DD-Wheel with Hoverboard Motor
Discussion in 'Direct Drive Wheels' started by Benu, Jan 21, 2019.
  1. Benu
    Benu Member
    1,295Coins
    Well, I never tested the BLDC output from the MMos board myself. But the creator of the MMos firmware stated in his thread at virtualracing.org that he implemented BLDC support but never tested it himself. I also found no reference of someone else giving it a try.
  2. Benu
    Benu Member
    1,295Coins
    That is interesting! How is your progress? Does the motor react to the FFB input correctly?
    Ok, got it.
    I never tried two IBT2 for that. So I cannot provide any trustable/proofed schematics, sorry.
  3. BiT0
    BiT0 Member
    227Coins
    Progress is slow due few time available because of work and family.
    Positive on HW side: the IFX shield is easy to work with, had no problem with the toolchain.
    Still lot of issues on my code. The motor reacts to FFB but can not say it does...correctly. Lot of spikes. Guess I have to rework the lookup tables but had no time. Let's hope in holidays...
    The wheel project will remain on the IFX, expecially now that I hope to mix the BLDC control code with the AIW you provided (thank you!).
    I was looking at the IBT as a cheaper solution for another later project involving multiple motors. I was looking at the ODrive for that. I like that project very much but was too much for a single motor. But with 2 the 2x IFX cost is not much low.
    The 2xIBT would be a very cheap solution.
  4. Benu
    Benu Member
    1,295Coins
    Do you use shielded and grounded wires for the control and encoder signals? Maybe some interference causes the spikes.
    I think the AIW source came from fernando igor, not me.
  5. BiT0
    BiT0 Member
    227Coins
    Yep all shielded and grounded. I really think problem is my sw. Wll sort it out.
    I know the code is from Fernando. But you posted the git link. I was not able to found it myself
  6. RSP
    RSP New Member
    131Coins
    DC motor
    The IFX007T it's a good solution and easy to install because put the board on Arduino and the current output is very high.
  7. BiT0
    BiT0 Member
    227Coins
    Yes it is a very nice board. Another interesting one from same source is the TLE9879, you can stack up to 4 on a single Arduino. Would be a very nice solution for multiple motor control. Sadly it is not fine for hoverboard motors because of the max 10A rating. Indeed this spec is reported in the product homepage but I did not find any in the tech docs. Still think Odrive is te better solution for multiple BLDC motors. Like maybe in a motion platform...
  8. wannabeaflyer2
    london uk
    8,362Coins
    Hi Guys just wanted to say thanks for the feedback on connecting BTS's to drive Brushless motor , some more bits to order again now before Play time Cheers Some very good info to go check out -)
  9. johnmiller85
    johnmiller85 New Member
    92Coins
    DC motor, AC motor
    I am working a new hoverboard project.
  10. RSP
    RSP New Member
    131Coins
    DC motor
  11. Benu
    Benu Member
    1,295Coins
    I didn't notice these boards yet. Good find!
    The SPIN3204 will not be suitable, I guess. Although the databrief states FOC drivability, I did not see anything in the manuals.
    But the SPIN3201 seems to be a worthwhile candidate. The 3201 is designed for FOC drive and has three shunt current sensing. The other specs are almost identical. Even over-current protection is in a range suitable for our needs (20A/65A/140A).
    This board could be a good alternative to the F303RE/IHM08M1 combo.
  12. BiT0
    BiT0 Member
    227Coins
    Wish to share a resource.
    It may be of interest expecially for @danove_b since he is working with tables like me. BLDC Lookup table calculator.
    It is a spreadsheet in open office format to crete lookup tables for both SPWM and SVPWM.
    Original credit to Barryjam. Interesting reading (and code).
  13. BiT0
    BiT0 Member
    227Coins
    Hey @danove_b had another look at the code you posted on page 2 and have a question.
    I am reworking my own code in the sinusoidal function moltiplication.
    I am not sure what you did there in the logic you applied for values of the sinusoidal function ><127.
    Beside this are you sure abouth your math? I mean I think there is a fault: your argument to the function is a float between -1 and 1, that is 0 is supposed to be 50% torque. But when the argument is 0 your algorythm will always ouput 127
  14. danove_b
    danove_b Active Member
    Sweden
    1,782Coins
    That part is correct, but I did some more adjustment to the code when I did my tests. 127 should give about 6 volts and be considered as the zero level. 255 will give 12 volt and 0 will give 0 volt. So with zero torque demand we will put out 6 volt on all three phases.
  15. BiT0
    BiT0 Member
    227Coins
    Hi danove_b. OK about volt/torque. So for you the 0 as argument equals to ... zero. LOL
    I missunderstood the range to your CalcTorque and thought you were going from -1 to 1, with 0 being half.
    Is that to reverse?
    I've found other code on the net, as a modification of the one from barryjam I linked above.
    Like this or from the same author in a different repo this
    Here on the same array concept he is doing in first case
    Code:
    // get number from the sin table, change amplitude from max
      pwm_a = (pwmSin[(position + currentStepA) % 360]) * (power / 255.0);
      pwm_b = (pwmSin[(position + currentStepB) % 360]) * (power / 255.0);
      pwm_c = (pwmSin[(position + currentStepC) % 360]) * (power / 255.0);
    and in the second
    Code:
    // fetch pwm from sinus table
      posStep = MotorPos & 0xff;
      pwm_a = pwmSinMotor[(uint8_t)posStep];
      pwm_b = pwmSinMotor[(uint8_t)(posStep + 85)];
      pwm_c = pwmSinMotor[(uint8_t)(posStep + 170)];
      // apply power factor
      pwm_a = maxPWM * pwm_a;
      pwm_a = pwm_a >> 8;
      pwm_a += 128;
      pwm_b = maxPWM * pwm_b;
      pwm_b = pwm_b >> 8;
      pwm_b += 128;
      pwm_c = maxPWM * pwm_c;
      pwm_c = pwm_c >> 8;
      pwm_c += 128;
  16. danove_b
    Sweden
    1,782Coins
    I can send you my test code tonight.
  17. BiT0
    BiT0 Member
    227Coins
    Oh that would be kind of you. I am collecting lots of info and studying a lot because with my own code I still got a lot of spikes.
    What do you think of the math used by that guy in the code I posted above?
  18. danove_b
    Sweden
    1,782Coins
    Attached my simple test code. In this code I have used the inbuilt hall elements in the motor for the commutation. Of course this will be replaced with the encoder, but I didn't have that at this time. This was the first time I did something similar. Was mostly reversed engineering... As you can see I change the commutation with 140 degree to change the direction. I have no explanation why it worked best with that value. I was expecting 120 or a multiple of that.
    I used a potentiometer connected to a AD in to simulate the torque values. The enable signal enables the drivers. (I disable it when there is no torque, which make the motor easy to turn by your hands) I don't know if this should be there or not in the final application.
    My own comments are sometime in the Swedish language... I kind of mix...
  19. danove_b
    Sweden
    1,782Coins
    I also played with some sine generator in Excel. You can check the values by changing the torque factor (0-1) in R1C8
  20. BiT0
    BiT0 Member
    227Coins
    Hi @danove_b, sorry for late answer. Lot of family troubles are taking me away from this project atm.
    Thank you for sharing your code. Very kind by you.
    Indeed it is very close to mine because I too started from the same original code you posted early.
    The only differences are in the torque scaling math that is much simpler and based upon the code I found here Arduino_BrushlessServ and in the commutation at 120.
    I may be wrong but in your code since the sine arrey element you select is choosen by the angle you pass to SetTorque() and that angle comes from math with two constants applied to the hall reading, which returns 6 possible values, indeed only 12 (6+/6-) possible values may be sent to SetTorque(). That is of the whole array you use always the same 12 elements upon the Commute().
    Other than that my code differs in the mmos interface which I am still dealing with (frequency and smoothing function which I am not convinced of). I am thinking to switch to the mode1 of PWM output from mmos but as said not time at the moment.
    Also as soon as I'll be back to the project I want to try an open loop method, with no sensor at all (used for the HID input but not to drive the motor).
