Assetto Corsa Competizione Plugin 2.0.0.0
SimTools plugin for Assetto Corsa Competizione
  1. JayMonkey
    JayMonkey New Member
    52Coins
    Hummmm,
    I thought I had the latest version of Sim Tools installed but maybe not ?
    Game Dash shows Version 2.1 in the top corner of the App, but i don't see any version numbers in Game Engine or Game Manager.
    How can I check if i have Sim Tools V2.3.1 Installed ?
    Cheers
    Jay
    153,770Coins
    +11,149 / 57 / -2
    The installed version is on the SimTools splash screen.
  3. JayMonkey
    52Coins
    @noorbeast,
    Hummmm ....I never really look at the splash screen hence why i've not spotted the version number before.
    Many thanks for the tip ... :)
    Might I suggest to the devs that the version number for Game Engine and Game Manager be displayed in the top corner like it is in Game Dash ...
    Just a suggestion ...
    Cheers
    Jay
  4. JayMonkey
    52Coins
    Thanks for the tip ...
    I checked and my installed version was 2.3 .. and game dash was 2.1
    So I downloaded SimTools 2.3.1 and Game Dash 2.2 and updated my installed versions, I also re downloaded the ACC plugin and updated that just to make sure everything was up to date.
    Upon Starting ACC Game Dash was still missing the ACC in the Profile selection, eventually I figured out i needed to unpatch then re-patch ACC using Game Manager and finally was able to select the ACC profile in game dash.
    Running ACC showed telemetry data being processed by Game Dash .. I copied my dash settings from my AC profile to the ACC one and everything is now working.
    Happy Days :)
    Cheers
    Jay
  5. f1iceman
    925Coins
    Hi all I have not been about and just fired my rig up again and I am still stuck with no motion for ACC.
    Its still the exact issue shuts down the Game Engine everytime I boot ACC.
    I have checked the ip setting when the game is not running on the ip of the game engine and that is 127.0.0.0.1 standards setting still.
    its saying the game has patched when I install it but I am abit lost now as been out of it for abit. would really like to get this up and running with acc as I have been wanting to play again for a long time now, but few things have stopped me, but I hope to be back on it again as I used to be.
    any help I would love at this stage.
    thank you all for any help in advance x
  6. f1iceman
    925Coins
    Hi after reading up on the assetto corsa orginal I found the issue there was the same and I have deleted the files let it rebuild and it is giving motion now and not shutting the game engine down.
    thank you for all the help here and in the other areas just show how important the smallest of thing are being documented.
    I did not look at that as it was assetto not ACC but when I seen similar issue it had to be the same thing going on.
    deleted the app data and boom back in bussines.
  7. Sin.Schumi
    Sin.Schumi Member Gold Contributor
    - 18Coins
    SCN5
    With the Last Update of ACC the TL does not Work ?? I Think they change somthing in the Telemetry
  8. Roland Munz
    Roland Munz New Member Gold Contributor
    - 114Coins
    Unfortunately, I have the same problem that Traction Loss doesn‘t work anymore.
    It would be great if anyone has a Solution.
    Thanks in advance!
  9. yobuddy
    51,529Coins
    Since we are using the official API nothing should be affected by updates.
    So I believe the game publishers turned some telemetry off.
    Hopefully they will fix it in the next update..
    Take care,
  10. value1
    14,237Coins
    I'm running the actual Version 1.2.1 without problems, i.e. seemingly correct data in GameEngine Tuning Center, Game Dash and GameVibe Tuning Center.
    And AFAIK there was no API update since the V1.1
  11. sparco
    sparco New Member Gold Contributor
    Paris
    - 143Coins
    SCN6, 4DOF
    i do...
    actuators (PRS Prosium) work in slowmo sometimes...i have to reset...
  12. sparco
    Paris
    - 143Coins
    SCN6, 4DOF
    i have mainly the problem on ACC
  13. xxpelle
    xxpelle Discord "TPMax#9574" Gold Contributor
    713Coins
    Hi
    Man kann Assetto Corsa Competizione Bei BigScreen in SBS 3D spielen "-emulatestereo" bei Steam eigenschaften eingeben und das Spiel als SteamVR starten.
    Hi
    You can enter Assetto Corsa Competizione at BigScreen in SBS 3D, play "-emulatestereo" on Steam properties and start the game as SteamVR.
    BigScreen auf SBS umstellen und Inverted 3D Modes
    Switch BigScreen to SBS and Inverted 3D Modes
  14. Ciaoarturo
    Ciaoarturo New Member
    36Coins
    Question for everyone: The plugin works fine. But, the motion of the rig and the in game view (in Steam VR) seems out of sync. I've tried various levels of VIEW settings in ACC to lock the horizon and limit cockpit movement but nothing seems to get it right. The rig will move as I'm driving just fine but the VR scene seems to be playing catch up, especially with pitch movements. I assume it's an ACC setting combo I have wrong. Any ideas?
  15. Abt_Simulator
    Abt_Simulator New Member
    28Coins
    Hey @yobuddy,
    first of all many thanks for your plugin!
    I'm in the process of setting up my custom build 6DoF sim and was wondering the following:
    • For pitch and roll, do you forward the absolute value (i.e. relative to a flat reference surface) into SimTools? And if so, wouldn't it be more appropriate to forward the relative values between track surface and vehicle or a blend of both (if possible)?
    • Due to the limited rotation of my sim (yaw-dof), would it also be possible to receive the yaw rate, rather than the total yaw angle as it currently is? I'm guessing one would need to write a new plugin and pick up a different channel from the telemetry or apply the derivative at this interface?
    Thanks in advance for your response!
  16. YIN Fan
    YIN Fan New Member
    24Coins
    New to here, just trying set up my sumilator. Thanks all
  17. noorbeast
    153,770Coins
    +11,149 / 57 / -2
    If you need to please start your own thread, detail any issues you may have and include pictures of all of your settings.
  18. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Motion platform, 6DOF
    I have a 6 DOF rig, but cannot find any information on the difference between Traction Loss LV and V18?? Anyone?
  19. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Anyone?? What is Traction Loss V18 vs Loss LV? There is no tooltip or documentation explaining what those are and what they do...
  20. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    What is the difference between traction Extra 1 - Loss LV and Extra 2 - V18? Should I use one over the other with ACC or ProSimu P7MP?
