Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. yobuddy
    51,781Coins
    ah right, different plugin author.
    Got to love plugin options!
  2. yobuddy
    51,781Coins
    I'm using steam dirt rally also.
    You just need to race one race before patching.
    (It's like this for most cody games)
    There is nothing special about the patching of this game.
    Its just like all other cody games.
    Don't think so, no.
    Take care,
  3. yobuddy
    51,781Coins
    You can probably find the device in device manager.
    Then right click it and select uninstall.
    Then reboot and let it re-install the driver for the "new device".
    I believe it should correct the problem buddy.
    btw, this is a known problem of the current update that is going out i believe.
    The update even has enough problems with some hardware, that Microsoft actually blocked the update for some SSD's and Toshiba laptops.
    For any one else reading this, I'd give it a week or so before updating.
    Take care,
  4. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Anyone knows the Dirt Rally location on the C drive? I need to Patch it...
    Let me know?
    Best
    Milton
    154,849Coins
    +11,229 / 57 / -2
  6. yobuddy
    51,781Coins
    Only one app can be connected to a single COM port at the same time.
    In most cases the fist app will block the second one all together.
    Take care,
  7. yobuddy
    51,781Coins
    You just need to hit the finish line of a single race is all.
    (so it updates the save file)
    This is really only needed for Cody games btw.
    For Dirt Rally,
    Un-patch the game with SimTools, launch the game and finish a race.
    Exit the game and then patch it with SimTools.
    Setup SimTools for the Game and you should be good to go.
    Take care,
  8. yobuddy
    51,781Coins
    First, Please open Game Engine's 'Tuning Center' and verify you are getting incoming data from Dirt Rally when the game is playing.
    154,849Coins
    +11,229 / 57 / -2
    Don't use the Rift while trouble shooting, use a screen.
  10. yobuddy
    51,781Coins
    Do you have data coming into the Game Engine's 'Tuning Center' thou?
  11. sam poole
    sam poole Active Member
    midlands
    38Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF, 6DOF
    Does anyone else have the pitch axis working in reverse on the Hill climb tracks?
  12. yobuddy
    51,781Coins
    If pitch is backwards, simply click the little Dir (direction) box for pitch in the axis assignment settings (game engine) for the game.
    Take care,
  13. sam poole
    midlands
    38Coins
    thanks yobuddy tremendous work btw but the problem is when i do that all the other tracks in the same game are then the opposite direction
    thanks for that it was still working off of the project cars profile i was convinced id saved it
  14. Psionic001
    Psionic001 Active Member Gold Contributor
    Sydney
    997Coins
    Motion platform, 6DOF
    Like many others I had no Surge/Sway data.
    For ME it's 100% solved by changing the graphics quality to ULTRA, but has anyone figured out why the data is affected by the graphics setting?
  15. nicopoche
    nicopoche Member
    Musician
    259Coins
    I have the same problem ( surge & sway don't work )... I tried everything I found on that forum ( region, graphic settings, full screen, different patchs, patching & depatching, desinstall & reinstall... ). I think Dirt Rally is not made for my PC :grin unfortunatly....
  16. Psionic001
    Sydney
    997Coins
    What graphics card do you have.
    Increasing to full high quality absolutely works consistently (I use Nvidia 1080Ti).
  17. nicopoche
    nicopoche Member
    Musician
    259Coins
    Thx for your replay :cheers
    I have a 1070, and i run the game in "Ultra" mode already... As you say, I wonder how the graphical settings can affect telemetry ^^
    I will have a Vive very soon, maybe changing the resolution or running it in VR will hopefully solve the problem... A miracle :grin
  18. dr.feelgood
    dr.feelgood Member Gold Contributor
    FINLAND
    484Coins
    Hi! Just to confirm that I had also difficulties to get motion working after resetting my computer. But I think the main things were regional settings, graphics settings (everything above low) and plugin from @Illuis. I use latest Simtools. Dash was problematic with other plugin, but with this one it works also...
    https://www.xsimulator.net/community/marketplace/dirt-rally-plugin.205/
  19. nicopoche
    nicopoche Member
    Musician
    259Coins
    Big news !!!!
    I received my Vive. And guess what !? Telemetry works like a charm in VR !!! If i launch the game again without the Vive, telemetry doesn't work ! ( surge & sway )
    So strange but I feel very lucky ! maybe it will help to find the final solution to that "bug";-)
  20. Jaysonchou111
    Jaysonchou111 New Member
    188Coins
    thank you ,i realy like this game
