Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. Driftmachine
    Driftmachine New Member
    550Coins
    Does this program do anything with butt-kickers? I have simvibe(sim commander 3) but it don't support this game. I am assuming this program does things the other don't. I am trying to figure how to use telemetry data to work the transducers. I need more intel to know what I am doing and how to go about it.
    154,711Coins
    +11,211 / 57 / -2
    Not yet @Driftmachine, @yobuddy is working on adding transducer support to SimTools but it is not yet known when that will be completed.
  3. SilentChill
    20,661Coins
    Yeah I have but its just odd the way it is working , maybe something i need to look into :)
  4. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    @Blame73 - Yeah, set the tuning levels low. Trouble is the green data (that constantly moves) just stays at 0 on Heave, Surge and Sway, while all the other data is fine.
    However, every now and again it will spit out a large number, causing my sim to jump and jolt, so I've turned off those axis for now until fixed / resolved.
    Is everyone else OK with the plugin? Wondering what could be different on mine seeing as we all have the Early Access Steam versions.....
  5. michto35
    michto35 Member
    france
    92Coins
    With the plugin I had to capture the tuning center, because by default the simulator was moving all the time and was really different dirt 3.
    after the capture i am very happy with the result
  6. Archie
    Wollongong, NSW, AU
    3,797Coins
    I'll post a video at some point so everyone can see what I get on the problem axis.
  7. value1
    14,295Coins
    Did you select "C:\Users\mazak515\Documents\My Games\DiRT Rally"?
  8. value1
    14,295Coins
    Can you try to patch "C:\Users\mazak515\Documents\My Games\DiRT Rally"?
  9. Archie
    Wollongong, NSW, AU
    3,797Coins
    Fired up Dirt Rally tonight to capture the issue I have been having, and yup... works a treat now... No idea what caused the original issue, but all fixed.
    What a game!! What a plugin!!!! :D Thanks again @value1
  10. Pit
    30,517Coins
    I have run into the same issue, I am going to check it out now, thank you @value1 ;)
  11. value1
    14,295Coins
    Thank you all for your feedback. Always good to hear that something is fixed and working :)
  12. Archie
    Wollongong, NSW, AU
    3,797Coins
    For those struggling to patch, you may need to run the game first, create an "Autosave" and then quit the game and try to patch to the folder.
    I think I needed to do this on mine as I played with the Resolution settings and I seem to recall the folder was created after I did that...
  13. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    Is there a way to use simdash and simtools simultaneously ?
    I saw that simtools already use the same setting in the XML file (motion enable).
    I suppose if I put the same port to listen in simdash it will do a conflict with simtools ?
  14. gigi
    gigi Active Member
    920Coins
    2DOF, JRK, 4DOF
    I installed the plugin but whe I try to patche the game ...I go in edith patch then I select steam/steamapps/common/DIRT Rally I receive the message "the selected patch is not valid for patching"
  15. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Download this tool: Codemasters Proxy Server
    http://www.eksimracing.com/cmps/
    And follow guides.
    You can forward data from one port to other ports and devices that will use it.
    • Informative Informative x 3
  16. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    Thanks prodigy it is exactly what I need !
  17. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    In fact it doesn't work... :(
    GameEngine crashs while extradata="1" in the motion tag.
    I tried with API 1, 2 and 3 in the proxy server and it is the same result : crash.
    And there is no option API 0 to hide extradata.
    It works only while extradata="0" in the XML, but in this case, logicically, no extradatas (speed, time, rpm...) are sent to the proxy...
  18. gigi
    gigi Active Member
    920Coins
    2DOF, JRK, 4DOF
    thank you for support. Now it works fine
  19. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    How it is with Dirt 1/2/3 & F1 series ?
    Does simtools support the extradata attribute enable in the motion tag or is it the same problem ?
  20. prodigy
    Croatia
    6,698Coins
    That's weird, Simcommander4 works with Dirt Rally + Extradata=3 and other devices works too.
    I suppose Simtools can work that way too, maybe the plugin need's to be revised.
    My guess is it was copied from Dirt 3 and that one was crashing GameEngine with anything else other than Extradata=0.
    I don't remember what Extradata were used in other Codies games with Simtools..
