Canopy screen rear projection
Discussion in 'Commercial Simulators and Peripherie' started by wannabeaflyer, Jul 30, 2009.
  1. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
  2. sn4il
    sn4il New Member
    2Coins
  3. CXCSimulations
    CXCSimulations Member
    - 9Coins
    We've been working a little with this company recently: http://thinkoutofbox.com/
    It's actually a really interesting concept at a pretty economical price. (relative of course)
  4. michael haertsch
    michael haertsch Member Gold Contributor
    - 206Coins
  5. njracer
    njracer Member
    2Coins
    Hey Michael how is the canopyscreen? worth the cash?? is it hard the screen? is there some sort of frame holding the screen in place??
    any details you can give?
  6. michael haertsch
    - 206Coins
    The CanOpyScreen is to little, 107cm.
    I will bigger.
    This material can break,ca 2mm fat.
    And this making the image a little blurred.
    Now cant see the rastersizer from Beamer that is good but with blurred.
    I find good for mee 8) but another peaple i cant say.
    For this price becommes a 50zoll LED Flatscreen with many better Image.
  7. njracer
    njracer Member
    2Coins
  8. DrAwender
    DrAwender New Member
  9. Brightonuk
    Brightonuk Member
    Business Owner
    Plantation, FL
    492Coins
    Hi Michael
    Can you give us the dimensions of the FREX canopy
    Width
    Depth (Front to back)
    Height
    How much bigger do you think it should be if you could design it? Using the same dimensions as above
  10. Brightonuk
    Brightonuk Member
    Business Owner
    Plantation, FL
    492Coins
    I have just spoken with the company that makes the domes and I have been told that the thickness of the dome at the apex is 50% less than the stated thickness of the dome, that is to say you order a 1/4 thick dome the top of the dome is only 1/8 thick
    Is the Frex the same thickness all the way around the dome?
  11. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    You like it big an thin ? Softpedia reports that Samsung focused on something more unusual and came up with what can be seen as a large panel that sets a new record in terms of bezel thickness, or thinness in this case:
    The company created a 55-inch LCD Display whose top and left edges are 3.8-mm thick, while the bottom and right ones measure 1.9mm.This means that placing two of them next to one another will leave a gap of just 5.7mm between their respective screen contents.
    As such, one can consider this newcomer a very convenient candidate for LCD-Videowalls, especially considering the actual performance numbers. Not only does each panel support the Full HD resolution, but the brightness is an arguably brilliant 700 nits.
    The product was made public through an official announcement issued by Samsung Japan, announcement which also revealed one of the display maker's other plans. Apparently, this 55-inch ultra-thin bezel screen will be followed by one with a diagonal of 46 inches and a separation of 7.6mm.
    Samsung did not offer any sort of pricing or availability details - via Softpedia.
    Source:
    http://www.guru3d.com/news/samsung-55in ... ss-record/
