Compact 3dof build series arudino IBT-2 12v server ps.
Discussion in 'DIY Motion Simulator Projects' started by Halloween2go, Sep 9, 2022.
  1. Halloween2go
    Halloween2go Active Member Gold Contributor
    1,395Coins
    Oh.. now this is real good! Thanks for the photos! I'm putting them at full res so I can take a good look! Thanks for everything! Dave
  2. wuftymerguftyguff
    wuftymerguftyguff New Member
    16Coins
    Hi Dave,
    What CAD package do you use?
    Would you consider sharing your files?
    I love your work on here and also in your video.
    Access to your drawings would really help with measurements.
    thanks
    Jeff
  3. Halloween2go
    1,395Coins
    Hello Jeff.. It's just 3ds max.. I used it to sort of put out some ideas i could see in 3d.. not really for scale or anything other than just helping me to visualize the project.. I will say that 99.999 percent of the dimensions are taken live in the video series via tape measure.. It's a long series.. but hope that helps.. Dave
  4. Halloween2go
    1,395Coins
    Ok guys.. I'm starting to realize that at 60+ years old.. My VISION is just about shot and that soldering components takes me 10 times longer now.. and I STILL get them wrong! Simply cause I cant see small details like I used to.. So I decided to search and try out some components which may add a fraction of cost to your controller boards, but are well worth it.. In terms of speed, disconnectability and level of frustration.. hope that some of you have time to watch the video.. All part numbers are listed in the video, where to get the parts as well as links in the description.. Let me know what I missed.. or if it helped you out.. I'm using all of these new parts on my new rig.. DMAX
    154,124Coins
    +11,170 / 57 / -2
    I feel your pain with respect to age, vision, and fine motor skill deterioration!
    @Ronnie Rowe has made similar wiring related recommendations, with a couple of variations: https://www.xsimulator.net/community/threads/controller-build-for-3dof-smc3.16719/
    With respect to flexible couplings they come in different sizes, both ends, so rather than drill them out buy ones that fit your particular Hall Sensor shaft. Check the data sheet for the Hall Sensor you are using to find the shaft size, for example: https://www.farnell.com/datasheets/2710373.pdf
  6. Opast
    Opast Member
    Chicago, USA
    184Coins
    3DOF, Arduino
    Would you recommend to use Jazzy motors 250W - 300W for your 3 DOF frame? Also, what tubes did you use for rods?
  7. Theodore X Toth
    Theodore X Toth New Member
    64Coins
    Having checked out many of the 'DIY' 3 DOF build youtube videos I think yours is the most detailed and buildable for those of us who don't own a CNC mill, lathe, ... so thank you. I know you did a video covering cost of your previous build, what do you think this one costs i.e. material, seat, pedals, wheel, etc...?
  8. Halloween2go
    1,395Coins
    It's about the same as before.. the motors have gone up about $50 each in price, but the other components are still about the same. I still have the same V3 pedals but now have added SimMagic reactors to them, The seat has been updated with a custom poured foam core which cost about $120 for the foam etc (i did a video on it as well) and I added the HF8 haptic pad into the poured foam seat core. Other than that, overall cost was about the same.
  9. Theodore X Toth
    64Coins
    Thanks. What's the link to the seat foam video? I did that once before the internet for my Formula Ford (SCCA racing) but it was a mess and all remember was I ruined some clothes :(
  10. Halloween2go
    1,395Coins
    Yeah it's a bit messy and I suggested wearing clothes you might consider 'worn out already' turned out pretty fine and ive been racing ALOT more since i made that insert. no noticeable wear and tear yet. D
  11. Halloween2go
    1,395Coins
    I thought I replied in the correct spot.. the link should be next on this thread..
