Resolved Assetto Corsa plugin
Discussion in 'SimTools Plugins' started by ericRacer, Nov 15, 2013.
  1. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    875Coins
    2DOF, SCN5
    Haven't played AC much because of camera motion is limited to locked to the horizon or not. Didn't care for either and the unlocked setting made me dizzy/sick in no time. Then I installed Real Head Motion last week and what a major difference.
    The problem I'm having is I'm only getting ramdon signals/movement and no real car movements. It's been a couple of months since I played the game with motion but everything was fine back then. Do I need to update anything since the official release? Running plugin 3034
  2. Blame73
    Blame73 Well-Known Member
    8,316Coins
    Always used real head motion and never had problems with it and motion
  3. Hobbs77
    Connecticut, USA
    875Coins
    2DOF, SCN5
    Thanks.......that's good to know!
  4. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    A curiosity... after installing the Assetto Corsa plugin in SimTools software and after have patched the game (indicating the game patching path) where it is added the .dll file?
    154,711Coins
    +11,210 / 57 / -2
    All SimTools data is stored here: C:\Users\Your_User_Name\AppData\Local\SimTools\
    To back up SimTools you just zip and store that folder: http://www.xsimulator.net/community...thout-loosing-your-profiles-and-settings.160/
  6. furiano
    furiano New Member
    - 88Coins
    Asseto Corsa Plugin 3.0.6.0
    Not working with me, who can help I am grateful .
    154,711Coins
    +11,210 / 57 / -2
    You will need to be far more specific about your settings and what you have done or not done. Just saying something does not work will not help anyone to troubleshoot the issue.
    Did you install the AC plugin with Game Manager running with Administrator privileges?
    Have you followed all the steps of previous advice given to you regarding the proper way to setup a plugin: http://www.xsimulator.net/community/threads/2-dof-3-monitors.7673/page-2#post-94540
    Can you please post pictures of all your SimTools and Tuning Center settings.
  8. furiano
    furiano New Member
    - 88Coins
    SimTools recognizes the game starting but no response from 2 dof, using heave , sway and surge .
    In projectcars operates normal.
    154,711Coins
    +11,210 / 57 / -2
    Again that is not enough information to be able to assist you.
    Have you patched as administrator?
    What path have you patched to?
    Please confirm if you have or have not followed the previous advice on how to set up a motion profile.
    Please post pictures of all settings.
  10. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    2DOF, DC motor, JRK, SimforceGT
    Am I the only one having trouble with Assetto Corsa after the 1.5 upgrade?
    The motion works. But it aint as powerful and then ALOT of delay :(
  11. Nick Moxley
    17,057Coins
    Not running 1.3 But overall motion from AC is 100% fine. I suggest you check your gear Simon.
  12. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    Thanks for the info Nick .. :)
    But all other games runs perfectly. Have tried to unpatch/patch the game to see if that helped..
    But no luck...
    Gotta give it a try again then..
  13. luky_90
    luky_90 Member
    277Coins
    hello guys, I have to update race trim but do not know whether to do it for this reason , no one has found problems ?
  14. noorbeast
    154,711Coins
    +11,210 / 57 / -2
    I am sorry I do not know what you mean, can you explain a bit more what your issue or question is.
  15. luky_90
    luky_90 Member
    277Coins
    the assetto corsa plugin was to v.1.4.3 from yesterday came out the v.1.5 works equally this plugin ?
  16. Blame73
    8,316Coins
    Yes, motion's working
  17. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    Hope this is the right place to ask for help since the plugin works for everybody else..
    But I'm still having trouble. Have removed the plugin and made a fresh install..
    No luck still..
    All my other games works perfect with Simtool s..
    The problem occoured right after the 1.5 update.
    Have a 2 dof, and the sway and surge axles works and gives the same amount of "feedback" as usual (As I have trimmed in tuning center)
    But it feels like there is some kind of delay..
    Are there any possibility to "tune" the axles so they respond faster just in the Assetto Corsa Plugin?
    Thanks in advance..
    Simon
  18. noorbeast
    154,711Coins
    +11,210 / 57 / -2
    Yes, you use the Tuning Center for tuning: http://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  19. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    Thanks Noorbeast..
    I have now read the link you linked to..
    I cannot see I can do more than i already have tried to do?
    All my axlas has been trimmed in tuning center..
    Im pleased in how the seat moves.
    But it just feels like they are only moving with 50-75% of the speed so the movings doesnt feel so realistic.
    The movement is much faster in Iracing, raceroom etc..
  20. Blame73
    8,316Coins
    Could you post a pic of your tuning center settings?
