value1
City Car Driving Plugin 2.0.8.3
SimTools game plugin for City Car Driving
  1. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    Can you explain a litte further what you have done @spyderwash. For example what are your settings for pitch, roll and yaw in the SimTools profile and Tuning Center?
  2. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    I set the standard profiles but I saw that in Tuning Center see only two data and play while I did not even have to initiate changes
    Capture Max Min?
    154,849Coins
    +11,228 / 57 / -2
    City Car driving only supports pitch, roll and yaw and yes do run Capture Min Max.
  4. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    thanks
    Today I run the tests if I can not do video
  5. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    I tried to run again capture but no change from game data inputs receive only roll and yaw, but no change in value remains fixed not have to change some parameters in the game?
    154,849Coins
    +11,228 / 57 / -2
    Could you please post a picture of your SimTools and Tuning Center settings @spyderwash.
  7. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    154,849Coins
    +11,228 / 57 / -2
    I think @value1 may need to check for changes between game version 1.4 and the 1.4.1 patch released on 10th March 2015. Looks like the patch broke pitch.
  9. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    What should I do, who can I ask to fix the problem?
    154,849Coins
    +11,228 / 57 / -2
    I just flagged the update issue with @value1 in my last post and I am sure he will look into the plugin as soon as he is able.
  11. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    ok thanks wait
  12. value1
    14,306Coins
    :D Yes, 1.4.1 is not compatible with the plugin. I think I have an update handy at home…
  13. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    perfect I would be very happy to try and do the test as soon as possible;);)
  14. value1
    14,306Coins
  15. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    now works perfect thanks:thumbs:thumbs:thumbs:thumbs:thumbs;)
  16. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    Now that is what is called real service support, thanks so much @value1 :thumbs
  17. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    you can not have other forces besides pitch roll and yaw as acceleration and braking?
    It has a gambling problem or plugin? it would be nice aumentre its capabilities
  18. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    The City Car Driving plugin only supports pitch, roll and yaw, hence I am guessing that there are real technical limitations to what is possible, because if that were not the case @value1 would already have added other forces.
  19. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    it's a shame they can not develop the plugin:(
    anyway thanks for your development work:thumbs
  20. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    If you are having problems then start your own thread and post pictures of all of your settings, that way members can advise what to try to get your moving.
