Aura shaker ast-2b-4 with bk-g2 amp
Discussion in 'Off Topic - All other stuff here' started by hazardic, Jun 11, 2015.
  1. WowaDriver
    WowaDriver Waldemar Jost
    Bachelor of Science and Engineering
    Hannover
    1,127Coins
    @Dev's:
    Is it possible to get some infos about a possible beta release date or any infos about the functionality of the plugin?
    Actually i'm in development for my new rig and decide last month to integrate a bass shaker module for all four
    tires to identify exactly from where the bombs will come. But if you will say the support will have a support for only
    one or two transducer, i have to get a new decision about how to build the setup.
    The main point in the simtools software i like is the support about a server and client functionality! I like it very much
    to have the possibility making changes in the profiles on the client pc and the game works in the same time on the server pc.
    So you don't need to have a window mode or minimize the game...
    And now the next question... will it be possible to connect the bass shaker to the client? I have to plan where the cable
    have to go...
    BTW: Which games works correctly with simtools and simvibe on the same time? iRacing? Assetto Corsa? pCars?
    Best regards
    Waldemar Jost
    153,788Coins
    +11,150 / 57 / -2
    @Dev's won't work, it would be @yobuddy who will advise soon about the next update of SimTools and transducer support and @eaorobbie who posted about early transducer testing with Dayton Pucks.
  3. Historiker
    Michigan USA
    9,205Coins
    Waldemar, I have had no problems using SimVibe and Simtools at the same time with any game although I do not have PCars I would assume from my experience that it will work.
  4. f1iceman
    925Coins
    well that the misses sorted for xmas :) lol
  5. f1iceman
    925Coins
    it was just a thought and an idea but if the wheel is force feedback and its decoded as that the out put to the wheel is already being sent to the motor.
    has anyone tried to hack that part of the out put or tag onto its out put ?
    just thinking if can extract from the wheel aswell you could get alot from it. was something else i wanted to look into.
  6. f1iceman
    925Coins
    you would be getting most feedback then of the right stuff you could even lock out via resistors to let certain info thru for diffrent forces so anything like road and hard bumps would prob be easyer to use or get the info for its more finding away to convert it to goto an amp so taking the feed from the main output to motor in wheel and converting it to run thru an amp, not sure which way it could be done or even get it before the outpower amp for the motor so you feed two things with info not just the wheel itself.
    if the wheel is simulating then its the right info for the chassis for some bits
  7. WowaDriver
    Hannover
    1,127Coins
    @noorbeast: Yes you're right, but with dev i mean this both guys ;) .... i would get some infos only ... ;)
    @Historiker: Thanks a lot for your statement! So if there is no chance for the future to get all funtctions from simtools i will have an other way to get my rig shaking :D ...
    153,788Coins
    +11,150 / 57 / -2
    I get what you meant to do but if you don't tag members specifically then they won't get an automatic alert and you really can't rely on them reading all posts.
    We will know what the future of transducer support for SimTools is when @yobuddy gives an outline of new features and a development road map.
  9. isamu
    isamu Member
    267Coins
    Excellent idea F1Ice!!!!!! I've been wanting an option to convert standard direct input wheel FFB into transducer/rumble compatible signals for a long time. Very very hopeful that this upcoming transducer plugin address this issue.
