Best method to connect the pot to the motor?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by siantic, Oct 22, 2014.
  1. siantic
    siantic Member
    616Coins
    Thanks @insanegr and @RacingMat!!! :D
    I have removed the pcb and i have connected the wires directly to the brushes and... it works!!!
    Now i need to know where put the potentiometer.
    If i put it rear the motor i need to make a hole on the back but it is made of iron:
    is difficult to do?
    how can i do?
    Thanks!!!
  2. RacingMat
    21,082Coins
    You can drill a hole (don't leave any iron filing "limaille" in the gears)
    or you don't modify you rmotor and you can use the lever to connect your pot: see FAQ
