value1
Colin McRae Dirt 2 Plugin 2.0.0.1
Colin McRae Dirt 2 Plugin for SimTools
  1. jjanu
    jjanu LiveForSim Gold Contributor
    Multimedia
    Québec
    649Coins
    I have a 4dof sim and my 4th axis is for traction loss but when I use the Extra1 on axis 4 in Dirt2 and 3 the motor#4 is receiving surge input from the games instead of traction loss. In Simtools it is indicated that Extra1 is for traction loss. Tuning center is also displaying surge input in the Extra1 cell when I'm accelerating or breaking. Is there an other step we need to perform to get traction loss from these games? Could the latest version of Simtools have changed the way the engine digests Dirt2 and 3 telemetry? Dirt Rally runs perfectly with traction loss. Tks!
  2. jjanu
    Multimedia
    Québec
    649Coins
    No one has an idea why I have this error?! (see my previous comment)
  3. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    813Coins
    @value1 could you please update the plugin to accept extradata=3 instead of 1?
    There is no way for me too use other apps like simevibe, simdash etc together with motion.
    Because we need to use a proxyserver, the main port data must be 1 for simtools but 3 for other apps, they dont work together. (not even with assigned api number in a proxyserver)
    The only solution i can think of is using extradata=3.
    This also applies for Dirt 3.
    I know these are old games, but they are really fun to play, even after all these years. Would be awesome if i can get them working with dash en vibe, and even wind.
    Thanks in advance!
  4. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    Yes it happens to me exactly the same as you
  5. splendiddd
    CCTV security
    Netherlands
    813Coins
    Ok after more testing i think i know what the issue is, this plugin should listen to extradata 1 instead of 0.
    Can this be done? @yobuddy @value1 ?
    In the xml hardwaresettings you can only add one line. For simtools it must be extradata=0 and for other app (also proxyservers) extradata=1.
    When extradata=1 is added into the xml, and port is forwarded to 4123, simtools crashes (or rather quits)
  6. splendiddd
    CCTV security
    Netherlands
    813Coins
    @value1 could you please answer?
    thanks
  7. value1
    14,268Coins
    Yes, it's possible to run Dit2 with extradata=1 but I need some time to update the plugin.
  8. splendiddd
    CCTV security
    Netherlands
    813Coins
    That would be great, thanks! (PS this also is true for Dirt3)
  9. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, I confirm simtools is closing too bad because dirt 2 and 3 are top
  10. izhangt
    izhangt Member Gold Contributor
    - 91Coins
    2DOF, Motion platform
    That doesnt work for me, in extradata 1 gets closed, solution there?
