  1. Erwan960
    Erwan960
    I used to control my simrig with xsim. Because I installed windows 8.1 today and x-sim isn't compatible with it, I tried SimTools and everything works fine.
    But the driver of my wheel (fanatec csr elite) isn't compatible with 8.1... so I have to return to windows 8. I will not return to xsim provided!
    Although under development, simtools is more intuitive :)
  2. Historiker
    Michigan USA
    9,205Coins
    That is not good to hear; that the Fanatec driver is not compatible. I too am using Fanatec gear. Did you check the Fanatec forums to see if there is an update?
    EDIT: lol, just noticed that you posted a "You have been warned" post over there ;)
  3. bsft
    Oh sorry, I guess you mean 2089, not really available now Simtools is running.
  4. bsft
    Ah dont worry, they will ban you in no time at all. Just stay here and stick with Simtools.
    As for fanatec wheel driver, I asked here for you as well http://insidesimracing.tv/forums/topic/6403-so-will-fanatec-work-with-windows-8/
  5. Brighton
    Brighton Member
    221Coins
    DC motor
  6. Brighton
    Brighton Member
    221Coins
    DC motor
    I'm gonna try to get SIMTOOL
  7. RaceRay
    23,884Coins
    :cheers
  8. RaceRay
    23,884Coins
    Should not be possible when the platform mechanic has been build properly. Do you have any pictures for the issue?
  9. Brighton
    Brighton Member
    221Coins
    DC motor
    Hi guys, i tried so many times to found how i can get SIMTOOL but i cant see how i cant get it, Please guys show me how i can get it, if i can get a link that will good.
    I been using XSIM to control my Simulator but now is not available any more, so please help me to get SIMTOOL. Thanks
  10. RaceRay
    23,884Coins
    Feel yourself invited. I ve granted the access for you. Look for simtools to find the threa.
  11. Brighton
    Brighton Member
    221Coins
    DC motor
    hi, The problem is, i cant see the Simtool software on website
  12. Brighton
    Brighton Member
    221Coins
    DC motor
    I did find SIMTOOLS and i cricked on, what i can see is this (There are currently no resources to display).
  13. RaceRay
    23,884Coins
  14. Brighton
    Brighton Member
    221Coins
    DC motor
  15. Erwan960
    Erwan960
  16. Historiker
    Michigan USA
    9,205Coins
    Thanks Erwan, good to know. I was going to upgrade to 8.1 (so it will boot to the desktop if for no other reason) but was hesitant after hearing about your Fanatec driver issue.
  17. mario73
    mario73 New Member
    Mecchanik
    Monza
    382Coins
    DC motor
    hi at all the community my name is Mario from italy and the simulation of formula1 historik is my favourite passion, i build some pheripheral wheels and pedals now i build a new pedals with all sensor for accelerator and a load cell for the brake i need a help for a creation of a display for view weight in kg. in order to calibrate the brake if 20, 30, 50, up to 100kg.
    I think with arduino is possible this project,I hope that here you manage to help me in my project in Italy because no one can do it, can you tell me where I should post my question?
    escuse me for my english best regards
  18. value1
    14,237Coins
    Hi Mario and welcome in the forum!
    Have you tried load cells from a pesapersone? Cheap and accurate!
  19. Brighton
    Brighton Member
    221Coins
    DC motor
    BrightonHi guys, Is the VELLEMAN k8055 interface works with SIMTOOLS?? Thanks
  20. eaorobbie
    20,502Coins
    ah no there is no interface plugin for the k8055 not a recommended driver, if using a sabertooth recommend using the Kangaroo instead to drive the sabertooth
