Cousin of OSW (Open Sim Wheel)
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Sep 23, 2017.
  1. elnino
    elnino Active Member
    Computer Geek
    Adelaide, Australia
    1,557Coins
    Can anyone give some detailed examples of how they inked up the motor shaft with a wheel?
  2. Danksa
    Danksa New Member
    13Coins
    Hey! I've recently started my own project but I'm using two linear hall sensors to calculate the angle of the shaft (using CORDIC). Has anybody still got the source file from Ai-Wave (ESP_WHEEL_0.3.zip)? It isn't available on their site anymore and I need to modify it to not use a rotary encoder. Thanks!
  3. OZHEAT
    OZHEAT Active Member
    Australia
    2,459Coins
    3DOF, DC motor
    @elnino
    I would stay with a design that doesn't directly attach the steering wheel to the motor shaft.
    The quickest way to ruin a motor is to bend its output shaft, once bent it would be pretty hard to straighten again.
    Anything under 16mm you stand a good chance of bending with the leverage of a steering wheel on the end.
    @Danksa
    here is ESP_WHEEL_0.3.zip
  4. Danksa
    Danksa New Member
    13Coins
    @OZHEAT
    Thank you so much! Hopefully everything works out :D
  5. danove_b
    danove_b Active Member
    Sweden
    1,782Coins
  6. Fernando Igor
    Fernando Igor Member
    Programmer
    Fortaleza, Brazil
    913Coins
    DC motor, Arduino
    This version does not work in rfactor 2. Game uses periodic effect, you must add / create the USB_EFFECT_PERIODIC parameter in the function.
    example: https://github.com/fernandoigor/BRWheel/blob/alphatest/brWheel/ffb_pro.ino
  7. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
  8. Fernando Igor
    Programmer
    Fortaleza, Brazil
    913Coins
    DC motor, Arduino
    It is a person project, created with the purpose of using in my G27 that did not work, taking advantage of platform. It did not aim to do something generic for various hardware types like AiWave and MMOS.
    My code is an evolution of the open version released from the RFR (it works on rfactor2 xD), but there is still a lot to improve.
    If you need something specific and the customization of the available versions are not enough, I recommend starting from the code, else go to MMOS or AiWave
  9. Carlo_Labati
    Carlo_Labati New Member
    italy
    213Coins
    its MMos2014 seems doesnt work well with rFactor2 ... no prob with other sim . Anywhone who know the fix ?
  10. The_Raging_Peacock
    The_Raging_Peacock New Member
    Slovenia
    204Coins
    DC motor, Arduino
    Sorry for late reply, had busy days in school. IBT does go to thermal shutdown but i really have to put load on the wheel (long turn during drift etc.) I did order 2 in case one was faulty so I can add anoter one. I really haven't figured out the stiffness tho, and it really bothers me at times i turned off all the damping, spring, friction, inertia sliders in aiwave and messed around in assetto(the game I use my wheel for the most). And again if i lower gain it gets a bit better but i loose all ffb. You can notice the wheel get stiff as soon as i apply power to IBT. Like it has some holding power preset... :/ or it's shorting the motor somehow...
  11. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    I'm not sure I understand what you mean. Are you saying that it does go into thermal shutdown but if you reduce the power enough to prevent thermal shutdown that the power/ffb strength is then not enough?
    If that is correct, I would try adding the second IBT_2 and see what happens.
  12. The_Raging_Peacock
    Slovenia
    204Coins
    DC motor, Arduino
    No I just mentioned that it sometimes happen.
    Problem is wheel is hard to turn even when I'm not in game(as soon as i turn power on with arudino conected)
    I see videos of people using regular wheels like thrustmaster or other diy wheels and it doesn't seem they have much resistance to turn but still have good ffb when neccecary. I use wheel for drift and grip races but nothing extreme(formula or gt3...). Feels like i have a car with no power steering...
  13. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    Alexey - I am curious to know why these are suggested as needed - You see the IBT_2 Modules already have a line driver installed (74HC244D). Why would it need another?
    Looking at the specifications of both the 74CH244D and the BTS7960 they both operate on extremely low currents (high input impedance) i.e 10 microamps, and both operate well at 3v logic. Perhaps, although opposite to the logic that more is better, driving the modules at 5v supply and 3v logic 'line driven' to 5v is actually counter productive and we might be better off running the modules at 3v with 3v logic? The F4 Pins are able to drive up to 25ma per pin (although a total of ~150ma total for the chip)
    I am just looking at the datasheets, I have all the kit, just not wired it up yet... With your real world experience, do you think that's plausible?
    Is that just the spring force?
  14. Gadget999
    12,331Coins
    something is wrong - what motor do you run ? does it have a gearbox ?
  15. The_Raging_Peacock
    Slovenia
    204Coins
    DC motor, Arduino
    ZY1016 24VDC 200W I use 1:4 ratio belt drive... it doesnt have much resistance when ibt&arduino aren't powered up. I'm worried the program was designed for DD wheel and its like a friction preset...
    And i have spring turned down to almost 0%
  16. Gadget999
    12,331Coins
    try turning off some of the effect like spring force off
    i suggest you convert it to a direct drive wheel and see if the problem is gone
  17. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    This could have been an issue solely on my STM board but I could not connect it to multiple H-Bridges without a fan-out buffer (PWM would drop out constantly). Other users seem to not have this issue and thus do not use the buffer.
    You can simply try to connect to multiple H-Bridges without the buffers and see if all H-Bridges respond. In terms of the power supply, I have used 5V as it is far more common as a supply to buy and utilise.
    Yes you could run a 3V supply. The only issue is do not expect to use the onboard STM32F 3v or even the 5v for that matter as they can only output 100ma total. Technically this should be enough for a dual H-bridge setup but my board seems to fizzle out and lose the PWM when I try. Again, try it out and see if yours works as this might just be a gremlin in my board.
  18. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    Plenty of people are using this setup non-dd. post a screenshot of your wheel config
    @Alexey The board i have has 5v direct from usb so should be good for 500ma but i was thinking of using a dedicated 3v supply for the ibt modules anyway (Not from the stm board 3.3v reg). I will be testing it all this weekend but will be interesting to see if reducing the module input to 3v would actually help the setup. If all else fails, another line driver is only a few $ and available from a local retail store.
  19. Gadget999
    12,331Coins
    can you try a Arduino Leonardo instead to see if it is related to the board ?
  20. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    He already is using Leonardo
