Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
  2. abah_masha
    abah_masha New Member
    Indonesia
    130Coins
    I use that interface code, for my default game (LFS) in simtools is work fine for my Arduino and 2 servo's..
    then, and the game (dirt) show's already "patched". i think i wrong game, like Tombo say.
  3. abah_masha
    Indonesia
    130Coins
    Oh my..... i think this is same game.. i think that are series.. like Dirt 1, Dirt 2, Dirt 3...
    but, why when i patching game.. the game are pacthed.
    in that picture, complete path. (C:\User\Public\Documents\CodeMasters\Dirt)
  4. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Plugin is for dirt rally and you are playing dirt 1
  5. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
  6. abah_masha
    Indonesia
    130Coins
    I felt to miss the News (Dirt Showdown, Dirt Rally) ... because I only had 3 games collection of Dirt in the home I've ever played, then I reinstall to try simtools. :blush.. Ok, thank's all, for info.
  7. gorzasty
    gorzasty Active Member
    photographer, IT specialist
    Poland, Wrocław
    1,060Coins
    Today I tried the Dirt plugin, but it desen't work. Virtual axis shows me that Heave is very large and Sway+Surge is often zero, but simetimes jumps like crazy ;( Game patched and connected.
  8. bsft
    Whats the percentages on the axis settings? It sounds like you have them high and the tuning centre nunbers low
  9. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    113Coins
    Hello, my motion isn`t working after the latest Finland addon patch. Anyone else having this issue?
  10. Blame73
    Blame73 Well-Known Member
    8,315Coins
    Hey @bob williams I upgraded and played without any problems with motion. Try patching it again
  11. bob williams
    IT
    Ermelo, Netherlands
    113Coins
    Thanks. I already tried that, but didn`t solve it.. I patched to folder
    C:\Users\JanJoost\Documents\My Games\DiRT Rally
  12. bob williams
    IT
    Ermelo, Netherlands
    113Coins
    Well got it working again.. It seems after the patch the hardware_settings_config.xml is changed.
    Patching with Simtools didn`t work so had to change the values manually
    <motion_platform>
    <dbox enabled="true" />
    <udp enabled="false" extradata="0" ip="127.0.0.1" port="20777" delay="1" />
    <fanatec enabled="true" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
    To:
    <motion_platform>
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="4123" delay="1" />
    • Informative Informative x 3
  13. gorzasty
    Poland, Wrocław
    1,060Coins
    Thx for your help @bsft but I have found what was going on - I run the game in the window. It doesent work then. In fullscreen everything is OK. It's great, especially Finland and heavy landings ;)
  14. welen123
    welen123 Member Gold Contributor
    HongKong
    35Coins
    support dash! Great! thanks for the plugin!
  15. Dusko Dogandzic
    Dusko Dogandzic New Member
    456Coins
    does anyone know how to lookup everything that game outputs trough it i know we can get rpm gear is there any way to get time or distance/damages
  16. bsft
    @welen123 . @value1 , it DOES NOT SUPPORT THE DASH IN Asutralia, probably because its a different version, a genuine steam version. Is there any plans to fix the plugin for us southern hemisphere guys or do I just wait till the next release of simtools.
    @RaceRay , @yobuddy , @eaorobbie
  17. Tonantsa
    Tonantsa New Member
    Finland
    81Coins
    SCN5
    Anyone managed to get Game Dash working? It worked well before update 0.6 but after that it does nothing.
    Dirt Rally doesn't seem to send any data (RPM, gear etc) to Game Dash anymore.
    Any way to get it working again? Extradata is 3 and port 4123. Im running windows 10 and even opened port 4123 from firewall.
    I built that tachometer and would be nice to get it in action again :roll
  18. value1
    14,266Coins
    Worx fine here with V0.900. The plugin outputs Speed, Gear and RPM.
  19. Tonantsa
    Tonantsa New Member
    Finland
    81Coins
    SCN5
    I managed to get it work. It was about my USB-drivers because I updated Windows 10.:roll
  20. bsft
    @value1 . My dash does not work and never did. I spoke to Rob and he informed me of different versions of the game depending where you live on the planet. We can only assume the gsme version for europe is different to australia. I guess i will just have to wait for next version of simtools
    Whenever that is....
