Showroom Blame73's 2DOF Seat Mover
Discussion in 'DIY Motion Simulator Projects' started by Blame73, Nov 20, 2014.
  1. Blame73
    Blame73 Well-Known Member
    8,314Coins
    I'm not blaming the product for the feedback not being recognized as connected cause it could be my fault (I have to see if there's away to find out if the JRK is 'compromised').
    But I could blame it for the USB connector, since it seems I'm not the only one who suffered this problem. The JRKs lie in a box and the USB cables are nailed and can't be moved, so it's hard to me to understand how could one connector fail one day from another
    About the Pololu support, I cannot say a bad thing, they answered the first time pretty soon and I'm sure they will do it again as soon as they read my answer (right now is still night over there).
  2. Blame73
    8,314Coins
    @bsft I've been offered a small discount on a replacement
  3. Blame73
    8,314Coins
    After the problems with both the JRKs and waiting to fix them I switched back to Arduino and MM.
    I'm suffering this strange issue: both motors are so weak now. I'm using the same configuration I used before but now I can stop the chair by hand without even sitting.
    What can this depend on? The hardware is the same as before, software and setting too...
    @Pit any advices?
  4. Pit
    30,510Coins
    Please upload all screenshots (SMC3, Wiring etc.)
  5. Blame73
    8,314Coins
    I didn't uploaded 'cause wirings, smc3, ... it's all as it was when it was working the last time I used Ard & MM.
    I was just wondering if there's somethings that comes to mind to you about what could be the cause.
    I was thinking about wires too thin... but are the same I used before and with the JRKs too
  6. Pit
    30,510Coins
    Mate you mean it is same but probably it isn't. Only my suggestion from my own experiences ;)
  7. Blame73
    8,314Coins
    So the problem was with the soldering of the 5v pin. It was weak and the effect was as if I used thin wires.
    Riding again with Arduino & MM :)
  8. Blame73
    8,314Coins
    Since the seat mover was up and running again I tried to fix both JRKs.
    The USB connector was pretty easy to fix, let's hope it lasts.
    The other one that didn't see the pot anymore, was a bit longer to fix, but removing the old wires and soldering, and doing it again from scratch seems to have fixed the problem!
    Now I got two electronic system that work. On my main desk I'll go for jrks cause are easier to set.
    Considering I've got another PSU, U-Joint, motor, wheel (DFGT) and the ARD & MM I think I'll build another compact seat mover for guests (or to sell it...)
    153,764Coins
    +11,149 / 57 / -2
    The motion sim bug has well and truly bitten @Blame73!
  10. GIB SimRacing
    GIB SimRacing Active Member
    Barossa Valley, SA
    983Coins
    @Blame73 how awesome would it be to have races against your friends when you have 2 simulators side by side!!
  11. Blame73
    8,314Coins
    Ask @bsft ! he has two identical desk racers and surely a lot of video about 'em
    A lot of fun for sure :cheers
  12. Blame73
    8,314Coins
    Now that I've put (again) all the pieces together I post a short video with the last release.
    Now I'm on JRKs, game manager settings were made for Arduino/MM, so it's a little weak now.
    Right now I just got Surge and a little Sway, Heave and Pitch. No Roll and Yaw.
    A couple of laps at Blackwood, a mod track for Assetto Corsa.
    For face tracking I'm using the PS3 Eye with FaceTrackNoIR, a free software that works pretty fine.
  13. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    Nice job there @Blame73.
    I was thinking of trying the PS3 Eye + FaceTrackNoIR for a head tracking new project that needs to be portable, is it robust in use for variable lighting situations?
  14. bsft
    Nice job, so far how do you find JRKS to Arduino comparing motion reactions? Or still yet to work it out
  15. Blame73
    8,314Coins
    Thnks @noorbeast
    PS3 Eye works @120hz so it's pretty accurate. Better have an illuminated face, so if I turn the main light off I use a bajour, a reading light, cause the only light from the screen wouldn't be enough.
    It's worth a try
  16. Blame73
    8,314Coins
    Maybe it was just my settings, but I find Arduino to be more 'raw', more on/off, while JRKs are more linear, soft
    But I'll tell you more tomorrow when I play with PID settings
  17. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    Thanks, I did try a webcam but did not think it robust enough, the PS3 Eye was next on my list as I can't justify the cost of TrackIR.
  18. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi @Blame73
    What arduino code are you using and how many monster motos?
  19. Pit
    30,510Coins
    IMO really difficult to compare them separately from current and power due to the numerous parameters of each driver. I can not confirm that the Ard is raw, obviously you should check out if there could be some more potential of fine tuning. Even after one year testing I make new experiences while playing with all variables. Remember also, meanwhile I am very familiar with Ards...
  20. Blame73
    8,314Coins
    In that video I'm on JRKs, before I used SMC3 and one MM
