value1
Codemasters F1 2018 plugin 2.0.1.0
SimTools plugin for Codemasters F1 2018
  1. Jeroen Vrancken
    Jeroen Vrancken ProSIMU T3000 Gold Contributor
    CPA
    Netherlands
    - 65Coins
    3DOF, SCN6
    \\When i install the game it works, and when i than play it for the second time all movement is gone. Tuning centere does not detect any movement :(
  2. JohnCrichtonFR
    JohnCrichtonFR JohnCrichtonFR 5 DOF Gold Contributor
    Maintenance Technician
    22Coins
    4DOF, 6DOF
    Can you say more details please ? Your Prosimu works on others games ? You use the default controller of Prosimu ? =>
  3. Jeroen Vrancken
    CPA
    Netherlands
    - 65Coins
    3DOF, SCN6
    using the default controller
  4. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Hey drivers...
    is it possible to have a screen of how you set "Profile Settings" of SimTools for F1 2018?
    I mean how you set the parameters for Roll, Pitch, Heave, Yaw, Sway and Surge.
    Thanks in advance :thumbs
  5. Leandro Kemp
    Brasil
    - 10Coins
    Hello. I'm having trouble moving in the F1 2018. Everything works normally until about 5min minutes of play. After this time the simmotion begins to lose synchrony. At times he does not respond to the movements and suddenly takes a few strides. I thought it would be something in the game. After the Automobilista upgrade the problem still continues. I already tested it on another PC and the same problem happens. During the game I need to restart GameManager and doing this I have another 5-10 minutes to play before the problem occurs again. Would anyone know if it is a game problem, some configuration in the game or in the plugin?
    PS.: Using F1 2017 UDP plugin works normally.
    Thank you.
  6. Jeroen Vrancken
    CPA
    Netherlands
    - 65Coins
    3DOF, SCN6
    I think i figured out what my problem is. When is use simhub i have no motion. Is it posible that simhub blocks the UDP signal to my motion rig (im tools)? In other sims i can us simhub with simtools ithout any problems
  7. yobuddy
    51,741Coins
    Yes, it is possible.
    My guess is which ever program patches the game last works.
    Take care,
  8. Djules
    Djules New Member
    - 175Coins
    DC motor, Arduino, 4DOF
    Hello
    I have the same problem
    improbable engine movement
    I have to do other tests, but actually the problems happen after ten minutes.
    I need to check if there is a relationship with the use of my Simhub dash boardo_O
    A UDP version should solve the problem, as for F1 2017
    Have you considered a UDP version?
    Thank you
  9. Djules
    Djules New Member
    - 175Coins
    The problem persists without using simhub ....:think
    the movements are jerky and inconsistent with the track.
    I will try to reload the plugin to try :(
  10. yobuddy
    51,741Coins
    Every single codemaster game plugin we have is UDP.
    Maybe take a look in your "hardware_settings_config" file and see how the patching looks.
    Maybe the combination of SimTools and SimHub caused the file to be patched in a weird way?
    Take care,
  11. jaguarkiki
    jaguarkiki New Member
    - 98Coins
    3DOF, SCN5
    hello everyone, with the help I can not play f1 2018, I put the zip file in simtools plugins, as I do for the other games but nothing is done .... there is no someone one who can tell me if I'm wrong? thanks again the pilots
  12. yobuddy
    51,741Coins
    Where are you putting the zip files buddy?
    SimTools Plugin Updater?
    Chat soon,
  13. jaguarkiki
    - 98Coins
    3DOF, SCN5
    hello @yobuddy, yes I put the zip file that I downloaded in simtool plugins updapter.
  14. yobuddy
    51,741Coins
    And what happens buddy?
    Is the game plugin available in Game Manger?
  15. Djules
    Djules New Member
    - 175Coins
    Hello
    is it expected to have an udp version plugin of F12018?
    thank you
  16. yobuddy
    51,741Coins
    Maybe you could ask @value1 to compile a Console version of the plugin.
    (It just needs the _ProcessName's removed from the plugin for a test anyway)
    Take care,
  17. Michael Maggio
    Michael Maggio New Member Gold Contributor
    usa
    10Coins
    I have same issue here. installed and patched, but no movement. works in iracing and pc2. help?
  18. DPR
    DPR New Member Gold Contributor
    85Coins
    2DOF, 3DOF, Motion platform, 6DOF
    Hi all.. yes.. i seem to have the same problem. Followed the guide thoroughly (i hope) and no movement. Assetto works fine - F12018 no movement
  19. yobuddy
    51,741Coins
    @DPR,
    Un-patch the game with GameManger.
    now launch the game and complete a race.
    Exit the game and re-patch the game.
    Try again and you should be good to go.
    Take care,
  20. DPR
    85Coins
    Thank you yobuddy.. have tried that.. but unfortunately no joy .. it was a short race and all the other tracks are unlocked.. maybe i'm missing something
