DCS/ED 3-DOF starting project, need your help !
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by dureiken, Oct 1, 2016.
  1. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    Hi dureiken
    my motor are speed 19 rpm/min and I feel this is enough....
  2. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,935Coins
    For a motor of 19RPM output it can give a 19*360/60 = 114 deg./sec.
    That gives us a full 360 degree in 3.1 second ...
    As per using a 8cm. crank arm with the ouput shaft that moves only 180 deg.
    So a top to buttom movement of 16cm. will be in a 3.1/2 = 1.5 second
