Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. Vef445
    Vef445 Active Member
    Denmark
    597Coins
    Bringing @Avenga76 back on this thread :) I know your post is almost one year old, but since I meet the same problem... Full screen really was your only change? I have the exact same behaviour in full screen :(
  2. matrixpascal
    matrixpascal Member
    305Coins
    Hello.
    I have a small problem.
    I would like to start simtools and simdash.
    the problem is that for simtools in the next line
    Documents / my games / Dirt Rally / hardwaresettings / hardware_settings_info
    I <udp enabled = "true" extradata = "3" IP = "127.0.0.1" port = "4123" delay = "1" />
    and to operate simdahs I must:
    <Udp enabled = "true" extradata = "1" IP = "127.0.0.1" port = "20777" delay = "1" />
    as soon as I change the port or is simtools works or is simdasch.
    I asked myself if I want to run with the simtools 20777 Port How do I do
  3. Vef445
    Denmark
    597Coins
    Just copy both lines, it will work ;)
  4. matrixpascal
    matrixpascal Member
    305Coins
    that's what I did but it does not work either.
    when I write 2 lines only works simdash simtools telemetry not working.
    So I have no movement
  5. matrixpascal
    matrixpascal Member
    305Coins
    I do not know why but now it works by writing the two lines.
    thanks anyway
  6. Vef445
    Denmark
    597Coins
    Up :(
    Telemetry data seems to be somehow related to graphic settings: few people got similar problem solved by changing the graphical options or rendering in full screen, and I notice when setting up the game on "ultra low" we loose this data.
    I've tried everything from drivers update to switch from win7 to win10, all possible graphical options and still go the same issue :(
    @value1 , could it be possible to add a filter in the plugin itself? Something simple like "if sway = 0 and roll is not 0 then ignore sway value" This way the plugin would ignore all those zeros unless the game is actually stopped/paused.
    I'm keen to hear every other suggestion :)
  7. piorck
    piorck Member
    french
    258Coins
    i'll do redownload the plugin and install this to diretory and now .........................................................
    my sim T1000 make the mouvement also !!!!!!!
    i'm happy
  8. GTHQ_koop
    GTHQ_koop Active Member
    Something with airplanes..
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    Finally bought it as it was 0% off :)
    How much coins do I need for the download..? Is unavailable right now..(or am i missing something again :p)
  9. stevemontuno
    stevemontuno Active Member
    1,461Coins
    154,711Coins
    +11,212 / 57 / -2
    You will need to use 250 coins here to get 1 weeks access to all plugins: http://www.xsimulator.net/community/shop/
  11. Trafalgar
    Trafalgar New Member SimAxe Beta Tester Gold Contributor
    13Coins
    Hello everyone, since the last update (Version 1.2), I have more movement on the surge and sway axes. I deleted the file hardware_settings_config in Steam and I deleted the DiRT Rally folder in My Documents. I uninstalled and reinstalled the plugin after deleting all data Simtools on DiRT Rally. The problem persists, only these two axes do not work and I see it on Virtual Axes.
    I would want to know if other people have the same problem or if it is my installation.
    Thank you in advance :)
  12. Vef445
    Denmark
    597Coins
  13. Trafalgar
    13Coins
    @Vef445 , I had already tried with your plugin, but it does not solve my problem. Simtools work properly after this update with you?
  14. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    @Trafalgar mine did the same not sure if the update had anything to do with it but mine is now all ok not sure how as all i did was remove all trace of dirt rally in all folders found here
    C:\Users\Daguru\AppData\Local\SimTools ( swap daguru with your username of course ) re installed plugin and patched for motion then went to C:\Users\Daguru\Documents\My Games\DiRT Rally\hardwaresettings copied hardware_settings_config and pasted it in here C:\Program Files (x86)\Steam\steamapps\common\DiRT Rally\system (your dirt install folder)
    i have no idea how or why the sway, surge and heave motion came back but its worth a try hope you fix it i was gutted when it happened to me
  15. Trafalgar
    13Coins
    @Daguru , sorry for the late reply, but I was on holidays :D. I tried the method, but it does not work for me, thank you anyway. I would make just a clarification, the axes Heave, Roll and Pitch are working well. Someone has another idea ?
  16. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    I have the same problem as you, i hope someone can help us
  17. Rudolf Jan Horak
    Rudolf Jan Horak Member
    Simulator Maintenance Student
    Devils Lake, ND
    274Coins
    Motion platform
    Will this plug in work for all versions of the PC game? I am still new at the coin concept, so when I hit the 250 coins I can have access to the collection of addons for a week where I can burn up to my 250 coins but only have one week to do it?
  18. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Plugin works with steam version which as far as I'm aware is the only version out ( steam keeps it up to date )
  19. noorbeast
    154,711Coins
    +11,212 / 57 / -2
    If you mean will this plugin work with all the different PC games Codemaster puts out then no, each has its own plugin which can be found in the Plugin Download section, for example:
    https://www.xsimulator.net/community/marketplace/codemasters-dirt-showdown-plugin.18/
    https://www.xsimulator.net/community/marketplace/codemasters-dirt-rally-plugin.140/
    https://www.xsimulator.net/community/marketplace/codemasters-f1-2016-plugin.169/
    https://www.xsimulator.net/community/marketplace/codemasters-f1-2014-plugin.131/
    https://www.xsimulator.net/community/marketplace/codemasters-f1-2013-plugin.72/
    https://www.xsimulator.net/community/marketplace/codemasters-f1-2012-plugin.21/
    https://www.xsimulator.net/community/marketplace/codemasters-f1-2011-plugin.20/
    https://www.xsimulator.net/community/marketplace/codemasters-f1-2010-plugin.19/
    https://www.xsimulator.net/community/marketplace/codemasters-dirt-3-plugin.17/
    If you mean where there may be a Steam and CDROM version, say like Dirt3, then as long as they are the same then the plugin will work, but if the CDROM version is changed for Region or language or does not have the same updates then no. I had no problems with the Steam and CDROM version of Dirt3, both worked.
    Yes you can download as many plugins you want with the coin purchased access, but only for 1 week: https://www.xsimulator.net/community/faq/coins-how-to-get-them-and-how-to-give-them.74/
  20. tomato
    tomato New Member Gold Contributor
    - 99Coins
