Beginning of my new simulator
Discussion in 'DIY Motion Simulator Projects' started by mohawk24, Jan 8, 2009.
  1. Senetor
    Senetor Member
    Australia
    595Coins
    Hi mohawk24,
    The bigger end would be the drive end as it will have a larger bearing on it, the smaller end most likely had a fan mounted on it.
    Regards Senetor.
  2. mohawk24
    mohawk24 New Member
    no fan this is a TENV motor...
  3. egoexpress
    I'd highly recommend to use the end which is close to the flange!
    Btw, I guess you may have forgotten another thing. You need a reduction! The motor has not enough torque to move your platfrom without transmission. You need either a gearhead motor, or you have to connect a gearbox to your motors.
    4.5Nm are ~450g/meter -> ~450g connected to the end of a 1m leaver. Not that much...
    I'd propose a 30-60:1 reduction.
    Regards
  4. mohawk24
    mohawk24 New Member
    Hi ego yes i have a 70:1 gear reducer.....
    that is why i asked the question about the shaft as only one end of the motor will fit in the reducer....
    bearing size on one end is 205 other end is 203 if this is millimeters then that is pretty minimal i would think....
  5. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Hi Mohawk24,
    That looks like a very nice sim project you are working on. Have you completed it yet? Would like to see some vids. I am also a fellow Canadian. Where are you located :).
    ...Mike
    • IL-2.rar
      File size:
      283.9 KB
      544
  6. mohawk24
    mohawk24 New Member
    New pictures coming soon, finishing base and mounting of motors and control arms...
    I need some help now...looking for the latest, greatest list, diagrams and instructions for Tronics AMC hardware to control AC motors...
    Tronic if you could chime in and help me out that would be great....
    Also would be better if i could find an electronics expert that would assemble a complete board for me and i could pay them...instead of my fat fingers making a mess of it....LOL
    any help would be greatly appreciated...
  7. mohawk24
    mohawk24 New Member
    BUMP>>>
    anyone.....Thanos???
  8. Andi
    Andi Member
    - 10Coins
    Problem mit Input-Reference
    Hallo zusammen!!
    Endlich hatte ich auch wieder einmal etwas Zeit um zu basteln! Mein zweiplätziger
    Flugsimulator ist schon beinahe vollendet (ausser dem Cockpit Ausbau). Sobald
    alles funktioniert werde ich hier einige Vids posten.
    Trotzdem tritt noch ein Problem auf, das ich bis jetzt nicht lösen konnte. Wenn ich
    beispielsweise einen Steigflug einleite fährt der Simulator korrekt nach oben, langsam
    richtung Input-Referenz 100%. Wenn diese 100% erreicht sind, fährt er jedoch weiter!
    Wie kann ich das verhindern? Weiss jemand einen Ratschlag?
    Danke und Grüsse
    Andi
  9. mohawk24
    mohawk24 New Member
    Sorry i speak english only.
  10. bevins
    bevins New Member
    Where are you located?
  11. mohawk24
    mohawk24 New Member
    Ontario Canada 2 hrs east of Toronto.
  12. axle182
    axle182 New Member
    Any news on progress Mo? My build has started, need to take some pics and post up.
    AJ Calgary
  13. mohawk24
    mohawk24 New Member
    Still looking for someone to sell me a assembled tronic board, at stand still untill i get that piece...everything else is ready.
