value1
Automobilista Plugin 2.0.0.5
SimTools game plugin for Automobilista
  1. Sento Siete
    Sento Siete Member Gold Contributor
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    In the main folder of your AMS instalation!!
    If Steam:
    X(your drive):\Program Files (x86)\Steam\steamapps\common\Automobilista\Plugins
  2. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    113Coins
  3. helisfreak
    helisfreak Member
    Phoenix, AZ
    591Coins
    Hey guys,
    How come I can't download Automobilista plug in? Is it because I don't have enough coin? It said Not Available?
    How much coin do I need?
    thanks guys.
  4. BlazinH
    16,703Coins
    You have enough coins so I think you just need to purchase a download package. There's a link to them at the top of this page.
  5. helisfreak
    helisfreak Member
    Phoenix, AZ
    591Coins
    Yes, got it, it been so long, I forgot about how to redeem the coin. :)
    But could someone explain how to add traction loss?
    "For add traction loss with automobilista put manualy rfactor plugin in AMS plugin folder ;)
    Have fun"
    I don't know what rfactor plugin mean? where can I get this file?
    154,711Coins
    +11,211 / 57 / -2
    According to the plugin information traction loss is not implemented, only pitch, roll, yaw , surge, sway & heave.
  7. BlazinH
    16,703Coins
    Do this instead. In your AMS installation folder find the AMS.exe executable and rename it to Marcas.exe. Then apply this patch to the same folder https://www.xsimulator.net/community/marketplace/copa-petrobras-de-marcas-plugin.121/. Once that's done either double click Marcas.exe from the installation folder to launch AMS or right click it and create a shortcut to you desktop and you then you can launch it from there instead. That's it!
  8. helisfreak
    helisfreak Member
    Phoenix, AZ
    591Coins
    Thank you. With your instruction I manage to get some output for Extra1 for traction loss, but it sure isn't working with the same number I had working for AssettoCorsa. But that's the least of my problem with this game.
    Spent a few hours trying to get my LogitechG27 to work with this game, no luck... It's just so weird, the FFB is all over the place, some time it's on, sometime not. Throttle and brake is odd as well, sometime I feel I am in control, something it wouldn't response at all. I see on the screen it's reading my input, but it doesn't seem to response to it.
    Never had such issue configuring my wheel with AC.
  9. BlazinH
    16,703Coins
    Every title must be tuned to your rig. If the numbers from one title work good with another your just lucky. But AMS, Game Stock Car, Marcas, and maybe Rfactor would use the same numbers.
    Don't remember if I tried my G27 with this title or not because I prefer using my very old Logitech Red Momo wheel. It just feels so much better in your hands and I prefer a 270 degree wheel too most of the time. But feedback works a treat with it!
  10. BlazinH
    16,703Coins
    Btw, traction loss is a treat with this title also once you get it set up properly.
  11. Boomslangnz
    4,172Coins
    This resource has been removed and is no longer available for download.
  12. stevemontuno
    stevemontuno Active Member
    1,461Coins
    Hi guys ,,,will there be a simtools 2.0 pluggin for this title or do i have to use GSCE,, Cheers
  13. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    290Coins
    The best physics, and the best version of Autodromo de Buenos Aires, but without RV is not an option. Apparently, they will give support soon
  14. myg20
    myg20 New Member Gold Contributor
    Budapest, Hungary
    - 135Coins
    Hi, does GSC2013 plugin V2.0 work with AMS?
  15. value1
    14,295Coins
    • Winner Winner x 5
  16. BlazinH
    16,703Coins
    Woo-hoo! Another hug:.
  17. bruce stephen
    general contractor
    michigan
    9,115Coins
    TL added, too cool
  18. stevemontuno
    1,461Coins
    Lovely jubbly :cheers
  19. Leandro Kemp
    Brasil
    - 10Coins
    Hello. I'm having trouble moving in the Automobilista. Everything works normally until about 10-15 minutes of play. After this time the simmotion begins to lose synchrony. At times he does not respond to the movements and suddenly takes a few strides. I thought it would be something in the game. After the Automobilista upgrade the problem still continues. I already tested it on another PC and the same problem happens. During the game I need to restart GameManager and doing this I have another 10-15 minutes to play before the problem occurs again. Would anyone know if it is a game problem, some configuration in the game or in the plugin? Thank you.
  20. value1
    14,295Coins
    Hmm, I'll check. I think I've read such a remark before. Will see if there's some fluffy code in there…
