Showroom Custom 2DOF full platform
Discussion in 'DIY Motion Simulator Projects' started by Tóth Péter András, May 4, 2023.
  1. Tóth Péter András
    Tóth Péter András TPA
    Budapest, Hungary
    130Coins
    Thank you. I made the suggested changes!
    Hopefully the last issue before the human test :)How to deal with the pitch?
  2. early_m
    early_m Active Member
    Chelmsford
    893Coins
    What is your central pivot joint look like? It should not allow movement in that direction.
    For more mechanical leverage you can attach the rods higher up the back, behind the top of the seat.
    154,576Coins
    +11,190 / 57 / -2
    Many CV joint allow lateral rotation and if used require additional panhard style control rods running diagonally between the top and bottom frames to prevent unwanted twist of the motion sim. A uni joint prevents lateral twist so is a far simpler solution.
    It is worth hunting around and finding an old car to get the tailshaft and uni joint, just cut it to the suitable length, mounting the uni joint as close to the seat base as possible.
  4. Tóth Péter András
    Budapest, Hungary
    130Coins
    Thank you for the replies. I've used, the same 3d bearing as by the shaft, so as you suggested, I'm gonna look for a proper U-joint for it! Thanks again.
    Do you have any link for it maybe on aliexpress?
  5. Tóth Péter András
    Budapest, Hungary
    130Coins
    Thank you! I've made the updates.
    What do you think about using gyro instead of potentiometer?
    154,576Coins
    +11,190 / 57 / -2
    If you are using 10k pots I would suggest 180 degree Hall Sensors as a drop in replacement, as they have good resolution, won't break if over rotated, and have a very long life span.
    I used these but all Hall Sensors with the same specs should be fine: https://au.element14.com/bi-technol...fs/sensor-hall-0-2v-20v-to-10v-pin/dp/2319662
  7. Tóth Péter András
    Budapest, Hungary
    130Coins
    154,576Coins
    +11,190 / 57 / -2
    Because Hall Sensors are a known, proven, robust and extensively utilised solution, I can't recall anyone using a gyro, but you are welcome to try and beat a new path.
  9. Tóth Péter András
    Budapest, Hungary
    130Coins
    They doesn't ship to Hungary :( What about this one:
    https://www.aliexpress.com/item/32422949989.html
    I'm using currently gyro, and it works, but I doesn't know how robust they are...
    Other:
    Any ideas how to fasten the rod to the motor? In the shaft there was only a hole, and I fasten the rod with a screw, but it has a backlash which I doesn't like...
    154,576Coins
    +11,190 / 57 / -2
    Any hall sensor with the same specs should work OK.
  11. Tóth Péter András
    Budapest, Hungary
    130Coins
    I made some updates, eliminated some backlash, and tested without driver:
