Codemasters F1 2020 Plugin v2.0
SimTools plugin for Codemasters F1 2020
  1. MAYKAMER
    MAYKAMER New Member
    111Coins
    SCN5, SCN6, Motion platform
    thank you very much for your answer ! yes indeed I just managed to make it work with simhub 2018! wonderful I have to test in my team mode if it also works thank you all for your sharing it's been 1 years that I have been looking for solutions! thanks ! thanks ! thanks !
  2. MAYKAMER
    MAYKAMER New Member
    111Coins
    Thank you very much bruno for your help! I would never have succeeded in finding this solution with very precise captures of what to do thank you all for your help and your sharing grazie ! grazie ! grazie !
  3. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, with pleasure everything is going perfect !
  4. marcosrobert
    marcosrobert New Member
    Design Grafico
    Sao Paulo - Brasil
    253Coins
    how do i get the 2020 f1 plugin
  5. pfm21
    pfm21 pfm21 build 3dof dinamic
    374Coins
    If you have 250 money you can download every plugin for one week or buy
  6. Mr-oven
    Mr-oven Mr-oven
    Oven cleaner
    - 42Coins
    2DOF, Motion platform
    Has this plugin stopped working with today's game update?
  7. pfm21
    374Coins
    I use it and work without problem
  8. pfm21
    374Coins
    What problem You have?
  9. Mr-oven
    Mr-oven Mr-oven
    Oven cleaner
    - 42Coins
    Ah, I only installed plugin yesterday and after a little work got it working fine.
    Today I noticed a small 500mb or so update to game and motion has gone.
    I will spend more time working with it if you say it is fine.
    Thanks.
  10. pfm21
    374Coins
    Yes I use also today and not problem. . Verify setting
  11. Mr-oven
    Mr-oven Mr-oven
    Oven cleaner
    - 42Coins
    Yes, all is now working.
    Somehow the UDP channel had changed from 20777 so this fixed things.
  12. pfm21
    374Coins
    Sometimes it happens. Have fun
  13. lupotto
    lupotto New Member
    - 120Coins
    I have a problem: when i run simtools Game Manager, for patching f1 2020, it gives me an error (Before Patching, Please Complete one race in the game), but i complete this race with UDP activated, mode legacy and DirectX 11. I installed the plugin in simtools PluginUpdater and F1 2020, but it doesn't work.
    Can you help me?
  14. pfm21
    374Coins
    When give error continue patching
  15. lupotto
    lupotto New Member
    - 120Coins
    i have done it but when i run, for example, a race Simtools detect a signal but Virtual Axis doesn't work
  16. pfm21
    374Coins
    You must capture data game from simtools
  17. pfm21
    374Coins
    Right click ixon game manager and go tuning center
    After click on capture, reset and run one lap on Monza.
    When finish lap select save setting
    Stop capture
  18. lupotto
    lupotto New Member
    - 120Coins
  19. pfm21
    374Coins
    Try it
  20. Martin.Berger
    Martin.Berger Member
    216Coins
    I finished my Seat some weeks ago.
    LFS works fine for setup.
    Now i started in F1 2020.
    UDP settings set in the Game.
    I start the game in DX11 Mode for multiplayer.
    No movement not even in virtual axis or TC
    The strange thing is when I open the hardwaresettungs.xml some settings ie the last is reset to restricted.
    Any ideas?
    Thank you für Help.
