Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. Atlas974
    Atlas974 old school
    Physics chemestry
    Reunion island
    358Coins
  2. Wanegain
    Wanegain Active Member
    Bruxelles
    2,021Coins
    Thank you so much !!
  3. zigzag49
    zigzag49 Active Member
    726Coins
  4. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    Thanks for update :thumbs
    I just read this in update news maybe helpfull for someone using gamedash
  5. Wanegain
    Bruxelles
    2,021Coins
    The last plugin is not working for me... Is there something to do?
  6. Wanegain
    Bruxelles
    2,021Coins
    Now it's working. I had to delete the hardware_settings_config file and scan the files with Steam. Launch the game a first (to create again this file) and then after patching the game it's working ! Thanks again :thumbs
  7. servili007
    servili007 New Member
    NY
    212Coins
    Looking forward to this, thanks for keeping it updated.
  8. zigzag49
    726Coins
    Merci wanegain sa fonctionne maintenant:cheers
    Thank you wanegain it works now
  9. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    Thanks wanegain,
    I first had problems with the new plugin but with your solution it works again.
    I try to find out how the second udp port can be enabled like described by codemasters to use it with gamedash. So i don't need the other programm too.
    Can someone help with this?
  10. eaorobbie
    20,506Coins
    gamedash doesn't need another port to run , The Game Manager feeds it the data we have chosen from the plugin
  11. eaorobbie
    20,506Coins
    And I had to manually edit cfg file to make the new plugin work. But did try to unpatch and repatch.
  12. T-Man
    T-Man New Member
    Telecommunications
    Adelaide
    149Coins
    2DOF, SCN5
    Hi guys wondering if you can help I have tried the delete of the hardware_settings_config file and then then tried to run the Verify Integrity of Game Cashe. setup new hardware profile in game still no go tried again without verify game cashe and no go. I have a feeling its port blocking issue but not sure, any ideas?
  13. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    This is what I did to get Dirt Rally working for me, it might help someone else:
    First I backed up my Max and Min settings.
    Then I completely deleted the Dirt Rally folder from My Games folder (64bit PC) - I was not bothered about losing Saved Games / Progress.
    Then I manually removed the plugin from Simtools.
    C:\Users\<user>\AppData\Local\SimTools\GameEngine\Config - Delete Axis Assignment (Backed this up first just in case)
    Then deleted DirtRally.cfg file from C:\Users\<user>\AppData\Local\SimTools\GamePathSaves.
    Deleted DirtRally folder from C:\Users\<user>\AppData\Local\SimTools\GameProfiles
    Deleted DirtRally_Plugin.dll from the C:\Users\<user>\AppData\Local\SimTools\GamePlugins Folder.
    Ran Dirt Rally and fired up a custom event. Quit the event and quit the game
    to create a new Saved game folder in "My Games" (64bit)
    Downloaded latest Dirt Rally plugin (1.0.4.0).
    Installed the Plugin via the usual manner.
    Fired up Dirt Rally again and it was working. (Motors shot to centre)
    Even though I had backed up my Axis Assignment and Min/Max file I decided to re-tune, as I noticed my Roll, Sway and Pitch were now reversed from the previous settings I had.
    So I just re-tuned the game one Axis at a time, and it's working fine again.
    Hope this assists someone....
    • Informative Informative x 3
  14. T-Man
    T-Man New Member
    Telecommunications
    Adelaide
    149Coins
    2DOF, SCN5
    Excellent thanks Archie I will give this a try
  15. T-Man
    T-Man New Member
    Telecommunications
    Adelaide
    149Coins
    2DOF, SCN5
    You are the man Archie, it worked a treat. highly recommend doing as Archie advised above. Thanks again
  16. bsft
    I probably missed it , but does the plugin support the ard dash?
  17. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
  18. bsft
    ok, my game dash not working in this. It works in Assetto Corsa and Grid Autosport, but not Race07. I am using plugins off site.
  19. bsft
    game dash crashes everytime I start Dirt Rally, and Race 07. But it works fine for AC and Grid Autosport
  20. Romain Seignour
    Romain Seignour Member
    - 115Coins
    thank's for this plug in ! but is not ok wuth my seat but other software is ok i have see all the patch this is ok but the seat not start all the % in setting output is the same to assetto for made a test and no again !
    i have buy in last time one month for the plug but now i don(t now if the plug are updated sorry for my english and thank you a lot for your return ! ^^ Romain
