Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. mrbeginner
    mrbeginner Active Member Gold Contributor
    What ever come in my way
    Finland Niinisalo
    - 40Coins
    Hi!
    I have problems with surge and sway in my other pc with Dirt rally. Tuning center shows little movement when car is still, but after i start to drive both axis go to zero. I patched game few times, Set hardware settings in my games folder, Put plugin again in game manager, delete hardware settings and start game again and after that set settings again. Try to copy settings on other pc and still not movement. every other game work ok. I have some problems with first pc too but they was solved with this thread. Pc is win 7 64-bit.
  2. Ali Khaleghi
    Ali Khaleghi Engineer
    161Coins
    3DOF, 4DOF
    thanks!, this is awesome.
  3. mrbeginner
    Finland Niinisalo
    - 40Coins
    I found out that surge and sway works in rallycross but not in rally or hill climb. I try to delete all game folders in pc and reinstall the game hope that works.
  4. mrbeginner
    Finland Niinisalo
    - 40Coins
    Reinstall don't help. I don't know anymore what i can do. Only thing is i don't play that game.. Do you have any idea because i try all in this thread.
  5. Nick Moxley
    17,057Coins
    If your getting some forces and not other's. Its not the game's fault, its something with YOUR setup.
    FYI Sway is a Super sketchy force in Dirt Rally, I wouldn't bother wasting too much time with it.
  6. mrbeginner
    Finland Niinisalo
    - 40Coins
    Maybe the sway it's not so important, but surge is because i don't feel when brake is working. I must try other screen if that help and change hdmi in different output.
  7. Nick Moxley
    17,057Coins
    Post pics of all your Simtools setting's including the tuning center and we can go from there.
  8. mrbeginner
    Finland Niinisalo
    - 40Coins
    I found the problem after a long weekend. I change graphics settings and after that it works. If i put auto settings everything ultra low then surge and sway stop working. If settings are greater than low then everything works ok. I try to find out what quality setting make that problem after i enjoy few stages in rally.
  9. Trafalgar
    Trafalgar New Member SimAxe Beta Tester Gold Contributor
    13Coins
    @mazak515 Have you looked on this forum here?
    I do not have a G25, but it helped me a lot for my FANATEC :thumbs
  10. Historiker
    Michigan USA
    9,212Coins
    I would like to take a moment and make a comment about this plugin.....
    OUCH!
    Boy howdy does this plugin work well. I am pretty sure that I have bruises in places that I would have difficulty explaining to a doctor. Rally drivers must be made of rubber.....
    Thanks again for the plugin! :)
  11. SeatTime
    While never really 'smooth' the suspension on a modern rally car is actually quite compliant. If you are getting bruises maybe you have it set a bit 'too' hard, but I know 'because race car' :D.
  12. Historiker
    Michigan USA
    9,212Coins
    I cannot comment on pirated software but the plugins works with the legal licence for the game that I have.
    Please do not discuss illegal activities on this forum.
    • Agree Agree x 5
  13. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Are you seriously here in this forum reporting to us about using pirated software? Thats a special kind of dumb man.
  14. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    I left out a few words between "but" and "the plugin".. I happen to hear that it does not work with....
    Anyway the point is I would like to confirm the plugin works well or not...before buying the game..
    Sorry if there is any illigal meaning..
  15. Nick Moxley
    17,057Coins
    common guys, No need to tear him a new one. :p
    hb kim, Dont feel bad, i did the same with Pcars beta back when, as i knew it was questionable content and Boy am i glad i did but honestly fear not, Dirt Rally really is the BEST of the BEST for current rally games....Dont even bother looking into that other freshly released rally game, its junk in yo trunk from initial reviews. :grin
  16. Historiker
    Michigan USA
    9,212Coins
    Again, please do not discuss software piracy on these forums. Regardless of the reason. Final warning.
  17. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    I LEGALLY purchased Dirt rally on Steam today.. But, unfortunately, the motion is something wrong.. At first it moves like a jitter?? So I tried tunning but no improvement. Stopped the car and watch the value from the game in tuning center, found out that some values are still moving weird even my car firmly stopped on the road. Tried repatch, delete hardware settings, full screen, udp port change,extra change...play again and again, suddenly motion does not move at all while I can see the tuning center is still getting the value(but weird value).
    Anything worth trying left??
  18. noorbeast
    154,849Coins
    +11,229 / 57 / -2
    Have you run through all the steps for creating a motion profile, including establishing base settings for the Tuning Center: http://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  19. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    Yes, I did axis settings as well.. Not exactly the same as your link above, but I have done those steps and works well with Assetto corsa and FSX. It is not that kind of setting I guess, some people seems already had the same issue like I read above. But not sure how they resolved their problem. Udp setting in XML, re-patch..etc.. They seemed just happended to make it work.
  20. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    Finally I made it.. It was language setting. I changed it to English and then work perfectly.. I thought it was not that important so that I rather focused on patching and editing .XML. Now that I think of it, it was already on the FAQ list. Not only dirt rally but also some other games that I had problems with goes away with the language setting.
