Showroom "cheap" 6 dof odrive actuator motion rig (with lots of issues ^^ )
Discussion in 'DIY Motion Simulator Projects' started by Joey, Nov 13, 2021.
  1. Will974
    Will974 Active Member
    Industrial Ingeenering Teacher
    Reunion Island
    953Coins
  2. Walysson
    Walysson New Member
    52Coins
    Arduino, 6DOF
    Hello, I've been studying about Odrive for some time, I've seen many variants and I have some questions and maybe ideas.
    as well as two motors, a 56v board.
    consuming
    example: [a 190 kv / 65 amp / 2450 watt motor]
    (130A + 4900 watts)
    maybe the board could not support taking so many watts for the motor to give the best torque ??
    I usually see you connect the two motors from an Odrive board to the following actuators
    example ( the two front actuators . when there is acceleration it makes the two actuators go up at the same time, remembering that . when the /voltage / that enters the plate would not be enough to give the best to the motors?
    Does what I said make sense?
    a solution I thought
    1 - use pulley system! where we can increase the motor torque one gear tooth ratio.
    2 instead of running both engines on the Odriver.
    use a separate 60amp ESC and use only the hall and pwm sensor plug from the driver board.
    I'm Brazilian, I really want to start my project, I'm studying a lot and I'm having a lot of doubts about how to deal with all this.
    I hope you'll forgive me for the text. And if you do, it doesn't make sense because I'm awake at 3:58 am typing this will I want Odrive to become a solution for those who don't have as many conditions to invest as I do
    health and peace
