Cousin of OSW (Open Sim Wheel)
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Sep 23, 2017.
  1. Gadget999
    12,053Coins
  2. danove_b
    danove_b Active Member
    Sweden
    1,782Coins
  3. Gadget999
    12,053Coins
    Looks perfect ! How many amps is one ?
  4. ste94
    ste94 New Member
    203Coins
    A guy on another forum used one of these and he wasn't very happy about it, it was geared so had a pretty big resistance to turn it. But it's pretty strong for the same reason.
    Anyway i've got 2 liteon server Power supply (PS-3601-1F), do you guys know if i can connect them in parallel without any problem?
  5. Gadget999
    12,053Coins
    i think you should be able to connect them together in parallel
  6. danove_b
    Sweden
    1,782Coins
    Do you have a link to that forum thread?
  7. ste94
    ste94 New Member
    203Coins
  8. elnino
    elnino Active Member
    Computer Geek
    Adelaide, Australia
    1,557Coins
    Has anyone considered treadmil motors? generally these are 100+v DC motors and are high torque. if we are looking for high voltage/wattage motors that we can undervolt then these should be perfect.
    Added bonus is that you can score them super cheap from broken treadmils on auction sites.
    they generally have double ended shafts (as they have a low resolution encoder already) and a pulley/flywheel perfect for mounting a wheel hub to.
  9. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    The motor would have to be very specific as I have already tried this with a 180V treadmill motor. You would have to build a custom H_Bridge to run the motor of that kind of voltage.
    I used a IRAMX16UP60A, this type of chip is what is used in VFD controllers. I also used the tradmills own power supply and fed that to the bridge. Unfortunately the power supply blew up in spectacular fashion as it was not able to take the return voltage spikes. This was later descovered that I needed to add a brake resistor circuit to dissipate the excess voltage.
    There are treadmills with 80V DC motors but again, you would have to know which model had what motor.
    Also not every treadmill have the encoder on the motor, the one I got had the encoder on the tread roller so the motor only had one output shaft.
    The MY1020 seems to be in the lead for performance/price ratio for a DC DD FFB wheel. You can under volt that motor and still get good torque.
  10. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    I was thinking something like this we could still run on 12v, not the 100+V. so we can get low current, high torque.
  11. Alexey
    Adelaide, Australia
    8,066Coins
    Unfortunately you could stop the motor with your pinky finger at such a low voltage. A motor that needs 100+V running at 12V will barely run the motor.
  12. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
  13. Gadget999
    12,053Coins
  14. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    Yes but from what i read the Leonardo version has ceased support/dev and there were also some new additions in the stm version i think.
    I am yet to find any source code for it. The author seeems to plug it as open but does not seem to have released thecsource code. The stm32f4 is crazy powerful - way overkill for this application. F1 seems more plausible but i dont know if there is differences in the usb implementation between the two. I ordered an F4 board for about Aud$12, i have to wait for the ibt-2s anyway...
  15. Gadget999
    12,053Coins
    the leonardo identifies under windows as a gaming device
    the code is available but not as raw source code - basically the board gets programmed with a hex file
    i too bought a stm32 development board - it was obsolete and took ages to order on backorder , programming it was not so easy iirc
  16. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    I'm aware of all that - I have done a lot with Arduino and the STM32s including programming etc. I purchased one like this https://www.ebay.com/itm/STM32F4Dis...2bit-MCU-Core-Development-Board-/172366085094 which should work fine. I already have STLink programmer if i need it.
    I (possibly incorrectly) assumed that the code for the Leonardo had been ported to STM32 Arduino and was not natively coded for the STM32 but who knows. According to some brief research, the STM32F1 (i.e BluePill @ AUD~$3 of which I have many) will work as a HID/Joystick and is still 400%+ better performance than the Atmega so I don't know why the creator went with an F4 board, other than 'thats what they had'
  17. danove_b
    Sweden
    1,782Coins
    It has never been confirmed, but according to the drawings found on internet it may be able to control a brushless motor directly using the necessary drivers of course
  18. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    That would be quite interesting but I imaging the 'cogging' would be pretty bad on any decent (suitable for this application anyway) brushless motor.
    Is it even still in development? The code is from 2015 and MMOs (the guy that posted/Authored it) it over on virtualracing.org has not been there since 2016. Perhaps someone else has taken on development?
  19. The_Raging_Peacock
    The_Raging_Peacock New Member
    Slovenia
    204Coins
    DC motor, Arduino
    Hello guys, with help form this thread I made a arduino FFB wheel about 6 months ago and still use it to this day. It works okay but I'm wondering if upgrading to STM32 and MMOS software would give me better FFB. Current setup: Omron 1000p encoder, ZY1016 24VDC motor, one IBT2 driver, 350w 24v PSU, controlled by arduino leonardo. I also have 6+R gearbox, handbrake and 3 pedals connected via arduino. The wheel uses belt drive with about 4:1 ratio. My biggest gripe with it is that if I want good countersteer and details I need to turn FFB up, but that makes it very stiff and hard to turn. I'm only planning to change the processor board (hopefully). Any experiences, imput, advice is welcome :)
  20. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    Upgrading to the stm32 is not going to magically increase electrical power or mechanical force, it just can't. However, as i mentioned before, the Leonardo version was abandoned by the author in favour of the stm32 (Still no real reason why other than 'too hard to install arduino') it seems that there were several updates and probably improvements to the code that might (but probably won't) make a difference.
    Based on the specs you list, that should be plenty other than possibly hitting the limit of the single ibt_2 but it would just go into thermal shutdown which you don't mention. More than likely it is a profile thing i would have thought.
