Resolved Assetto Corsa plugin
Discussion in 'SimTools Plugins' started by ericRacer, Nov 15, 2013.
  1. Nick Moxley
    17,057Coins
    Are you sure your running the Profile @ 100% ?
    154,711Coins
    +11,211 / 57 / -2
    The lower the Tuning Center values the faster the response.
    It would be helpful to post pictures of all your settings and a video that shows the movement of the simulator and game screen at the same time.
  3. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    2DOF, DC motor, JRK, SimforceGT
    Well. I have now tried uninstalling Simtools completely.. That didn't do it..
    But after recording min/max in tuning center SEVERAL times it started to come alive again.
    I have never tried this before.
    I know I'm not seriously hardcore in Simtools.
    But the other times I have just driven a lap without hitting anything and have got the min/max values and thats it..
    From there I have made some further fine tuning. But have had a good baseline from the standard min/max values from tuning center..
    This one was tricky..
    But now it works..
    Thanks for your help guys :cheers
  4. Blame73
    Blame73 Well-Known Member
    8,316Coins
    Sometimes recording min/max values is not enough because you could want to feel more some effects.
    e.g. if you wanted to feel more the acceleration than what it gives you the recording, you should manually input the values. To do so you have to start recording and once text boxes are enabled you type in your values. The lower the values the higher the effect. Also, if you want to feel more the acceleration than the breaking, you could insert different positive and negative numbers, like 2 and -3
    • Agree Agree x 3
  5. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    I'm aware of that Blame73 and have tried fine tuning similar to that ..
    But this was so much different..
    So annoying I didn't take a video of it eventhough it would have been hard to see the delay and the slower movement.
    But I have made made a new network for simtools going out on a usb to a rj45 adapter.
    Don't know it that can cause some network/delay problems..
    Just wondering Assetto Corsa was the only game where it appeared.
    If it happens I will take a video of it.
    Thanks again...
  6. Bullitt
    Bullitt New Member
    Sydney
    271Coins
    i am trying to make a simple dashboard indicating gear, rpm, shift light, speed and delta time or your time after finishing a lap.
    From my understanding the latest two are not yet implemented in the plugin, sorry i haven't been able to download the plugin yet so i am not so sure.
    any chance time value can be added to the plugin in future?
  7. sparco
    sparco New Member Gold Contributor
    Paris
    - 143Coins
    SCN6, 4DOF
    Hi All,
    I'm new on the forum and a new owner of a ProSimu T1000 sim motion.
    I downloaded the AC plugin and dragged it in the plugin updater.
    I wad told that the update is ok but i can't see the AC choice in the GameManager.
    I must tell you that my .exe is on D and not see
    Many thanks for you help !
    Sparco
  8. Willem Pienaar
    Willem Pienaar New Member
    478Coins
    Good afternoon fellow racers.
    I'm experiencing problems to get Assetto Corsa to sdtart SimTools. Ive downloaded the AC plugin and patched the game successfully. I have started AC from within Steam and from the shortcut on my desktop, but all to no avail.
    P.S. SimTools plugins for iRacing, FSX, X-Plane and various Stem Games (Eurotruck, PCars and Dit Rally) all works fine.
    What am I missing.
    Amy suggestions will be appreciated.
    Regards
    Will
  9. Nick Moxley
    17,057Coins
    did you patch the right location ?
  10. Nick Moxley
    17,057Coins
    ALSO fwiw, if your New To AC.....you dont get a "connection" with simtools till you actually jump ON Track with pressing "RACE" in the top right corner from the Online UI.
    Not likely the case, but just thought of it.
  11. Willem Pienaar
    478Coins
    I assume I have patched the right location i,e .... \Steam Games\steamapps\common\assettocorsa
    Please let me know it is incorrect.
    Eagerly awaiting your response.
    Regards
    Will
  12. Willem Pienaar
    478Coins
    I went onto the track and started driving but no SimmConnect.
    Note : SimConnect is usually locked when you're in a game i.e. don't allow you to make any adjustments. In the case with AC Simconnect is not locked.
    Please help.
    Regards
    Will
  13. noorbeast
    154,711Coins
    +11,211 / 57 / -2
