knaufinator
BeamNG.drive plugin 2.0.3.0
Simtools game plugin for BeamNG.drive
  1. knaufinator
    knaufinator Active Member
    Simulation Engineer
    akron,ohio
    1,957Coins
    AC motor, 6DOF
    FYI, it looks like this plugin is using a wrong value for "Traction loss"/Extra 1 - it is using the value for velocity of X, when it should be the rate of yaw.
    //this.Extra1_Output = (double)local.velX;// <-------ORIGINAL this is velocity of x,...
    this.Extra1_Output = (double)local.yawRate; // <------- NEW this is rate around vertical z axis,...
  2. value1
    14,293Coins
    Thanks for the hint, I'll check :)
  3. knaufinator
    Simulation Engineer
    akron,ohio
    1,957Coins
    AC motor, 6DOF
    I've updated my understanding of how traction loss works in motion systems, it looks like most plugins are indeed using the velocity rate, but for the y axis,.. I was overthinking it with the rotation velocity value. Currently in the plugin with velocity at on the X axis that is tied with moving forward/back. The faster I was driving forward the more "Traction loss" was occurring.
    I had made a video of me using it on my sim if anyone was interested! I do not have traction loss enabled in this.
  4. ty88
    ty88 New Member
    6Coins
    It won't let me download the plugin,
    "You do not have permission to view this page or perform this action"
    154,675Coins
    +11,209 / 57 / -2
  6. De Baas
    De Baas New Member
    Alkmaar
    302Coins
    3DOF, Motion platform
    Is there still no solution for the tractionloss problems? I have the same problem knaufinator has. if i give gas the tractionloss goes left and if i brake the tractionloss goes right. I have a 3 dof system. I really like a solution for this problem.
  7. knaufinator
    Simulation Engineer
    akron,ohio
    1,957Coins
    AC motor, 6DOF
    Since this I was able to calculate traction loss in other games like my custom gtav plugin I made. I may take another stab at this game. It is as simple as just calculating the velocity sideways using the change in position over time, this also requires to know what way the player/car is facing. I have vacation starting soon, so I should get some time to try... I will ping u if I get it working in beamng
  8. De Baas
    De Baas New Member
    Alkmaar
    302Coins
    Oke thanks in advance.
  9. knaufinator
    Simulation Engineer
    akron,ohio
    1,957Coins
    AC motor, 6DOF
    I have taken a look at the source and I think I know what is going on, the Velocity value sent by beamng seems to be relative to the global coordinates, not in relation to the direction the vehicle is facing,... I may need to modify the beamng Lua in order for it to send the correct data... I have it loaded on my dev laptop and will tinker more in the next few days, but I think I see enough to do it...
  10. knaufinator
    Simulation Engineer
    akron,ohio
    1,957Coins
    AC motor, 6DOF
    so I got it working,... much quicker than a few days... its a little hacky,... but I needed to add to the BeamNG telemetry output the forward vector of the vehicle, then I was able to calculate the right vector based on the upXForward vectors... as well then the velocity in the Y axis of the vehicle. because we need more data from beamNG i am not sure how the developers want to handle this as you need to override a BeamNG Lua script "motionSim.lua" But I will work with value1 to see if we can get a updated official release.
    I can make a video Thursday after work.
  11. De Baas
    De Baas New Member
    Alkmaar
    302Coins
    Oke thanks for youre quick response and trying to make it work. Maybe you and Value1 can put the fix in a new update for this pugin if it all works like it should.
    Again thanks and i wait for a positive update :)
  12. knaufinator
    Simulation Engineer
    akron,ohio
    1,957Coins
    AC motor, 6DOF
    i tested on my rig machine, and its actually looking like it will work, I will keep at it,. but its not done..
    My Fanatec wheel does not have FFB in game though,.. so I need to figure out that!!
  13. knaufinator
    Simulation Engineer
    akron,ohio
    1,957Coins
    AC motor, 6DOF
    Confirmed, Traction loss works good on my rig.
    If you want to test
    Copy over the old plugin this new dll and a new
    motionSim.lua
    if it crashes simtools,. .. you may need to Unblock the file - as it was downloaded,.. and could be a nasty virus.... unblock by right clicking dll file,.. properties... and click unblock if it is shown at the bottom..
    Plugin dlls located
    C:\Users\USERNAME\AppData\Local\SimTools\GamePlugins
    motionSim.lua file located
    C:\Program Files (x86)\Steam\steamapps\common\BeamNG.drive\lua\vehicle
  14. noorbeast
    154,675Coins
    +11,209 / 57 / -2
    Excellent work :thumbs
    And my kind of car ;) https://www.xsimulator.net/community/threads/what-car-do-you-drive-in-real.7322/#post-86257
  15. knaufinator
    Simulation Engineer
    akron,ohio
    1,957Coins
    AC motor, 6DOF
    Long video of me being tortured to death by a physics engine, while tuning my rig for BeamNG.
  16. De Baas
    De Baas New Member
    Alkmaar
    302Coins
    Oke thank you so much for youre fast look at the tractionloss problem. I going to try to update that two files, i never tried to fix a standard plugin, but i will try and let you know. I have a fanatec v2.5 and i have no problems with the ffb from the game, so that is strange you have no ffb no?
    Nice rig and nice video by the way!
  17. knaufinator
    Simulation Engineer
    akron,ohio
    1,957Coins
    AC motor, 6DOF
    I like a good challenge, and I was the perfect dude for it as I had already came across this issue before with gtav, and had worked for weeks to understand and solve the issue... Now it's a tool.
    I got the ffb working, I just needed to restart the pc, trac loss worked out great and added much needed dimension to the game. I am glad I tried
  18. De Baas
    De Baas New Member
    Alkmaar
    302Coins
    Oke good that ffb works again.
    I tried youre update how you explained and i think i make it right, but for me tractionloss isn't working at all. I use tractionloss with extra 1 with all my games. I also did change the values of the tuning centre, but no tractionloss. One thing has changed and that is when i put extra 1 in the game engine on, the rig doesn't have tractionloss anymore when i give gas or brake, so that problem is solved. Unfortunalatly for me still no right tractionloss.
  19. knaufinator
    Simulation Engineer
    akron,ohio
    1,957Coins
    AC motor, 6DOF
    did you replace the motionsim.lua file?
    if you open the tuning center do you see values when you slide?
    what are your min max tuning center limits? for extra 1
    you agree that in my video, Trac loss is working yes? we need to try to figure out what is different in our setups/ config
    perhaps take a video with all that data in the feed and a webcam on the rig, I used "OBS studio" to make these videos ...
  20. De Baas
    De Baas New Member
    Alkmaar
    302Coins
    I did replace C:\Program Files (x86)\Steam\steamapps\common\BeamNG.drive\lua\vehicle main.lua for youre one. But with me it's called main.lua and not motionsim.lua?
    i have no values from the tuningcentre on extra 1. Almost all values are 10/-10. But i tried 5/-5 and 2/-2 also but nothing, because i don't have values that are changing on extra 1.
