Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. piorck
    piorck Member
    french
    258Coins
    dirt past to 1.03 version seen 02 feb , is the plugin is ok or you do patching for new version?
  2. piorck
    piorck Member
    french
    258Coins
    sorry for double post but i'll don't edit my msg .
    remeber me the folder to install the dirt plugin pls
  3. sliversgyj
    sliversgyj New Member
    - 27Coins
    can I use this together with simvibe
  4. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    On dirt rally first page, it just says v1.0 so I am not sure it is 1.03 or 1.0. Anyway I downloaded it on 06-feb. You can check the folder on a pop-up window that comes up when you click on the patch button on the game manager. It is ~~my games/dirt rally.
    154,711Coins
    +11,212 / 57 / -2
    Patch to the Dirt 3 in the My Games folder, which you will find in My Documents.
  6. Historiker
    Michigan USA
    9,212Coins
    Yes it works fine.
  7. sjmy
    sjmy i like a wind
    china
    194Coins
    2DOF, SCN5
    Thank you:cheers
  8. sjmy
    sjmy i like a wind
    china
    194Coins
    2DOF, SCN5
    me too..
    my Dirt rally is ver 1.0 ,some err value readform tuning center.
  9. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    Try language setting below and see if it works, then you can use Local emulator
    Control panel - language - change date, time.... - administrative - language for non-unicode programs : set English
  10. sjmy
    sjmy i like a wind
    china
    194Coins
    2DOF, SCN5
    thank you
    fix this bug need to change windows language? very interesting
  11. eaorobbie
    20,506Coins
    Slight correction this only correct for 64bit version
    32 bit you need to patch the installed directory of Dirt Rally.
    Opps
    • Informative Informative x 3
  12. piorck
    piorck Member
    french
    258Coins
    i'll do the patch in the directory but the game no runing my T1000 .
    i'll test to copy the files in the other directory (to my games ) but no runing too
  13. BlazinH
    16,703Coins
    Contact the manufacturer of your T1000 then! Why do you Prosimu buyers keep asking for support on a Do-it-Yourself website when the manufacturer of your non-DIY (commercial) rig should be taking care of you?
    • Agree Agree x 4
  14. Boomslangnz
    4,172Coins
    hmm this plugin wont work for me anymore and I'm not sure why. I firstly updated plugin but no tuning numbers ingame even tho it says its connected etc, then I deleted it and did it again and same thing. I then went and changed the stuff in hardware_settings_config and still no go
    Plugin used to work fine with no problems at all so I'm not sure what else to try
  15. noorbeast
    154,711Coins
    +11,212 / 57 / -2
    Just checking, have you tried all the steps @value1 outlined here: http://www.xsimulator.net/community/threads/codemasters-dirt-rally-plugin.6823/page-11#post-93948
  16. Boomslangnz
    4,172Coins
    cheers @noorbeast that did the trick. took ages to verify but everything going now
  17. noorbeast
    154,711Coins
    +11,212 / 57 / -2
  18. eaorobbie
    20,506Coins
    Sorry not a support device on Simtools
  19. piorck
    piorck Member
    french
    258Coins
    désole mais prosimu nous indique de télécharger ce logiciel pour faire fonctionner leur simulateur , ils n'ont pas de logiciel développé par leurs soins !
    voyez avec eux si vous ne voulez plus voir d'acheteur de simu prosimu pour qu'ils développent leur propre logiciel
    ps : pas de traduction en anglais car je n'ai plus le choix de cette sélection dans le choix de traduction
  20. Historiker
    Michigan USA
    9,212Coins
    https://translate.google.com/
