Center of gravity discussion on 2 DOF platforms
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by tomkil192, Aug 14, 2015.
  1. Nick Moxley
    17,057Coins
  2. Dusko Dogandzic
    Dusko Dogandzic New Member
    456Coins
    thanks for your input i looked and read some more about it and decided to test it out by calculating weights and forces involved in movement because i think with right profile u can tweak it to feel any way u like i will start a thread as soon as i start making something so far for electronics i have MM and ARDUINO
    does anyone have experience with 2 X 8800 gtx gpu`s for 3 monitor setup?
  3. Bruceaust
    Bruceaust Member
    CNC Routing
    Launceston, Tasmania, Australia
    63Coins
    Hi all,
    I have not posted for a while. But I have the urge to start a new project with some new ideas
    for my diy race Sims.
    History:
    I have built 2 Sims , both joy rider type designs (ie: both have 20 deg + rotation on both axies.
    The center of rotation on both these Sims was as close to the center of gravity as possible.
    Sim 1 was a fairly upright driving position (v8supercar) and sim 2 was a F1 reclined driving position.
    Bother have been very successful. But I have always thought there was something not quite right
    with motion.
    For the last year or so I think I have to much time thinking about this problem!!
    I have come to the conclusion that the centre of rotation should be as close to your eye position
    as possible.
    Think about the physics and the forces acting on your body as the sim rotates. I believe most Sims (including mine) are working back to front WHEN THE SIM IS MOVING to a new position.
    Having the rotation point at the eyeball point makes all the physics work in the correct sense as the sim rotates to a new position. It will push and pull your body with a force that has a "similar" sense of direction to the real life situation.
    To be continued. ........... next post
  4. Bruceaust
    Bruceaust Member
    CNC Routing
    63Coins
    I offer these ideas as a discussion on this important aspect of our hobby.
    All the sims that have been made by guys of this and other forums have one main aim: to try and fool the brain into thinking we are actually driving a “real” racimg car. So he closer we can get our sims to deliver forces that simulate to forces in a real car the more realistic our simulation experiences should be. This is why my next sim will have this in mind.
    By having the center of rotation at the “eye ball”, when braking the force applied to your body pushes on your chest as the sim rotaes in a forward direction. And vice versa, when accelerating the force applied when rotating the sim up and backwards needs to push on your back – just as it is in the real car. This can only be achieved when the center of rotation is at the top of your body ie: at or above your head. The same argument applies to lateral moves from side to side.
    Thoughts anybody?
  5. bsft
    Got a sketch of what you mean?
  6. Bruceaust
    Bruceaust Member
    CNC Routing
    63Coins
    This is the idea:
    152,517Coins
    +11,082 / 56 / -2
  8. Bruceaust
    Bruceaust Member
    CNC Routing
    63Coins
    Thanks Dave and noorbeast I will check out the other threads.
    As always somebody has already thought of it first ,ha ha
