. :)
    You wrote...
    ... but don't wrote - how? Last firmware version works good?
    What question? If you need any help - ask :)
    Regards,
    Ale.
  8. hooshang
    275Coins
    @prilad
    ive changed pc and it just worked!
    ill ask you a few question later
    but there is still exist the old question that why does the same Arduino and firmware worked
    with x-sim properly and doesnt with simtools!?
    however(to simtoolser...)i believe the simtools still is not as green as x-sim
    interms of compatibility with windows and othr programs
    best regards
    Hooshang
