Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. dedraro
    dedraro Active Member
    124Coins
    a screenshot of what happens, the values increase by themselves as you can see in tuning center, they increase without stopping, they even reach over 10,000 if I leave the game open, even without doing anything
    https://i.postimg.cc/44nZBcBc/Immagine.png
    EDIT: sorry I was missing this parameter:
    <custom_udp enabled="true" filename="SimToolsCustomUDP.xml" ip="127.0.0.1" port="4123" delay="1" />
    Now everything works fine. :D
  2. botty
    botty New Member
    21Coins
    great work! thanks for that
  3. weachi
    weachi New Member
    30Coins
    AC motor, Arduino, 4DOF, 6DOF
    Hello brother, my dirt has not moved, I have added it as you said
    &lt; Udp enabled="true" extradata="3" IP ="127.0.0.1" port="4123" delay="1" /&gt;
    &lt; Udp enabled="true" extradata="3" IP ="127.0.0.1" port="10001" delay="1" / >
    It still doesn't work, only the first one rises. What's going on here
    154,723Coins
    +11,213 / 57 / -2
    Before getting into other possibilities what patch path are you using to patch Dirt Rally for motion?
  5. weachi
    weachi New Member
    30Coins
    C/file/my game//Dirt Rally
    154,723Coins
    +11,213 / 57 / -2
    The path for patching Codemaster games for motion differs, depending on it being a 32bit or 64bit version of Windows.
    32bit is patched to the game install path.
    For 64bit Windows Dirt Rally is patched to C:\Users\Your_User_Name\Documents\My Games\DiRT Rally
  7. chrisgeo
    chrisgeo Member
    111Coins
    Thanks noorbeast, but is it possible that the Steam Version uses a different path for the save games, because I can’t find my save games and therefore can’t patch the game for using simtools. Or is it me just getting to old?
    154,723Coins
    +11,213 / 57 / -2
    Steam installs games to: C:\Program Files (x86)\Steam\steamapps\common\
    But only 32bit Windows Codemaster games are patched to the install directory.
  9. chrisgeo
    chrisgeo Member
    111Coins
    I made it, it now works, but to be honest I don't know why. But it works and that is what counts.
  10. Kenshiro27
    Kenshiro27 Active Member
    253Coins
    2DOF, 3DOF, Arduino
    Hi yobuddy,
    I have a problem with this plugging, I specify that all the rest of the games work nickel
    but with DIRT 2 it does not work
    I also specify that I have already written what was needed in the Xtlm files
    and when I look in TUNING it displays crazy values like 6593 for pitch or 1756 for Surg
    A generous girl would have an idea
  11. yobuddy
    51,751Coins
    There is nothing to edit by hand, just patch the game and your done.
    Take care,
  12. Kenshiro27
    253Coins
    2DOF, 3DOF, Arduino
    indeed my access path to the patch was not perfectly placed and caused crazy values, thank you very much:thumbs
