Cousin of OSW (Open Sim Wheel)
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Sep 23, 2017.
  1. Vdub180
    Vdub180 Member
    England
    148Coins
    has anybody had the same issue as me, ive got 24v going into the ibt 2 but only max of 10v coming out, ive got a 2nd ibt 2 on order hopfuly this will sort this low power issue
  2. evolaco
    evolaco Member
    Spain
    694Coins
    the motor does not heat up when it is brushes and work in blocking all the time?
    Have you thought about putting a pulley to win par? These direct engines have little force for a ffb
  3. Vdub180
    Vdub180 Member
    England
    148Coins
    Motor does not get hot at all
  4. evolaco
    evolaco Member
    Spain
    694Coins
    works at its maximum power? does not fall short of direct force?
  5. Vdub180
    Vdub180 Member
    England
    148Coins
    I put 24v into controller with out any volt drop from battery, with all setting on 100% but on the output side of the controller going to motor I only have a max of 8v when in use on a game with everything maxed out.
  6. Gadget999
    12,331Coins
    do you have a graph of power vs rpm for your motor ?
  7. Vdub180
    Vdub180 Member
    England
    148Coins
    No sorry struggled to find any info on it to be honest
  8. Gadget999
    12,331Coins
    what was the power at the motor when you wired it direct to the power supply ?
  9. Vdub180
    Vdub180 Member
    England
    148Coins
    24v on the 2 car battery's and 12v off the one, I've now added a 2nd ibt2, feels stronger but volts r still between 2v and 9v, same as when I had 1 ibt2,
  10. evolaco
    evolaco Member
    Spain
    694Coins
    have you done the test on the ibt2? it seems defective
  11. Vdub180
    Vdub180 Member
    England
    148Coins
    I'm now running 2 in parallel but still the same off both
  12. Vdub180
    Vdub180 Member
    England
    148Coins
    At the moment it feels like an under powered G29
  13. Gadget999
    12,331Coins
    is your power supply the problem ?
    can you try a different source of power ?
  14. Vdub180
    Vdub180 Member
    England
    148Coins
    Using a car battery 100ah while on charge, so should be powerful, unfortunately I don't have any other supplys about at the moment, would I be wrong in thinking that if the volts don't drop under load then the current would still be ok
  15. Gadget999
    12,331Coins
    if the volts are dropping under load the power supply can not maintain current
  16. Vdub180
    Vdub180 Member
    England
    148Coins
    What's the max volts u get out ur controler, I'm thinking my motor my not be up to the task
  17. evolaco
    evolaco Member
    Spain
    694Coins
    then it can be for some problem in the code? I can not help you in that ...
  18. Gadget999
    12,331Coins
    24 volts
  19. Vdub180
    Vdub180 Member
    England
    148Coins
    24v output to motor from controller, what code r u using maybe I'm using wring one
  20. Vdub180
    Vdub180 Member
    England
    148Coins
    24v in and u get 24v out of the ibt 2 to the motor?
