  1. Deaks
    Deaks New Member
    Freelance Editor
    Bristol UK
    388Coins
    I have been looking into the idea of rear traction loss using a third actuator, and looking at the excellent simxperience design, the wheel and pedals (in fact the whole chassis) slides sideways just like a real car.
    It pivots from the front of the chassis in front of your feet and slides on runners at the rear by the actuator damper bar.
    If you take a look on Berneys website you can see how it works quite well.
    Happy Christmas :cheers:
    Deaks
  2. Fahim
    Fahim Member
    235Coins
    One the website all the videos seem to be from straight on back.
    So I can't see if the steering wheel moves aswell. Because there is a seperate full base for the rear actuator.
  3. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    @ Deaks. Thanls for the compliments on the rear traction loss system.
    @ Fahim - The entire simulator chassis moves. This seems to provide the most realistic feel for rear traction loss since it is doing exactly what a car would do. Attempts to pivot directly under the seat and provide rotation did not result in as accurate a feel. I chose instead to pivot from the front and provide rear traction loss simulation rather than general rotation.
  4. brian7408
    brian7408 New Member
    7Coins
    I've done hours of research, and Simxperience is definitely the way I plan to go. From a newcomer's perspective who is pretty good at researching online, it is undoubtedly the best choice, hands down. I do have some questions...
    1. My current rig is an E8500 o-clocked at 4.2, with a 8800 ultra. It runs rfactor and dirt 2 flawlessly with trackir at any good resolution. Will the sim software cause much of an additional cpu load? I'm assuming rfactor2/dirt3 wont be too much greater of a demand than what the current ones are. I was hoping to stay out of upgrading much until nvidia gets their 3-d hardware issues straightened out.
    2. any particular operating system seem to work better with the software?
    3. How difficult is the seat installation? Will I need to get a metal fab shop involved, or is this simple drilling, or bolt right in, and is there a seat that is recommended that fits better than other seats?
    4. Are their any set plans out for a seatbelt tensioning system add on, and if so, does that affect which seat (racing harness configuration) I should look into purchasing in order for it to be compatible?
    5. Ive read that drifting doesn't work well with the traction loss, for obvious reasons, but how about dirt oval, such as the rfactor DWD mods?
    6. What is the approximate cubic footprint of a stage 4 setup, without the monitor?
    7. Do the people who bought this system feel like it made a huge difference, in other words, comparing racing at a desk to racing in the Simxperience, would you say that having the motion makes it that much more immersive in a proprioceptive sense? Would you have a hard time racing without it?
    7. Who shot Buckwheat?
    Thanks,
    Brian
  5. Fahim
    Fahim Member
    235Coins
    Bernard that great that it all moves. I can't modify mine to do this.
    Not saying I would because not sure if it is better than just the two on the chair.
    Maybe I'm just saying that because I have not got it but would be nice if egoexpress, sirnoname masteryoda etc have tried one. Once you have sold lots and lots there will be more reviews,
  6. bvillersjr
    Ohio, USA
    438Coins
    @ Fahim - The rear traction loss simulation is in addition to the two on the chair. It adds effects that you can't get with only two actuators. That's the entire reason it was added. Several others in the forums have driven it. I believe that Ledfoot already offered his opinon earlier in this thread. It's not likely that the guys you listed will have one. They are able to weld and make their own.
  7. bvillersjr
    Ohio, USA
    438Coins
    @ Brian - These are good questions. I will leave this thread in hopes that some others who have experienced the Stage Series will respond to them. If you don't get the ansers you need here, I believe you have my email address.
  8. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    1) Since most games do not support multiple cores just yet, your overclocled E8500 should do just fine for the time being.
    2) I'm running Windows 7 -64bit with great success.
    3) Seat installation in the Stage 4 was plug and play with my Sparco seat using the standard seat monting brackets.
    4) I'll let Berney answer this one.
    5) The rear traction loss module in the Stage iV was designed for simulating loss of traction and not full on drifting. The limited range of travel of the actuator being used does not allow for the angles necessary to simulate full drifting however, the rear traction loss module adds a whole new dimension to the driving experience.
    6) Berney should be able to answer this one.
    7) One you race with a properly setup motion platform like the SimXperience, it makes it very difficult to go back to just a desk and a wheel.
    ....Mike
  9. angalvezs1
    angalvezs1 New Member
    Hi, everybody im beginner about it and thanks. My english is poor.
  10. DaMaine1
    DaMaine1 New Member
    Nuclear Medicine Technologist
    Wesley Chapel, FL
    381Coins
    Hello everyone. I'm just getting started in the sim building process but hope to be joining you all soon. Once I'm up and running I'd love to compete against you all in some races!
  11. Technic
    Technic New Member
    Poland
    300Coins
    I have just found this topic, but already read almost all the forum :)
    I'm Adam from Poland (moze jeszcze jest ktos z pl - maybe im not the only one?)
    Age : 28 - I saw that im not the only one big boy here...
    Hope to see you in some game using x-sim :p
  12. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Hello everyone,
    My name is Shannon in the USA, Virginia actually. I have been visiting this site for about 2 years now. Just finally got around to registering and doing intro. Think I even made this login a bit ago.
    Im determined to make a 2dof simulator. I have read through a lot of the intros, the docs, the pdf's, the posts. I can only say that I am amused and overwhelmed as Im sure most are when finding this awesome site and software. There are so many options out there and Im just not sure what all to get to start, I see parts lists, then I see a long thread with an update....head spins....I think im good with the hardware but the electronics like amc1.5 and the h-bridge, while I understand how to build together, Im not sure what all parts to get. Im not opposed to having someone else build the electronics for me at cost, but Im not sure how the scene feels about that.
    My goal is to do a wiper motor setup. I will construct the frame using steel and weld and look to have just the seat mobile with the pedals, steering wheel and shifter remaining motionless.
    Ok, so intro is done...now where do I go...hmmmm...wish me luck
  13. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    NEW MEMBER? Introduce HERE!
    Hello everyone,
  14. fredspeed
    fredspeed New Member
    Northern Norway
    418Coins
    Velcome, and absolutely good luck. It is a lot of help to get building this electronics. If you havent made electronics before you will meet som challenges, especially with the h-bridge, but there is also alternatives like pololu controllers and drivers, and relay-driver. If you are determined and patient You`re gonna have a lot of fun here!!! :thbup:
  15. EC Sim Hardware
    EC Sim Hardware New Member
    EC Sim Hardware - - CEO
    Spain
    261Coins
    Hello Everyone,
    My name is Eneko Celayeta.
    I have 22 years old and I'm real life rally driver on my Citroen C2 R2.
    I also race on karting too in the past. In general I race in real life in the last 6 years.
    Every week I use different simulators to give up the feeling with the car and I also stay at Milestone (WRC 2010 Developer) to give my impressions and feedbacks about it.
    After the presentation, I'm taking the oportunitty to announce all Sim Racers something interesting.
    Due some different reasons, I need to leave up the real competition world but I didn't want leave up in all aspects.
    We are starting offering high quality Sim Racing Products. Every product was studied designed and manufactured by EC Sim Hardware.
    For the moment we are in advanced development in our products but some of those are finished like PRO Shift (secuential gearbox) and PRO Handb (Handbrake)
    You can follow it on: www.ecsimhardware.com
    Thanks you all to keep reading my lines...
    We stay often in contact.
    Best regards.
    Eneko Celayeta.
  16. padek78
    padek78 New Member
    Hello. I am Pawel from Poland (33). I am a total noob in a hardware simulators but I eventualy want my motion sim in a future. I have been simracing for almost 20 years now. I am not interested in electronics or metal casting :) . I only know that somewhere in the future I want to upgrade my simracing cockpit because I feel that instead of my interest in simracing gets lower it actually gets higher and higher so natural way is to upgrade step by step my driving immersion.
  17. bvillersjr
    Ohio, USA
    438Coins
    Welcome Pawel
  18. MrChaos
    MrChaos New Member
    Denmark
    333Coins
    Hello All :)
    My name is Michael Christensen i'm 31 and lives in Denmark
    I've been real simracing for about a year now, well I have been playing car games since the commadore 64, but that's not simracing :D
    One day when I was browsing around on youtube, I found out that people was making homemade simulators, so I investigated it some more through google, and found this forum, that I really spend alot of time reading about others experience when building a simulator.
    So that was a little bit about me, and how I got here :)
    Sorry for my bad english, but i'm not a fan of using google translate ;)
  19. bvillersjr
    Ohio, USA
    438Coins
    Your english is not bad. Welcome.
  20. Deleted member 4666
    Deleted member 4666
    I hope you already started working on a TestDrive Unlimited 2 plugin. ;P
