Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. Benji85
    Benji85 Member Gold Contributor
    851Coins
    It's really good in vr with motion isn't it? :)
  2. Benji85
    851Coins
    Sorry for necro.. but what was this tip noorbeast? Do you remember? I suffered judder for ages on driver 388.59 - only when asw kicked in but still very distracting.
    I read 384.94 was a better driver for vr so I tried it and it's much better in dirt - no judder from asw constantly trying to turn on and off.
    154,849Coins
    +11,229 / 57 / -2
    Sorry no.
    In general judder can be induced by anything that delays processing a frame within an allotted time. So poor drivers, running background processes, game graphics settings and the like can all be contributing culprits.
  4. Benji85
    851Coins
    Roger that all good tips. Less is definitely more when it comes to processes and gaming!
    154,849Coins
    +11,229 / 57 / -2
    I have donated enough coins, but see my PM re contributing relevant posts to earn coins for plugin access.
  6. optical10
    optical10 Member Gold Contributor
    694Coins
    My FPS drops down to single digits when this plug-in is enabled, anybody else getting that?
  7. yobuddy
    51,781Coins
    @optical10 you on SimTools v2.3?
    Have you updated GameVibe and GameDash also?
    Chat soon,
  8. Trafalgar
    Trafalgar New Member SimAxe Beta Tester Gold Contributor
    13Coins
    @optical10, no, I do not have any problem like this, but I'm still on version 2.2 of simtool :think
  9. Flash66
    Flash66 6DOF Motion over the ocean in DCS FA/18-C
    Engineer
    Las Vegas NV
    154Coins
    I have the Oculus store version of Dirt Rally and cannot get telemetry to work. Game patched fine but Game manager doesn't say game running when Dirt Rally is launched. in hardware config I have a line under motion platform : <udp enabled="true" delay="1" port="4123" ip="127.0.0.1" extradata="3"/>
    Any ideas?
    154,849Coins
    +11,229 / 57 / -2
  11. Flash66
    Engineer
    Las Vegas NV
    154Coins
    Hi Noorbeast, I figured it out although the solution is kind of crude. It appears Simtools is looking for the filename drt.exe to flag the game as running. On the Oculus store the name of the .exe is drt-vr.exe. Changing the .exe name results in an error but flags simtools to show running. If I create a copy of the .exe, naming it "drt.exe" and run both files leaving the error on the screen for the invalid file name drt.exe in the oculus build, and sequentially running drt-vr.exe everything works fine as it leaves simtools in a "running" state. If I hit OK on the error for invalid .exe and close the window, simtools goes back to "connected" I searched inside the plug-in files to see of I could change anything, but nothing pointed to the executable name to possibly edit. At least it does work crudely.
  12. noorbeast
    154,849Coins
    +11,229 / 57 / -2
    Most plugins are built against the Steam version of games and if there are any fundamental changes to a game it will result in problems.
  13. BlazinH
    16,704Coins
    I believe both Simtools and Steam needs to see whats consided the valid filename for both to function. Just needs a plugin update.
    Edit:Just noticed you said Oculus store not Steam.
  14. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Can you try something else, I remember I had to do something similar years ago with F1 2013 game..
    Go to C:\Windows\system32\cmd.exe and copy this cmd.exe file, than paste it on your desktop. You need to do Copy-Paste, no shortcut.
    After putting cmd.exe on your desktop, rename it to drt.exe and run it.
    A CMD window will opet itself and Simtools will think that Dirt is running, but there will be no error messages.
    Just leave the window in background and then start the real game.
  15. yobuddy
    51,781Coins
    @Flash66,
    Plugins can have multiple trigger exe names.
    Since you have confirmed it works, i think all we need to do is add "drt-vr" to the trigger list.
    Ill take a look at it tomorrow.
  16. Flash66
    Engineer
    Las Vegas NV
    154Coins
    Hi Yobuddy, That's absolutely great news! The only reason I bought the oculus version was because of the $24.99 price as opposed to $39.00 on steam. I had my doubts about patching it but thought what the hell. Glad to know there's at least a work-around and that it may help other folks. Much appreciated you're looking into the trigger list to update!
    @prodigy, Thank you as well for the advice.
  17. noorbeast
    154,849Coins
    +11,229 / 57 / -2
    You should keep an eye on our game discount thread and you will likely find Steam to be cheaper, for example you could have got Dirt Rally for $9.99, which if you go back in that thread is often the Steam Sale price: https://www.xsimulator.net/communit...fers-steam-sales-etc.6143/page-20#post-164616
  18. Flash66
    Engineer
    Las Vegas NV
    154Coins
    No friggin way! I think I bought the title just after midnight so it showed at full price! I spent the evening swapping flight controls to driving controls for the first time and must have just missed the sale as it showed $39.99 on steam when I went to purchase. Thanks for the info mate! Bookmarked the thread twice lol!!
  19. optical10
    694Coins
    Sorry for the delay had to change my motherboard. I installed Sim tools 2.3 so do you mean that every time I upgrade Sim tools I have to upgrade GameVibe and GameDash? I use Sim racing studio vibration software would that make a difference or cause problems with GameVibe?
  20. yobuddy
    51,781Coins
    SimTools v2.3 requires GameDash and GameVibe to be updated also.
    its not required every time, but it is for this release buddy.
    You probably can't use them at the same time, but you would have to try it to see.
    It may depend on the game, but I personally have not tried this setup, so I can't say for sure.
    Take care,
